Amazfit Balance
BigBlind68
Post by BigBlind68 »
supersufa wrote: 21 Nov 2023, 14:17
BigBlind68 wrote: 21 Nov 2023, 12:19
For all Android users, you can try this option to upload to your Balance: https://discord.com/channels/6872628817 ... 1866498069
I don't own an Android device so I cannot test it.
Link seems not working... Discord doesn't open any server and/or discussion....
https://discord.gg/9yN2dqnN
Paul570
Post by Paul570 »
can you kindly post this guide in another way? thanks mate
Stephthouv
Has thanked: 7 times
Post by Stephthouv »
Same for me. Link doesn't work.
BigBlind68
domenicopardo
Post by domenicopardo »
TROPPO COMPLICATO - TOO COMPLICATED
I HOPE FOR SIMPLER APPS OR SOLUTIONS - SPERO IN APP O RISOLUZIONI PIU' SEMPLICI
supersufa
Post by supersufa »
There is a workaround solution finally.... While we wait the official app....
It is not so complicated.... And works fine for Android also....
BigBlind68
Yep, you can even use the original ZEPP app to upload the watch face to you Balance with a QR code
Powerade001
Has thanked: 12 times
Post by Powerade001 »
Hi!
Can someone just copy/paste the solution here because I cannot find it on the link provided even if I subscribe to the group.
Thanks a lot in advance
supersufa
Post by supersufa »
I done it yesterday evening but moderation delete my message....
I'm sorry....
I retry to explain in other words...
The procedure is quite simple... You have to download your favorite watchface from the site, then rename the file in device.zip....
This file has to be added into this archive http://tagete.altervista.org/WatchFace.zip by replace the same file device.zip.
After this you have to modify the file extension from WatchFace.zip to Watchface.zpk.
Load the file on your web space and copy the file url....
ie http:// yourspace / Watchface.zpk and generate a qr code by modifying the url as follow:
ie zpkd1:// yourspace / Watchface.zpk
Enter in zepp developer mode (search on web how to do this) and scan the generated qr code.
The watchface will be installed autmatically on your balance!
domenicopardo
Watchface.zpk or Watchfile.tpk ?????
supersufa
Post by supersufa »
domenicopardo wrote: 25 Nov 2023, 18:36
WatchFile.zpk
domenicopardo
Grazie ! speriamo che funzioni . Per ora niente. ( ti rispondo i italiano considerando che sei di Biella, poi in inglese per il resto della comunità).
Thank you ! let's hope it works. Nothing for now. (I'll answer you in Italian considering you're from Biella, then in English for the rest of the community).
supersufa
Post by supersufa »
Dunque... Ti rispondo anche io in Italiano... Ho provato diverse volte caricando il file (zip, che poi cambiando l'estensione diventa zpk ma sempre uno zip rimane) su github come consigliato dalla guida.... Ma non c'era verso... Mentre su altervista funziona immediatamente.... Ti consiglio quello, ma semplicemente perchè, a differenza di Drive per esempio, hai un link diretto....
So... I tried several times uploading the file (zip, which then changing the extension becomes zpk but still a zipremains) on github as recommended by the guide.... But there was no way... While on altervista it works immediately.... I recommend that one, but simply because, unlike Drive for example, you have a direct link....
McAND
Post by McAND »
Come mai non c'è un modo come il GTR 4 di caricare le watchfaces? C è l.app.balance,vede il Mac adress.ma.nn funziona , xchè queste protezioni??
Has thanked: 1162 times
Been thanked: 279 times
McAND wrote: 29 Nov 2023, 21:04
Salve,
Grazie per averci contattato e per aver condiviso la tua esperienza con il nostro app. Stiamo costantemente lavorando per migliorare la compatibilità del nostro app con vari modelli di smartwatch, ma a volte incontriamo alcune limitazioni tecniche o restrizioni imposte dai produttori.
Per aiutarci a capire meglio la tua situazione, potresti fornirci maggiori dettagli su come stai cercando di caricare le watchfaces e su qualsiasi messaggio di errore o problema specifico che incontri? Queste informazioni ci aiuteranno a indirizzare meglio il problema e a cercare soluzioni.
Apprezziamo la tua pazienza e il tuo supporto mentre lavoriamo a migliorare l'app.
massi131
Post by massi131 »
buongiorno
Gentilmente cosa significa "Load the file on your web space and copy the file url...."
Grazie
massi131 wrote: 03 Dec 2023, 09:25
buongiorno
Grazie
Buongiorno,
Grazie per averci contattato. Per aiutarti al meglio, potresti fornirci maggiori dettagli su dove hai trovato il messaggio "Load the file on your web space and copy the file url..."? Questa informazione ci aiuterà a comprendere meglio il contesto e a offrirti una risposta più precisa. Potrebbe riferirsi a diverse situazioni, quindi qualsiasi ulteriore informazione che puoi fornire sarà molto utile.
Restiamo in attesa di ulteriori dettagli da parte tua.
massi131
Post by massi131 »
ie http:// yourspace / Watchfile.zpk and generate a qr code by modifying the url as follow:
ie zpkd1:// yourspace / Watchfile.zpk
Grazie
Xphyle1971
Been thanked: 7 times
Post by Xphyle1971 »
Ok, WHERE IS BALANCE SUPPORT ON ANDROID? It's been more than 3 months since the Balance was released! The fact that this isn't working yet on Android is RIDICULOUS.
Xphyle1971 wrote: 04 Dec 2023, 12:30
We have noticed your repeated messages on the forum. While we understand your frustration, please be advised that posting the same query multiple times does not expedite the resolution process. In fact, it may hinder our ability to address other users' concerns effectively.
Regarding the Balance support for Android, we sincerely apologize for the delay. We currently do not have the Balance model available for testing, which significantly slows down our ability to add support for it. Additionally, there are known issues with the watch itself that make integration challenging. It's worth noting that this is an industry-wide challenge, as no other service has yet managed to provide support for this model.
Moreover, our operations are heavily impacted by the ongoing war in our country. It's a challenging time for us, and maintaining our project under these circumstances is a significant endeavor.
We request your understanding and patience in this matter. Rest assured, we are doing our best to provide support for more models, including Balance, as soon as feasible.
massi131
Post by massi131 »
ok.
I didn't understand this part. what is it my Web space
supersufa
Post by supersufa »
massi131 wrote: 05 Dec 2023, 08:31
ok.
I sent you a pvt... Check and tell me!
Bye
Stephthouv
Hello, Could you please explain me too?
supersufa wrote: 05 Dec 2023, 11:27
ok.
Bye
supersufa
Post by supersufa »
Stephthouv wrote: 06 Dec 2023, 07:09
ok.
Bye
Sure!!
Once you have built your WatchFace.zpk file you have to load it online....
In order to be sure that the procedure works fine you have to load the file in a webspace which provide you a direct link. For example you can create an account on Altervista, because i know that everything works without any issues...
Immagine for example that you chose Stephthouv as your nickname on Altervista.... Your loaded file could be for example http ://Stephthouv.altervista.org/WatchFace.zpk ok?
The last step is to generate a QR code... By performing this action however the QR code have to point to zpkd1: //Stephthouv.altervista.org/WatchFace.zpk
In this way, by using Zepp to scan the just generated QR code the watchface will be installed automatically....
Stephthouv
Thank you very much 🙏🏻. I'll try this.
supersufa wrote: 06 Dec 2023, 13:48
Bye
Sure!!
Return to “AmazFaces app”
