lumenvindex
Been thanked: 49 times
Post by lumenvindex »
Download WF_Builder 1.0.4
Changelog
1.0.3
1.0.2
1.0.1
1.0.0
0.9.8
Fixed some bugs
0.9.7
0.9.6
Previous versions
1.0.3
Recommendations
Virus?
MESS WITH THE BEST
DIE LIKE THE REST
Dandow
Post by Dandow »
That's awesome!
Thanks a lot, i'll test it today.
I was wondering, did you contemplated "gif"?
lumenvindex
Dandow wrote: 09 Sep 2019, 12:44
That's awesome!
Not sure what you mean by that. You would like to see a feature of saving animated GIF from preview? But Mi Band 4 WF Tool already make gif file every time you pack a watchface.
MESS WITH THE BEST
DIE LIKE THE REST
lazimk
Post by lazimk »
Great! I will try this. I found this on 4PDA.
It was in Russian. So i was about to request to translate that into English.
Thanks for sharing this here
-Laz
*Have a great day*
Dandow
Post by Dandow »
lumenvindex wrote: 09 Sep 2019, 13:14
That's awesome!
Like this pip boy
https://amazfitwatchfaces.com/mi-band-4/view/5300
lumenvindex
Dandow wrote: 09 Sep 2019, 16:41
Like this pip boy
Still don't understand you. At all. Give me some more detailed explanation.
MESS WITH THE BEST
DIE LIKE THE REST
Dandow
Post by Dandow »
lumenvindex wrote: 09 Sep 2019, 18:16
When you open the json you se that pipboy has a sequence of images, its not static.
I couldn't try it yesterday but i'm gonnna play a bit today 🤭
lumenvindex
Dandow wrote: 10 Sep 2019, 08:50
You're asking whether program can or cannot add Animation block to config? Sure it can! I even made my own variant of Pip-boy watchface with this program.
MESS WITH THE BEST
DIE LIKE THE REST
Menpanda
Post by Menpanda »
Hello, I would like to learn how to make my own animated mi band 4 watch faces, is there any tutorial to use this tool? I tried to convert a gif int a APNG but it didn't work. Could someone please help me?
lumenvindex
Menpanda wrote: 10 Sep 2019, 21:19
There are no tutorials about this program as far as I know. To add animation you need to split your gif file into a set of png frames (I used "ezgif" service for that). Then open needed watchface in WF_Builder, turn on the Animation block and choose all png files of the set. Than you should change X and Y parameters to place the animation on the watchface.
Unfortunately there is no easy way to adjust animation speed - the Speed parameter should be larger than 4 (otherwise the animation won't play on the device with the latest firmware), but large values cause animation blinking. Probably you'll have to adjust the speed by changing the amount of frames.
Don't forget to cut off all unnessesary pixels from the frames and use Palette mode to pack a watchface. Your bin file shouldn't exceed 320 Kb size to be successfully uploaded to Mi Band.
MESS WITH THE BEST
DIE LIKE THE REST
Dandow
Post by Dandow »
Is it not possible to put months as letters instead of numbers? I mean, I try writting in the json to count 12 images instead of 10, but seems to reestart at the 10th
lumenvindex
Dandow wrote: 11 Sep 2019, 19:31
Mi Band uses these images as digits only. Therefore it recieves only 10 images.
But you can unpack some watchface with "months as letters" and see how it could be done. Watch out, don't twist your mind. :D
MESS WITH THE BEST
DIE LIKE THE REST
sachann
Post by sachann »
it is possible. I have my watchface modified to have months as text instead of nubers.
I only use the short form of the month but full month is also possible with all 12 names.
have a look at my thread: viewtopic.php?f=62&t=828&p=2477#p2477
Miro
Post by Miro »
You achieve that with the latest firmware ?
Is the MIBand4 App still work to add custom WF in Mi Fit ?
I can't get my watchfaces to work anymore ..
Navajoa
Post by Navajoa »
great Tool, but there is one problem. I opened .json, Add status "Do Not Disturbe", and PNG. When I create the new .json and will create an new .bin with Mi Band WF Tool V4 I get some errors.
When I edit the existing original .joson with hand, I can create the .bin without problems.
Kind Regards,
Navajoa
lumenvindex
Navajoa wrote: 13 Sep 2019, 08:21
Could you provide me with your json so I could see what's the problem? When editing json by hand, you still can pack it using WF Tool 1.4.0?
MESS WITH THE BEST
DIE LIKE THE REST
lumenvindex
Uploaded new version of WF_Builder (0.9.6) to fix a bug reported by Navajoa. Some other optimizations were also made.
MESS WITH THE BEST
DIE LIKE THE REST
ypiripillo
Post by ypiripillo »
there's a virus in WF_Builder0.9.6.zip
detected by standard Windows 10 antivirus and confirmed by virustotal
lumenvindex
ypiripillo wrote: 20 Sep 2019, 08:30
There is a "Virus?" spoiler in the first post. Thanks for your attentiveness. VirusTotal score is 11 of 62, by the way. :evil:
Of course it's up to you whether you use this program or not. I can even send you my sources, if you need it.
MESS WITH THE BEST
DIE LIKE THE REST
user839
Post by user839 »
Where is the download link?
Has thanked: 1162 times
Been thanked: 279 times
user839 wrote: 22 Sep 2019, 08:58
Soon, in the first message. We have technical problems that we will solve shortly.
lumenvindex
Lots of changes in new WF_Builder 0.9.7. Get it from the link in the first post.
MESS WITH THE BEST
DIE LIKE THE REST
phamaral
Post by phamaral »
Any tips for making watchfaces with gifs? I had to get rid of LOTS of frames to make is fit in the 320kb limit, tried compressing the PNGs but it makes no difference. Now I have 10 frames, and they play way too fast. Anything I can try to fix this?
lumenvindex
The larger animation frames weight the slower animation is. Palette packing makes smaller frames. I'm afraid there is no silver bullet for making long calm animations in a watchface. At least for now. Just try to find some balance between size and speed.
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Has thanked: 11 times
Post by mysiak »
lumenvindex wrote: 22 Sep 2019, 11:48
Thanks for the update. I see only LIB subfolder, without actual WF_Builder0.9.7.exe executable in the archive. Did I miss something? :)
