Messaggio da SashaCX75 »
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
blauer
Messaggio da blauer »
hello,
nice tool.
can you translate in german
and a manual in german?
i have win10 32bit, GTR 42.
many thanks
blauer
lawrence-dol
I do not notice such problems in myself. I tried to fix something. Try whether it helped or not.
AmazFit_Watchface_Editor_(without_Python)_8_5_beta
blauer
I do not translate. If someone translates, then I can add the finished translation to the program.
blauer
okay is good.
but the most of faces can't open with this tool
urbanrattrap
Messaggio da urbanrattrap »
I'm new here..
is there any guide to use the tools for GTR Watch Face(version 7.1)?
such a written manual or video?
i tried to read all the forum but did not find any guide.
please help
nqh2412
Messaggio da nqh2412 »
Great tool!
I have problem when I try to pack the json file to .bin the log file show this what can I do to fix this. Thanks
"2020-08-20 18:14:06,008 - root - CRITICAL - 'NoneType' object has no attribute 'getMinusImageIndex'
File "program .py", line 71, in writeWatchFace
File "program .py", line 181, in generatePreviews
File "watchFaceParser\previewGenerator. py", line 16, in createImage
File "watchFaceParser\previewGenerator. py", line 25, in createFrame
File "watchFaceParser\models\elements\basic\containerElement. py", line 12, in draw3
File "watchFaceParser\models\elements\weather\temperatureElement. py", line 39, in draw3
AttributeError: 'NoneType' object has no attribute 'getMinusImageIndex'
nqh2412
It looks like the picture for the "-" symbol for the weather is not set.
nqh2412
SashaCX75 You are right.
Thank you very much!
Thank you again for your amazing work!
HARRINGT0N
Messaggio da HARRINGT0N »
is there a way to get rid of the leading 0 in the time for 12 hour version. (ex. 2:42 rather than 02:42)
romstemp
Has thanked: 9 times
Been thanked: 41 times
Messaggio da romstemp »
HARRINGT0N ha scritto: 24 ago 2020, 21:49
An example watchface for a question you have asked
Watchface by ASoo : https://amazfitwatchfaces.com/gtr/view/6893
Quangvm3
Messaggio da Quangvm3 »
Tool will work for T-Rex also, right?
Matt-One
Messaggio da Matt-One »
Hello, and thank you for this great tool, can i know the difference between Current Weather and Icon under the Weather options? They seem to do the same thing... Thank you :)
Quangvm3 ha scritto: 25 ago 2020, 13:36
Yes, the program works with T-Rex. But in T-Rex, not all functions may work.
Matt-One
Current weather displays the temperature, the weather icon shows the type of weather (cloudy, sunny, rainy, etc.). These values are the same as those in the watch weather menu.
Matt-One
SashaCX75 ha scritto: 25 ago 2020, 14:28
@Matt-One
Thank you for your answer, I think you have to translate it in Current Temperature? :) :P Just jocking...
I would like to ask you if it is possible in the Animation tab, to show for example an animated icon only when the watch measure the heart rate, otherwise the icon is stopped. Thank you again for your time :)
Matt-One
I am not engaged in translation, but other people. In the next version I will probably correct it.
Not. The animation is displayed regardless of other conditions.
HARRINGT0N
romstemp ha scritto: 25 ago 2020, 13:20
OK so how do I change a face to get rid of the leading 0?
hohenheimz11
Has thanked: 12 times
Messaggio da hohenheimz11 »
Been thanked: 2122 times
Messaggio da asoo »
HARRINGT0N ha scritto: 27 ago 2020, 00:52
The rough process
1. Make a main screen (0000.png) with the hour section with _0:00
2. Make a set of numbers for hours as usual, but in part number 0, make a transparent blank image, other numbers have background according to the main screen color.
3. Place the hour numbers as usual.
If following this, you will be shown the numbers in the hour portion as you expected.
PS. You can learn more by extracting "BIN" files for use as an example.
hohenheimz11 ha scritto: 27 ago 2020, 08:41
hohenheimz11
SashaCX75 ha scritto: 27 ago 2020, 14:06
Thank you for the reply. I'd try so many times to convert all WF that I'd been created to verge lite...even excluded weather files to do so but still error. I hope there's a solution to this and update regarding this matter in your WF program tools in the future.
Best regards.
hohenheimz11
hohenheimz11
SashaCX75 ha scritto: 30 ago 2020, 13:10
@hohenheimz11
Thank you! Will try that :)
Matt-One
Why the editor don't accept 8bit PNG images?
MJW
Messaggio da MJW »
Hello guys! I am new here. Amazing work Sasha!
I used an Amazfit Bip and now I have an GTR. Seeing the py_amazfit_tools I found these code:
class ClockHand:
definitions = {
1: { 'Name': 'OnlyBorder', 'Type': 'bool'},
2: { 'Name': 'Color', 'Type': Color},
3: { 'Name': 'CenterOffset', 'Type': Coordinates},
4: { 'Name': 'Shape', 'Type': Coordinates}, #must be array [] fix it!
5: { 'Name': 'Image', 'Type': Image},
6: { 'Name': 'Sector', 'Type': Sector},
Can the property "Sector" be used in class ClockHand? It will be and big upgrade in watchface design.
Thanks again for your editor!
MJW
The "Sector" property works for the battery, step progress, date, etc. For hour, minute, second hands, the "Sector" property does not work.
Version 8.5
Fixed work with Verge Lite.
Torna a “Watchfaces tools”
