• Administrador
Reglas del Foro
Avatar de Usuario
Contactar:
Mensaje por SashaCX75 »
Imagen
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Última edición por SashaCX75 el 01 Jun 2022, 07:19, editado 32 veces en total.
ScaredyCat
Contactar:
Mensaje por ScaredyCat »
Ahh ok, thanks. I'm not going mad then ;)
Probably means my icon isn't aligned in the centre too, so willfix that :)
Avatar de Usuario
Contactar:
Version 6.1
Update v 6.1. Fixed weather alignment.
dilshadsys
Contactar:
Mensaje por dilshadsys »
kevin2012
Contactar:
Mensaje por kevin2012 »
Thanks. Will be really great if it also supports unpack gts 2 mini bin file even though it may not support creating.
Spiric
Contactar:
Mensaje por Spiric »
How can i convert WF from T rex Pro to T rex?
Avatar de Usuario
Contactar:
Spiric
Disassemble it in this editor and use the resources from it to make a new dial for the T-Rex.
Not all features from T-Rex Pro are supported in T-Rex.
ShepsCrook
Contactar:
Mensaje por ShepsCrook »
I'm unable to download from Dropbox oddly enough. It fails to download and acts like I need to log in. Anyone have any alternative download links for this stuff? Google Drive? something?
Slughorn
Mensaje por Slughorn »
Hi friends.
The amazfit watch face editor 2 doesn't open many dials for the T-rex. I try to open as a compressed bin and it doesn't unzip it, what can happen?
Avatar de Usuario
Been thanked: 2122 times
Mensaje por asoo »
Slughorn escribió: 17 Ago 2021, 19:19
Hi friends.
I think , you can not open " T-rex " Because "AmazFit WatchFace editor 2 for Windows" Do not support it. This program support only "T-rex PRO"
If you would like to open "T-rex" BIN you can use " AmazFit WatchFace editor for Windows by SashaCX75 " to do it.
Link to Program :
viewtopic.php?f=29&t=1076
Slughorn
Sorry, the watch faces of the t-rex pro are the ones that won't open.
[email protected]
Contactar:
Mensaje por [email protected] »
SashaCX75 escribió: 12 Abr 2021, 07:58
How does conventer GTR47ToGTR2 work?
Loads discs from T-Rex and saves as T-Rex Pro.
In Editor 6.1, I can't open it. The files are numbered 0000 not 0001 and the json layout is not loaded.
And I would like to add AoD to the reworked dial.
Avatar de Usuario
Contactar:
Slughorn
If you clarify which dials are not unpacked, in which version of the editor and on which system you are trying to unpack, then it will be clearer what the problem is. The editor does not work on 32 bit systems.
[email protected]
Editor v 6.1 and shouldn't unpack such dials. Converted dials have the older format. To work with such dials, the first message contains a converter combined with an editor. There is no AOD on such dials.
Slughorn
Thank you very much, I did not know that. I think now if it goes with the previous amazfit watch face.
Avatar de Usuario
Contactar:
Version 7.0
Elbruz
Contactar:
Mensaje por Elbruz »
Thanks before for created this tools, I'm very helped to created my own watchface.
I've trying to edited watchface from other creator, but when I'm packed and compress the file after editing, the size of BIN file is larger than original file.
what happen for this problem?
how to create BIN file with small size ?
Thank you
evileyes
Contactar:
Mensaje por evileyes »
https://amazfitwatchfaces.com/t-rex/view/7001
I'm using editor 2 to create this for Trex Pro,
it looks all good in the editor,
but its only black screen when installed to the watch.
so what is happening or what am I missing ??
Avatar de Usuario
Contactar:
evileyes
The first file must be a background or preview.
This watch face is made for Zepp E Circle and not for Trex Pro.
Saqibpiash
Contactar:
Mensaje por Saqibpiash »
Please support for GTS 2 Mini
Avatar de Usuario
Contactar:
Version 7.1
spidercrab
Has thanked: 27 times
Contactar:
Mensaje por spidercrab »
Not sure if this is exactly the right place to ask this question.
Is it possible to create WF's for the Zepp Z?
If not, as there are similarities to other round Amazfit devices, is it likely that this will be supported in WF Editor 2 or future versions?
Avatar de Usuario
Contactar:
spidercrab
I have not seen Zepp Z watch faces and cannot say anything about them. But judging by the size of the screen, the dials from GTR 2 should work.
Horatius80
Mensaje por Horatius80 »
spidercrab
Based on the various information available, the ZEPP Z should only be a "disguised" GTR2 without a speaker
manzoorkhokhar
Contactar:
Mensaje por manzoorkhokhar »
hello
i need converter which convert amazfit gtr 2 watch faces to gtr 47mm
here i found the concerter which convert gtr 47mm watch faces to gtr 2 but did not find any converter which can convert GTR 2 watch faces to GTR 47 mm
can anybody help
Avatar de Usuario
Contactar:
manzoorkhokhar escribió: 05 Sep 2021, 15:56
There is no such converter. You can disassemble a watch face in one editor and assemble a new watch face in another editor.
manzoorkhokhar
Contactar:
I am not such technical :( to do such difficult task neither know about any software which can do this task
anyhow Thanks for your time and response
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 4 invitados
