lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
anhtu7596 wrote: 26 Jul 2020, 18:26
Please create a tool like this for miband5
Unfortunately I don't have a MiBand5. Cannot develop a program without testing.
MESS WITH THE BEST
DIE LIKE THE REST
Mellifluous
Post by Mellifluous »
Thanks really helpful!
Please make a tool for Mi band 5 or NFC version generator.
Thanks.
Scorpion2185
Post by Scorpion2185 »
Can you make a linux version? It works bad with wine.
anhtu7596
Post by anhtu7596 »
lumenvindex wrote: 27 Jul 2020, 15:53
I think you should create a link so people donate you 👍🏻
Scorpion2185
How can I at least open the .bin files on linux? I should be able to change the background image, right?
lumenvindex
Scorpion2185 wrote: 30 Jul 2020, 18:24
Unfortunately, It's written on AutoIt, Windows-only.
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
Scorpion2185 wrote: 31 Jul 2020, 17:47
I think there was a linux version of MiBandWFTool. Try asking here.
MESS WITH THE BEST
DIE LIKE THE REST
jack.y.biton
Post by jack.y.biton »
Hi friends how can I make them see the months by name and not by number
lumenvindex
jack.y.biton wrote: 03 Aug 2020, 16:14
Download and unpack a watchface with that feature, explore the pictures, pay attention to the options of the Month section. It's easy to understand but it's hard to explain ;)
MESS WITH THE BEST
DIE LIKE THE REST
GodMutant
Post by GodMutant »
I use the web site virus total this WF_Builder1.0.4.exe is full of virus
i . p o s t i m g . c c / v m 4 k b T b J / v v v . j p g
jack.y.biton
Did not understand I want to make the months not in number but in letters
jack.y.biton
lumenvindex wrote: 03 Aug 2020, 18:14
Did not understand I want to turn the months into letters not numbers
lumenvindex
GodMutant wrote: 04 Aug 2020, 02:06
READ the original post.
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
jack.y.biton wrote: 04 Aug 2020, 04:10
Mi Band 4 firmware doesn't have this feature. You can only do this by using special trick with numbers pictures. Unpack, explore, get your brain twisted a little.
MESS WITH THE BEST
DIE LIKE THE REST
Adore_able
Been thanked: 6 times
Post by Adore_able »
Can we turn weather or PAI on Mi band 4 dial ? Those this program enables these . And lastly can we translate language , for example English to Chinese , herbrew ,and Czech
Thank you
Regards
Adore_able
Inspiring great affection and delight
urieleugenio
Been thanked: 7 times
Post by urieleugenio »
Adore_able wrote: 04 Aug 2020, 11:54
Thank you
Regards
Adore_able
I had read weather doesn't works on the MB4, I never really tried it. As for PAI, MB4 doesn't have PAI function (or at least mine it didn't until I gave it away a couple weeks ago), so you won't get the data input from the band.
As far as I know, translation is done by creating additional images (for day of the week or any other text image component), one set for each language. I'm not sure how to code for language, though. An easy fix would be to just make a different version for each language, swapping language images, so that you don't need to change the code.
GodMutant
Post by GodMutant »
Can you share the source code to we compile the software ?
lumenvindex
GodMutant wrote: 09 Aug 2020, 01:30
I would like not to share this embarrassing code :|
Why do you want to compile it yourself?
MESS WITH THE BEST
DIE LIKE THE REST
GodMutant
Post by GodMutant »
I want to make a online BUILDER using html and css and boorstrap so i want to use your code to learn about mi band 4 it is the best way.
All codes are some form of art I would never criticize your code.
lumenvindex
GodMutant wrote: 10 Aug 2020, 05:42
Answered in PM.
MESS WITH THE BEST
DIE LIKE THE REST
okniwt
Post by okniwt »
Hey Guys,
i cant download the builder. This Website tells me that the maximum limit of downloads is reached.
Please reup Version 1.0.4
lumenvindex
okniwt wrote: 12 Aug 2020, 11:05
Hey Guys,
Done. Thanks for noticing.
MESS WITH THE BEST
DIE LIKE THE REST
Vansh Rathore
Post by Vansh Rathore »
Can we make a mi band 5 watchface for mi band 4 by resizeing it from 16 bit to 8 bit
lumenvindex
Vansh Rathore wrote: 14 Aug 2020, 05:21
No. I think 16 and 8 bit is about colours, not size. Watchfaces for Mi Band 5 have different structure.
MESS WITH THE BEST
DIE LIKE THE REST
Lienarhba
Post by Lienarhba »
Hi lumenvindex , this program is really awesome . I have downloaded it a week ago , I was changing the parameters of my watchface . Suddenly , by my silly mistake , this program file was deleted from my windows 7+ .
My all works were reseted . Now I have left about that watchface . So, now I tried to again download the file , it says " the maximum number of downloads has reached" .
Please help me to download it again
Thanks .
