gengtrex
Updated the file. Check now, I can't check on Trex-pro
If this does not help, then you can configure the watch face in Trex-pro mode and switch to GTR 2 before creating the bin file.
Dials created in this program do not work very well. I advise you to wait for the release of WatchFace ...
Пошук дав 3 результатів
- 22 квітня 2021, 14:36
- Jump to forum
- Jump to topic
- 23 квітня 2021, 15:50
- Jump to forum
- Jump to topic
gengtrex
When converting, not all elements work. The animation does not work exactly, year. There should only be one kind of display for the battery, otherwise it won't work. If the dial had the am / pm designations, then they must be added again.
Therefore, I did not recommend using this program.
- 24 квітня 2021, 14:29
- Jump to forum
- Jump to topic
Version 3.0
Added support for T-Rex Pro.
Found bugs fixed.
Found bugs fixed.
