SupportUkraine
1.0.4
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
WF_builder allows you to change all known parameters of a watchface. It shows how watchface will look like with different data on it. Program uses Mi Band 4 WF Tool for packing\unpacking watchfaces and has it inside Lib subdirectory. Lots of thanks to @lvpokka for this tool. Previous versions
Virus?
Hi friends how can I make them see the months by name and not by number
Download and unpack a watchface with that feature, explore the pictures, pay attention to the options of the Month section. It's easy to understand but it's hard to explain
Did not understand I want to turn the months into letters not numbers
Mi Band 4 firmware doesn't have this feature. You can only do this by using special trick with numbers pictures. Unpack, explore, get your brain twisted a little.
Can we turn weather or PAI on Mi band 4 dial ? Those this program enables these . And lastly can we translate language , for example English to Chinese , herbrew ,and Czech
Thank you
Regards
Adore_able
Thank you
Regards
Adore_able
I had read weather doesn't works on the MB4, I never really tried it. As for PAI, MB4 doesn't have PAI function (or at least mine it didn't until I gave it away a couple weeks ago), so you won't get the data input from the band.
As far as I know, translation is done by creating additional images (for day of the week or any other text image component), one set for each language. I'm not sure how to code for language, though. An easy fix would be to just make a different version for each language, swapping language images, so that you don't need to change the code.
Hi lumenvindex , this program is really awesome . I have downloaded it a week ago , I was changing the parameters of my watchface . Suddenly , by my silly mistake , this program file was deleted from my windows 7+ .
My all works were reseted . Now I have left about that watchface . So, now I tried to again download the file , it says " the maximum number of downloads has reached" .
Please help me to download it again
Thanks .
Cookie Consent
