• 管理员
版面规则
头像
lumenvindex
Has thanked: 2 time
Been thanked: 49 time
联系:
帖子 lumenvindex »
Download WF_Builder 1.0.4
Changelog
代码: 全选
1.0.4
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
上次由 lumenvindex 在 12 8月 2020, 15:42,总共编辑 13 次。
MESS WITH THE BEST
DIE LIKE THE REST
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
anhtu7596 写了: 26 7月 2020, 18:26
Please create a tool like this for miband5
Unfortunately I don't have a MiBand5. Cannot develop a program without testing.
MESS WITH THE BEST
DIE LIKE THE REST
Mellifluous
来自: New York , US
Has thanked: 4 time
联系:
帖子 Mellifluous »
Thanks really helpful!
Please make a tool for Mi band 5 or NFC version generator.
Thanks.
Scorpion2185
来自: Planet Earth
联系:
帖子 Scorpion2185 »
Can you make a linux version? It works bad with wine.
anhtu7596
来自: Hà Nội
联系:
帖子 anhtu7596 »
lumenvindex 写了: 27 7月 2020, 15:53
I think you should create a link so people donate you 👍🏻
Scorpion2185
来自: Planet Earth
联系:
帖子 Scorpion2185 »
How can I at least open the .bin files on linux? I should be able to change the background image, right?
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
Scorpion2185 写了: 30 7月 2020, 18:24
Unfortunately, It's written on AutoIt, Windows-only.
MESS WITH THE BEST
DIE LIKE THE REST
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
Scorpion2185 写了: 31 7月 2020, 17:47
I think there was a linux version of MiBandWFTool. Try asking here.
MESS WITH THE BEST
DIE LIKE THE REST
jack.y.biton
来自: Isral
联系:
帖子 jack.y.biton »
Hi friends how can I make them see the months by name and not by number
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
jack.y.biton 写了: 03 8月 2020, 16:14
Download and unpack a watchface with that feature, explore the pictures, pay attention to the options of the Month section. It's easy to understand but it's hard to explain ;)
MESS WITH THE BEST
DIE LIKE THE REST
GodMutant
来自: Porto Alegre
联系:
帖子 GodMutant »
I use the web site virus total this WF_Builder1.0.4.exe is full of virus
i . p o s t i m g . c c / v m 4 k b T b J / v v v . j p g
jack.y.biton
来自: Isral
联系:
帖子 jack.y.biton »
Did not understand I want to make the months not in number but in letters
jack.y.biton
来自: Isral
联系:
帖子 jack.y.biton »
lumenvindex 写了: 03 8月 2020, 18:14
Did not understand I want to turn the months into letters not numbers
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
GodMutant 写了: 04 8月 2020, 02:06
READ the original post.
MESS WITH THE BEST
DIE LIKE THE REST
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
jack.y.biton 写了: 04 8月 2020, 04:10
Mi Band 4 firmware doesn't have this feature. You can only do this by using special trick with numbers pictures. Unpack, explore, get your brain twisted a little.
MESS WITH THE BEST
DIE LIKE THE REST
Adore_able
来自: New York , Manhattan
Been thanked: 6 time
联系:
帖子 Adore_able »
Can we turn weather or PAI on Mi band 4 dial ? Those this program enables these . And lastly can we translate language , for example English to Chinese , herbrew ,and Czech
Thank you
Regards
Adore_able
Inspiring great affection and delight
urieleugenio
来自: Madrid
Has thanked: 6 time
Been thanked: 7 time
联系:
帖子 urieleugenio »
Adore_able 写了: 04 8月 2020, 11:54
Thank you
Regards
Adore_able
I had read weather doesn't works on the MB4, I never really tried it. As for PAI, MB4 doesn't have PAI function (or at least mine it didn't until I gave it away a couple weeks ago), so you won't get the data input from the band.
As far as I know, translation is done by creating additional images (for day of the week or any other text image component), one set for each language. I'm not sure how to code for language, though. An easy fix would be to just make a different version for each language, swapping language images, so that you don't need to change the code.
GodMutant
来自: Porto Alegre
联系:
帖子 GodMutant »
Can you share the source code to we compile the software ?
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
GodMutant 写了: 09 8月 2020, 01:30
I would like not to share this embarrassing code :|
Why do you want to compile it yourself?
MESS WITH THE BEST
DIE LIKE THE REST
GodMutant
来自: Porto Alegre
联系:
帖子 GodMutant »
I want to make a online BUILDER using html and css and boorstrap so i want to use your code to learn about mi band 4 it is the best way.
All codes are some form of art I would never criticize your code.
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
GodMutant 写了: 10 8月 2020, 05:42
Answered in PM.
MESS WITH THE BEST
DIE LIKE THE REST
okniwt
来自: GER
联系:
帖子 okniwt »
Hey Guys,
i cant download the builder. This Website tells me that the maximum limit of downloads is reached.
Please reup Version 1.0.4
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
okniwt 写了: 12 8月 2020, 11:05
Hey Guys,
Done. Thanks for noticing.
MESS WITH THE BEST
DIE LIKE THE REST
Vansh Rathore
来自: India
联系:
帖子 Vansh Rathore »
Can we make a mi band 5 watchface for mi band 4 by resizeing it from 16 bit to 8 bit
头像
lumenvindex
Has thanked: 2 time
联系:
帖子 lumenvindex »
Vansh Rathore 写了: 14 8月 2020, 05:21
No. I think 16 and 8 bit is about colours, not size. Watchfaces for Mi Band 5 have different structure.
MESS WITH THE BEST
DIE LIKE THE REST
Lienarhba
来自: Ukraine
联系:
帖子 Lienarhba »
Hi lumenvindex , this program is really awesome . I have downloaded it a week ago , I was changing the parameters of my watchface . Suddenly , by my silly mistake , this program file was deleted from my windows 7+ .
My all works were reseted . Now I have left about that watchface . So, now I tried to again download the file , it says " the maximum number of downloads has reached" .
Please help me to download it again
Thanks .
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 3 访客
