bigdigital.kov
Been thanked: 9 times
Post by bigdigital.kov »
How to use it.
Notes .
-cmp2 Compress gtr2(gts2) bin
-unc Decompress
Current version 0.2
Chagelog
v0.2
Added widgets.
(323.58 KiB) Downloaded 2321 times
Has thanked: 414 times
Been thanked: 2071 times
Messef wrote: 16 Feb 2021, 15:44
Thank you for your response and the unpack.
I don't speak Russian, so I can't do much with the link to main.exe by SashaCX75.
See your PM.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
The problem of not displaying the "Bluetooth" sign is not current. I know that the GTR 2 only shows the "Bluetooth" out of range sign, if we use one in the watch face design.
su8044
Post by su8044 »
eliasf wrote: 04 Feb 2021, 07:39
Trying to decompile a couple of watchfaces and it results in a traceback error.
The log says:
WARNING - [ParamConv:parse] currentPath 5/./2/./3/./3 / Parameter 3 isn't supported for <class 'watchFaceParser.elements.gtr2.progress.Progress'>
CRITICAL - Parameter 3 isn't supported for <class 'watchFaceParser.elements.gtr2.progress.Progress'>
Has anyone else encountered it and is there a solution?
I can provide a full log if necessary.
Same issue here with only a couple of watch faces i tried. i wanted to try the workaround you mentioned but i think the file is now called "stepsProgress. py" on the latest version and already has 3 defined so i can't figure what else it might be, im still learning.
on another note, i see some default amazfit watchfaces not only have the option to select between different info displayed on the complication, but also the ability to be used as a shortcut to the amazfit app on the watch, and some extra info such as 5 day weather and windspeed i haven't seen on other watchfaces. is this possible in the current state of the compilers or will ot be in the future?
thanks!
eliasf
Post by eliasf »
That was an issue I had with v0.1 and it was since fixed in v0.2, it had to do with the weekdays progress which is probably parameter 3.
If you are trying to decompile a wf with "hot zone" (shortcuts) like huami calls it you would get a parameter 6 error. I did that and that's what I got.
This means that the parser can still not handle how huami have set up that specific feature.
Hopefully in a newer version this will be sorted out, unfortunately you can't get much help from Huami themselves which means it's up to the tool developer to understand their internal structure and how to implement a working parser that translates properly.
One can only hope...
su8044 wrote: 24 Feb 2021, 06:55
The log says:
thanks!
Fringo
Post by Fringo »
It also works on ZEPP E CIRCLE not only GTR2! Thank you :)
masterplexus
Post by masterplexus »
Hi all,
I'll start to try todo my own Watchfaces, and it looks like it is possible with the help of this group and tool ;) But I have one question for a special need:
Is it possible to include in a watchface also data/information, wich comes not directly from the Zepp app, or the watch itself? The background is, that I'm diabetic, and I have a measurement system wich collects blood-sugar values (with an app called xDrip). This information's I would like to provide also on the watchface. I can provide the information's in several ways (like json, as a graphic, over intents or whatever), but I'm not sure how to bring this information then into the watchface.
Is there any manual which could describe something like this? If someone could put me in a direction would be great!
Many thanks for any help!
bird81309
Post by bird81309 »
want to know how to modify the display of AOD mode...想知道要怎麼修改AOD的顯示
wolliden
Post by wolliden »
I am really happy that this tool exists, and it works (unpacked existing WF). I want to change several complications, because I need sunrise/sunset time and week number to show up permanently. Is this still not possible, with Huami watches?
CyclingAsia
Post by CyclingAsia »
Thanks for this amazing utility. Until today I was stuck as I don't have a windows machine. But today I was able to work out how to run the GTR2_Packer.exe in macOS (and likely works in Linux as well). Turns out the GTR2_Packer.exe is a java cli app that has been attached to a stub java loader, as such it can be run with java on macOS and Linux machines.
I wrote a fairly simple bash script to launch java with the appropriate arguments.
1. Edit a file called GTR2_Packer using your favourite editor (eg vim)
2. Copy and paste the following:
#!/bin/sh
java -jar $0.exe com.thatguys.Main $*
3. Save the file in the same directory as the GTR2_Package.exe
4. Execute it as you would any other command line utility.
Note: this will likely not work as expected if there are spaces in the directory tree.
mbp:py_amazfit_tools-GTR2$ ./GTR2_Packer
Wrong usage
usage: gtr-packer
 -cmp <filename>    Compress
 -cmp2 <filename>   Compress gtr2 format
 -test <filename>   Decompress and compress file, and make sure they are
                    equal
 -unc <filename>    Decompress
 -unc2 <filename>   Decompress gtr2 format
Aaronfet
Post by Aaronfet »
Thanks a lot for that tool I was just trying to figure out how to do a HTML5 port using Love.js games not finished yet, but I prefer to know early where I might have problems. I must have been doing something wrong because it wasnt working but thanks to your tool I wont have to waste time trying to find out what I did wrong. I was also starting to wonder if Id done something in my code that couldnt be ported, so it put my mind at ease.
Julien
Post by Julien »
Hello bigdigital.kov we've talked over Github, it seems you worked on the GTS 2 Mini too.
Is GTR2_Packer.exe an executable version of your python script or is it a separate project? I'm confused
bigdigital.kov
GTR2_Packer.exe is a separate project. it is required to compress/decompress existing watchface before uploading wf to the device. The GTR2/GTS2 can consume only compressed watcfaces. But it seems the GTS2 mini , do not require any compression. I guess this is because they use relatively small 16 bit images and the device screen much smaller
darekperlinski
Post by darekperlinski »
Hello, with amazfit gtr 2e it's working also(not for every watchfaces)! thanks!
