Messaggio da SashaCX75 »
Guydu91
Has thanked: 58 times
Messaggio da Guydu91 »
Emiliomc ha scritto: 08 nov 2025, 18:02
I'm starting a new watchface project. It's analog. I had the idea that the watchface could display 12, 6, and 9 when the watch is in 24-hour mode. And when I select 12-hour mode on the watch, the face would display 12, 6, and 9 in the morning and 24, 18, and 21 in the evening. I've been researching whether this is possible directly in the SashaCX75 application, or if it requires modifying the index.js file, or if it's simply not possible. Currently, I have two identical watch faces, one with 12, 6, and 9, and the other with 24, 18, and 21. I've looked into Analog Time Pro, specifically activating "24-hour format" (which I don't understand), and adding the second watch face as a foreground image on the hour hand. I've also checked if the solution was in "Switchable Background." Ultimately, I don't know if this is possible at all.
Hi Emilio,
I think you can simply create three different backgrounds:
1) the usual background (12, 3, 6, 9)
2) an identical background, possibly adding an AM indicator
3) a background (24, 15, 18, 21), possibly adding an PM indicator
The idea:
Create a digital clock where only the AM and PM information is visible.
The AM widget corresponds to background 1.
The PM widget corresponds to background 2.
In Sasha's editor, the digital clock would then be placed just above the standard background, and the other information would be above the digital clock.
This configuration should therefore produce a display that suits your needs.
Best regards,
Guy.
Emiliomc
Messaggio da Emiliomc »
The solution of creating three watch faces works perfectly. One standard face with 12, 3, 6, and 9 when the clock is in 24-hour mode. And two watch faces for when the clock is in 12-hour mode. One AM face with 12, 3, 6, and 9. And another face with 24, 15, 18, and 21. These last two are in the AM and PM sections of "Digital Time." It's a very logical and simple solution. I know how the AM and PM sections work, but it never occurred to me to apply them to analog time. I was mistakenly convinced that these sections only corresponded to digital time, and I didn't think about it further. Furthermore, I didn't consider that if they only corresponded to digital time and required digits, I could add them even if they were transparent. In short, the solution is quite simple, but I didn't think about it enough. Thank you very much.
Emiliomc
How can I change the progress circle parameters for heart rate data using the latest SashaCX75 app update (15.1)? Currently, at least in my case, the progress circle starts counting from 32 bpm up to 184 bpm. I would like it to count from 0 bpm up to 140 bpm. In previous versions of the app, it was possible to modify the values ​​in the generated index.js file, but now I don't know how to do it, or if it's even possible.
frankh93
Has thanked: 24 times
Messaggio da frankh93 »
If I understand correctly, you can do that detecting first the clock format the watch is using (12H/24H) so based on this use one or other set of images for bg images. This can't be done on the editor, you need to code a bit to get it working
Emiliomc ha scritto: 19 nov 2025, 17:48
Currently, a standard widget is used for the progress bar, and its behaviour depends on the system settings.
You can enable scale inversion. Then the code will be similar to what it was before. You can edit it and write the limits within which the progress bar will work yourself.
Emiliomc
Thanks, Sasha. I think I understand what you're saying. I've been trying what you suggested, then editing the index file. In the edit, I also replaced the value 184 in the `valueHeartRate` function with 140. And I want the starting value to be 0. That's where I think I'm getting lost... In `let progressHeartRate = (valueHeartRate - 30)/(targetHeartRate - 30);` I replaced the 30s with 1s, but it's not working. My idea is that the progress bar starts at 1 and ends at 140.
@Emiliomc
I think the code should be something like this.
Codice: Seleziona tutto
                let valueHeartRate = heart_rate.last;
                let targetHeartRate = 200;
                let progressHeartRate = valueHeartRate/targetHeartRate;
                if (progressHeartRate < 0) progressHeartRate = 0;
                if (progressHeartRate > 1) progressHeartRate = 1;
                let progress_cs_normal_heart_rate = progressHeartRate;
targetHeartRate = 200 - This is the maximum value for progress. You can change it to whatever suits you best.
Emiliomc
I've been testing a heart rate progress circle, aiming to measure values ​​from 0 bpm to 100 bpm, with a maximum of 100 bpm. I tried modifying the code in the watchface's index file for the inverted progress circle, replacing it with the code (which I believe is correct) for a non-inverted progress circle. I also added the information I think I understood. The only difference is that instead of a maximum of 200, I set it to 100. And, for example, at 65 bpm, the progress circle only expands by about 25%. Even replacing the value of 100 in the code with 200 produces the same result. I'm definitely doing something wrong.
//dynamic modify start
        let normal_background_bg = ''
        let normal_heart_rate_circle_scale_2 = ''
        let normal_heart_rate_text_font = ''
        //dynamic modify end
        __$$module$$__.module = DeviceRuntimeCore.WatchFace({
            init_view() {
            console.log('Watch_Face.ScreenNormal');
            normal_background_bg = hmUI.createWidget(hmUI.widget.FILL_RECT, {
              x: 0,
              y: 0,
              w: 480,
              h: 480,
              color: '0xFF000000',
	normal_heart_rate_circle_scale_2 = hmUI.createWidget(hmUI.widget.ARC_PROGRESS, {
              center_x: 230,
              center_y: 232,
              start_angle: 0,
              end_angle: 360,
              radius: 68,
              line_width: 5,
              corner_flag: 0,
              type: hmUI.data_type.HEART,
              color: 0xFFFF8C00,
              // mirror: False,
            normal_heart_rate_text_font = hmUI.createWidget(hmUI.widget.TEXT_FONT, {
              x: 158,
              y: 209,
              w: 150,
              h: 80,
              text_size: 30,
              char_space: 0,
              color: 0xFFFFFFFF,
              line_space: 0,
              align_v: hmUI.align.TOP,
              align_h: hmUI.align.CENTER_H,
console.log('Watch_Face.ScreenAOD');
            function scale_call() {
              console.log('scale_call()');
                console.log('update scales HEART');
                let targetHeartRate = 100;
                let progress_cs_normal_heart_rate = 1 - progressHeartRate;
                  // normal_heart_rate_circle_scale_2
                  let level = Math.round(progress_cs_normal_heart_rate * 100);
                  if (normal_heart_rate_circle_scale_2) {
                    normal_heart_rate_circle_scale_2.setProperty(hmUI.prop.MORE, {
                      center_x: 230,
                      center_y: 232,
                      start_angle: 0,
                      end_angle: 360,
                      radius: 68,
                      line_width: 5,
                      corner_flag: 0,
                      color: 0xFFFF8C00,
                      level: level,
              resume_call: (function () {
                console.log('resume_call()');
                scale_call();
            onInit() {
                logger.log('index page.js on init invoke');
            build() {
                this.init_view();
                logger.log('index page.js on ready invoke');
            onDestroy() {
                heart_rate.removeEventListener(heart.event.CURRENT, hrCurrListener);
                logger.log('index page.js on destroy invoke');
} catch (e) {
    console.log('Mini Program Error', e);
    e && e.stack && e.stack.split(/\n/).forEach(i => console.log('error stack', i));
You are doing it incorrectly. If you had done as I advised, there would be no line in your code.
Emiliomc
Sasha, I think I'm going to have to give up. I thought I understood what you said, but apparently not. Everything would be easier with a progress bar that could be easily configured to display the data each user wanted. That's just my humble opinion. I'll have to abandon the project.
hoa.snowboy
Messaggio da hoa.snowboy »
Hello @SashaCX75, I would appreciate it if you could add a Calendar event widget for display on the watch face. Thank you for considering this enhancement.
@hoa.snowboy
I don't know how to display calendar events on the watch face. Officially, there is no such option in the documentation. However, there are official watch faces that can do something similar.
dave_dophin
Messaggio da dave_dophin »
Hi, is there link any guide or similar how to start with this tool? Thx!
rush2112
Has thanked: 119 times
Messaggio da rush2112 »
@SashaCX75
Good morning ,
I want to ask something when a created a face watch. Is there a trick or a different way to do that? When a created a battery progress, I want to make the progress bar show 100%. I don’t want to put the exact percentage number, just the bar. Sometimes, I temporarily put the number to check, but it takes me about 8 minutes to set it exactly at 100%.
Can you tell me a trick or a better method? I need help. Thanks!
@rush2112
Do you want the icon to be displayed only when the charge is 100%? The easiest way to do this is with code.
You can also try to set only two images to show the charge progress. But I'm not sure if that will work.
rush2112
SashaCX75 ha scritto: 21 dic 2025, 15:41
@rush2112
Do you know of any trick to quickly set the battery progress bar to 100%? It usually takes me about 8 minutes to get it exactly right, and I’m wondering if there's a faster way.
Look at the Att ( battery ) on the face watch . Thanks
Link : https://amazfitwatchfaces.com/balance/view/5824
Wishing you a Merry Christmas and a Happy New Year!
@rush2112
I don't understand what you want. Do you need to set the battery value to 100% in the editor? It can be done in a few clicks.
rush2112
Yes, with the progress bar, I do have to look at the numbers to reach 100% before setting the progress bar in the battery 🔋 icon, with your editor.
frankh93
rush2112 ha scritto: 21 dic 2025, 20:01
I think you mean to get the progressbar in the right position and size you want right? if so you can open the "data for preview" tab and under the system section set the battery to 100, then you could draw the batterybar knowing the values you set (coordinates, lenght, width) is for the full progressbar.
Other way you could get this (which I personally do) is to "draw" the progressbar in an images editor (photoshop in my case) and once you get it there just copy the values. Taking your project as example:
You can use the values given (width, height, coordinates) to set them in the watchfaces editor (as I said before, these will be for the full progressbar), this way you should be able to get it done quickier
rush2112
frankh93 ha scritto: 21 dic 2025, 22:23
Thanks Buddy ,
Thank you for your help, that was exactly what I was trying to find. Thanks again!
Version 16.0
Sleep widget added.
Text widgets added (display of custom text).
Version 16.0
Archive
Installer
XiaomiFan
Messaggio da XiaomiFan »
Hi Sasha,
Thanks for the great editor. It works wonderfully. However, after creating my first watch face, I'm having trouble figuring out how to get it onto my watch. In my Zepp app, under developer options, the only option is to upload the watch face using a QR code.
Or have I overlooked something in the editor?
Been thanked: 2122 times
Messaggio da asoo »
XiaomiFan ha scritto: 05 gen 2026, 08:17
Hi Sasha,
This program is used to edit and modify watch faces for devices running ZeppOS. The program does not have an option to install watch faces into your watch.
For instructions on installing your custom watch faces onto your watch, I recommend referring to this article; it should be helpful for you.
sxtywzc0408
Messaggio da sxtywzc0408 »
"Hey Master, could you please add the Chinese Lunar Calendar?"
Torna a “Watchfaces tools”
