• 管理员
版面规则
回复
头像
来自: Ukraine
Has thanked: 13 time
Been thanked: 1036 time
联系:
帖子 SashaCX75 »
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
上次由 SashaCX75 在 01 6月 2022, 07:20,总共编辑 25 次。
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Only the drawing order of the analog clock hands is changed.
If at least one hand is offset from the center, then the second hand is drawn below the other hands. In other cases, the second hand is drawn from above.
The drawing order of arrows for other indicators does not change.
If there is any other information, please let me know so that I can correct the editor (preferably with specific examples).
jjkielce
来自: Poland
Has thanked: 3 time
联系:
帖子 jjkielce »
OKAY. IN MY AVAILABLE MOMENT, I WILL TRY TO CHECK ALL THE OPTIONS AND I WILL DESCRIBE YOU. GREETINGS
头像
Wizballs
来自: Australia
联系:
帖子 Wizballs »
Great app! Was wondering if there is anyway to change the order of analogue hand drawing so that if falls below all other output on watchface? Eg draw hands under digital time, heart rate, step counter etc. This way all of this other data would remain visible at all times...
SashaCX75 写了: 17 10月 2020, 16:52
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Wizballs
The analog clock hands are always drawn above the rest of the data. They can only be overridden by a static image.
头像
Biggie
Has thanked: 3 time
Been thanked: 2 time
联系:
帖子 Biggie »
SashaCX75 - What is the meaning of the "Device-Id" in JSON section "Info" for your editor? ZEPP and Notify&Fitness are stating for my GTS: "41 - GTS Global", you're using the "46" for the GTS.
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Biggie
This parameter is needed to automatically detect the model when opening a json file. This is inserted into the bin file.
头像
Biggie
Has thanked: 3 time
联系:
帖子 Biggie »
SashaCX75 - Yes, it make sense, but why not the "official" ID (GTS: 46 instead 41)? I'm assuming, it's only an internal code for you, to decompile the right version of bin files?
Notify&Fitness and the GTS watch are accepting both of them... By the way - your editor too...
Thanks for your fine prog! This is the reason why my new Amazfit X is lying on a rack and the GTS is still my favorite ;-)
Remark: The X has the ID 71 (at least the X from IndiGoGo...)
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Biggie
I do not know which ID in Notify & Fitness you are talking about. This ID is issued by the bin file decompilation program (by dpeddi) and this ID is stitched into the bin file when it is created.
头像
Biggie
Has thanked: 3 time
联系:
帖子 Biggie »
Amazfit delievers different ROM version depending on region (e.g. the primal CN/EN and the Global version) . Probably the "Amazfit-ID" which Notify&Fitness reads out is different therefore. For reading a watchface bin file this is seemingly quite irrelevant... Sorry for my wasted question.
Kivan
帖子 Kivan »
Hi Sasha, I already get the zepp e square smartwatch. I have the WF bin files but your amazing tool do not open. I detected my device ID is 82. I tried to install a GTS bin changing the device ID to 82 but with no luck. Have you tried something with gts2 bin files or zepp e square ones (they work are the same).
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Kivan
帖子 Kivan »
And are you planning on extend it to gts2/zepp square watchfaces (they use the same)? 😊
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
I have no information about the ability to disassemble the GTR2 / GTS2 watchfaces. Until there is a utility that can do this, then there is nothing to edit.
Kivan
帖子 Kivan »
Allright. Actual decompiler try to unpack the bin, but the log file says it fails after a few lines. I hope it will be an easy task to solve!
Thanks for your answer!
头像
Biggie
Has thanked: 3 time
联系:
帖子 Biggie »
On my GTS it was today a firmware update to 0.1.1.17. This makes the watch useless for me. No userdefined watchface can be loaded anymore, not any of my own and nothing from this forum's watchface site. "Ungültige Firmware gefunden" is the message (probably "Invalid firmware found" in English), if pressing the Update button to upload this to the watch...
sharizal78
来自: sungai petani
联系:
帖子 sharizal78 »
SashaCX75 do you have update for AmazFit_Watchface_Editor to solve problem with amazfit GTR new firmware 3.7.18?. This firmware encounter error "wrong firmware file found" when sync using notify & fitness for amazfit.
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
I have firmware 1.3.7.17 on GTR and there are no such errors on it, so I cannot check.
My editor only edits the json file of the project. A third-party utility is used to build the bin file, and if the author does not update it, then I’ll hardly be able to fix something.
The worst thing will be if the signature of the watchfaces is added to the new firmware. Then nothing can be fixed.
Horatius80
帖子 Horatius80 »
It was a Notify & Fitness issue, new updated N&F corrected this watchface upload issue read here:
Notify for Mi Band & Amazfit
Official Notify & Fitness for Mi Band and Amazfit/Zepp apps channel. News, suggestions, updates and much more!
https://t.me/notifyfitness
juanl
联系:
帖子 juanl »
Good Morning,
I do not know if it is technically possible because of hardware, etc.
Could the sphere editing program be modified so that 2 or more animations can be put?
I mean animations that are not animations between coordinates.
Thanks a lot
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Until such official dials appear in the Zepp program, I think it will be impossible.
Lori T
来自: Granada
联系:
帖子 Lori T »
Hi, I'm having a problem installing a watchface. If I put the date, even though the program generates the bin, the watchface is not displayed in the watch. If I remove the date, everything is displayed without problem. The images I use for the date numbers are the same as for the battery.
Where is the problem?
This is the code of the date right now:
"Date": {
"MonthAndDay": {
"Separate": {
"Day": {
"TopLeftX": 236,
"TopLeftY": 30,
"BottomRightX": 265,
"BottomRightY": 0,
"Alignment": "TopCenter",
"Spacing": -5,
"ImageIndex": 11,
"ImagesCount": 10
"TwoDigitsMonth": true,
"TwoDigitsDay": false
头像
Biggie
Has thanked: 3 time
联系:
帖子 Biggie »
Don't know if this the reason for your problem, but BottomRightY can't be null.
It is always TopLeftY + the pixel height of a digit image.
头像
来自: ͼͽ Thailand ͼͽ
Has thanked: 420 time
Been thanked: 2122 time
帖子 asoo »
Lori T 写了: 11 11月 2020, 08:34
"Date": {
"MonthAndDay": {
"Separate": {
"Day": {
"TopLeftX": 236,
"TopLeftY": 30,
"BottomRightY": 0,
"Spacing": -5,
"ImageIndex": 11,
"ImagesCount": 10
Can you send or post link download the "BIN" that have issue ?
Lori T
来自: Granada
联系:
帖子 Lori T »
Thank you both for the replies. I have been working on it and the problem was not in the date, it is that I can't
use more than 6 different elements in the same watchface. (battery, clock, date, steps number, step progress and bluetooth status). When I disable one of this the watchface loads.
electronikos
联系:
帖子 electronikos »
I have the same problem with Lori T. In the past I am sure that I was able to load more than 6 elements in one watch face without problem. I found this problem 7 days ago . Do you know what is the problem. (I install the watch face and it is not available) this problem has nothing to do with bin size just with the elements of the Wf
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 1 访客
