Se encontraron 12 coincidencias
Return
por GIK-Team
21 Jul 2020, 07:16
Jump to forum
Jump to topic
Re: Verified authors ✅
hohenheimz11 escribió: 21 Jul 2020, 03:47
I would like to apply for a verified author and will be humbly glad if got accepted. Thank you.
Some of your work is very similar to other work in the catalog.
Add a few more works, please. You have a lot of similar works, which it is desirable to combine into one (this is advice for the future).
por GIK-Team
26 Jul 2020, 20:30
Jump to forum
Jump to topic
hohenheimz11 escribió: 26 Jul 2020, 17:47
Am I able to join now? Just a quick check
The main point of the Verified authors' group is to support those authors who make unique works by themselves. Regarding the minimum quantity: you need to have at least 5 works that were completely designed by you.
por GIK-Team
29 Jul 2020, 19:06
Jump to forum
Jump to topic
Re: 403. Access denied.
hohenheimz11 escribió: 29 Jul 2020, 18:00
I have a problem uploading my WF to the catalog. It never happen before.
403
Sorry! Access denied :(
You do not have permission to view this directory or page using the credentials that you supplied.
Remove the quotation mark ' from name of the picture.
por GIK-Team
29 Jul 2020, 20:18
Jump to forum
Jump to topic
hohenheimz11 escribió: 29 Jul 2020, 19:34
Thank you so much! It's fixed! I finally able to upload my works. Cheers!
You're welcome ;)
por GIK-Team
04 Ago 2020, 21:47
Jump to forum
Jump to topic
hohenheimz11 escribió: 04 Ago 2020, 19:41
I would like to become verified author. Best regards. Cheers!
Cheers! ✅
por SashaCX75
17 Dic 2019, 17:06
Jump to forum
Jump to topic
https://i.postimg.cc/PrMjngqJ/2020-09-14-19-39-23.png
Not all ...
por SashaCX75
17 Jul 2020, 18:32
Jump to forum
Jump to topic
Re: GTR_WatchFace editor for Windows by SashaCX75
Version 8.3
Bugs fixed.
Added a manual in English.
por SashaCX75
27 Ago 2020, 14:06
Jump to forum
Jump to topic
hohenheimz11 escribió: 27 Ago 2020, 08:41
por SashaCX75
30 Ago 2020, 13:10
Jump to forum
Jump to topic
hohenheimz11
por SashaCX75
14 Sep 2020, 16:35
Jump to forum
Jump to topic
Version 8.5
Fixed work with Verge Lite.
por SashaCX75
17 Oct 2020, 06:46
Jump to forum
Jump to topic
No. In GTR2 / GTS2 another way to create a bin file. I don't know a way to parse the bin file from GTR2 / GTS2 yet.
por SashaCX75
21 Nov 2020, 10:48
Jump to forum
Jump to topic
Re: AmazFit WatchFace editor for Windows by SashaCX75
Version 9.0
Fixed bugs when ...
