Search found 4 matches
Return
by Stas
22 Sep 2023, 19:52
Jump to forum
Jump to topic
Re: AmazFaces for Android [Support]
I have a number of different phones that I alternate between and the AMAZFACES app does not see the Balance watch on any of them, even though the watch is paired and working fine with the ZEPP app on all my phones. I think the AMAZFACES app needs to be updated to work with/support the Balance ...
by GIK-Team
30 Sep 2023, 21:03
Jump to forum
Jump to topic
Re: Amazfit Balance
Xphyle1971 wrote: 30 Sep 2023, 20:20
Yeah but on the ANDROID app, the app doesn't see the Balance at ALL. Even if you try selecting GTR 3 Pro. Even if you set the MAC address manually. It just doesn't work whatsoever.
We heard you. Repeating the same thing won't change anything. Please be patient and wait for the app update.
by GIK-Team
21 Sep 2023, 20:34
Jump to forum
Jump to topic
Re: Amazfit Balance Faces
Someone please figure it out! I've got a Balance as well since the day of release and I check here daily for "Balance" watch face category to pop up so I can start installing custom watch faces!
https://amazfitwatchfaces.com/gtr/fresh?compatible=GTR_3_Pro They are identical, just use GTR 3 Pro ...
by Rlh1963
24 Sep 2023, 20:16
Jump to forum
Jump to topic
Strange, I use the application for Android and it doesn't have the option to choose the Balance. It also won't let me sync any watch faces from the GTR 3 Pro for my balance
