Messaggio da SashaCX75 »
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Ultima modifica di SashaCX75 il 01 giu 2022, 07:19, modificato 32 volte in totale.
y.ertanc65
Messaggio da y.ertanc65 »
Hello Sasha,
I have downloaded an interface from AndiL ( https://amazfitwatchfaces.com/gtr/view/13165 ) and if I use as it is, works perfectly and shows humidity on the watch (GTR 2e) screen. But if I import it to editor V2.1 it breaks "humidity" feature and I can't find a way to bring it back in JSON settings.
Do you have any solution for this problem?
Thanks in advance.
gengtrex
Messaggio da gengtrex »
SashaCX75 ha scritto: 21 apr 2021, 16:15
@gengtrex , @tlausl
i used this one, sasha.
is it a wrong one for t-rex pro?
gengtrex
Updated the file. Check now, I can't check on Trex-pro
If this does not help, then you can configure the watch face in Trex-pro mode and switch to GTR 2 before creating the bin file.
Dials created in this program do not work very well. I advise you to wait for the release of WatchFace editor 2 v.3 and make watch faces in this editor in the future.
gengtrex
SashaCX75 ha scritto: 22 apr 2021, 14:36
@gengtrex
thnx a miliion, sasha. i'll try it immediately.
Fulvio_61
Messaggio da Fulvio_61 »
Hi Sasha, maybe you know a way to open / view PPNG (Protected PNG) files? I have searched and tried different programs, but it seems impossible!
tangerinedream
Messaggio da tangerinedream »
Hi.
Thanks for the great program.
I'm having the exact same issue with a commenter just above (first comment on this page). Watch faces with 'Humidity' feature gets broken if you import it into the editor and this issue is somehow related with PAI feature aswell.
I'd like to know if you're aware of this issue or not.
Cheers.
gengtrex
latest, i use the converter (gtr-gtr2) to convert my t-rex file into t-rex pro.
it worked! but year was gone.
how can i fix it, SashaCX75 ?
thanks.
msmolinski
Messaggio da msmolinski »
I used this app to edit one of the watchfaces for GTR 2e. (gtr/view/14442)
I've got a problem. When I've installed it, it works fine but I can't access watchface settings and can't change widgets. When I access watchface changing screen and press edit button it all just freeze and nothing happens. In original watchface everything worked fine and I've changed only images and their positions in JSON file.
Also I don't understand why I don't see widgets on preview of my watchface in this editor, is there something wrong with them?
Please help.
Allegati
classic-aod-widget_pl.zip
Project files
(410.24 KiB) Scaricato 170 volte
Fulvio_61
I have not come across PPNG files
y.ertanc65 , tangerinedream
Version 2.1 does not support the Humidity parameter. This is why the dials created in this version do not have this element.
PAI should work. If this is not the case, then send the dial where it does not work, I will check.
gengtrex
When converting, not all elements work. The animation does not work exactly, year. There should only be one kind of display for the battery, otherwise it won't work. If the dial had the am / pm designations, then they must be added again.
Therefore, I did not recommend using this program.
msmolinski
The current version of the editor does not support widgets. But it should save them if you add them to json manually.
Perhaps the current version has some problems with this. Check this file.
Allegati
classic-aod-widget_pl_packed.zip
(164.12 KiB) Scaricato 160 volte
msmolinski
SashaCX75 Thanks for the info. It seems that there may be some problem with it in current version. I've checked it with another watchface and there was the same problem.
File you attached works well. Thanks for help.
Version 3.0
Found bugs fixed.
tlausl
Messaggio da tlausl »
Thanks for your new Version, works perfekt for me. Thanks a lot.
arlemm
Messaggio da arlemm »
Thank you SashaCX75 for your great work.
I wont report you that in version 2.3 (Version 3.0) when used "Random value" button in Edit mode, the current temperature data are always in "error"; in Browse mode it works properly.
arlemm
I will fix it in the next update.
An error occurs if the symbol is not specified for a weather data error. If the error occurs in some other cases, then send the dial, I will check.
arlemm
SashaCX75 ha scritto: 25 apr 2021, 05:35
@arlemm
Thank you for your answer.... I have checked and it happens with any watch face even when the symbol is specified
Allegati
big_num_IT.bin
(1.63 MiB) Scaricato 192 volte
arlemm
@SashaCX75
If you want, I could translate your program's UI into Italian (from English ;) :D).
Titchy2005
Messaggio da Titchy2005 »
Are shortcuts like on the GTS available for GTS2 watchfaces?
spidercrab
Has thanked: 27 times
Messaggio da spidercrab »
SashaCX75 In the Digital time settings, what does the "Unit" refer to? Also does this need to be set?
I am debugging a V3 face and I have not set the Unit Index image, but I notice that in the ...packed.log that the value of 28 has been used for the Unit:
This is what I see:
"MultilangImageUnit": [
"LangCode": "All",
"ImageSet": {
"ImageIndex": 28,
"ImagesCount": 1
My last image is 0028.png.
Ultima modifica di spidercrab il 25 apr 2021, 14:37, modificato 1 volta in totale.
Titchy2005
Not. Officially, they are there, but they don't work.
spidercrab
The names in the editor and inside the json file are not always the same. In this case, in the editor, this parameter is called "Separator"
Kifrawi
Messaggio da Kifrawi »
Weather > Current Temperature > Error
spidercrab
SashaCX75 I just wanted to say a huge thank you for the V3 Editor that now supports the T-Rex Pro. It works perfectly for me and there are a lot of cool new features compared to using the original GTR Editor.
To my surprise, you can add several custom WF's to the T-Rex Pro and choose them from the watch, which I was not expecting.
NuttyS
Messaggio da NuttyS »
SashaCX75 ha scritto: 12 apr 2021, 07:55
Not all elements work after conversion. Of the advantages of such dials, I consider only working labels and the ability to set different fonts and independent coordinates for tens and units in time.
I’m so sorry to be a pest, but I’m new to this bit, I can’t work out how to convert a gtr face to work on a gtr 2e. That’s what this is for right? But I can’t figure it out.
I assumed it would be the convert bit, but there’s no gtr 2e.
Ultima modifica di NuttyS il 28 apr 2021, 12:30, modificato 2 volte in totale.
Torna a “Watchfaces tools”
