Messaggio da SashaCX75 »
Frv100
Using the editor, you can only extract images from this watch face. If you need to change the code in the index.js file then just extract this file from the archive.
Version 3.0
kotobuki09
Messaggio da kotobuki09 »
Hi guys! Is there an easier way to make convert the GTR2 watch face for GTR3/3 Pro wfs ?
bartekmatuszewski
Messaggio da bartekmatuszewski »
Hello SashaCX75. Thank you for your work. It's brilliant to see v3 of your editor.
Where could I find hunami framework functions documentation? I guess you know the answer.
Frv100
Messaggio da Frv100 »
SashaCX75 ha scritto: 18 feb 2022, 16:02
@Frv100
Thanks.
I try and can read the index.js file but what's inside is beyond my skills :?
good job with the v3 !
bartekmatuszewski ha scritto: 21 feb 2022, 15:35
You can find documentation here https://docs.huami.com/
blazzy96
Messaggio da blazzy96 »
Hello do you know how to make smooth seconds animation on gts 3? instead of ticking I want it sweeping
NickGrabowsky
Messaggio da NickGrabowsky »
Hi!
I would like to create a counterclockwise thermometer dial. (weather.temperature img_pointer)
Could someone give some hints how to do this in JS?
NickGrabowsky
I'm not sure this is possible.
I tried using img_pointer for temperature, but the pointer displays random data.
You can use JS to get temperature data and, depending on this data, set the angle of rotation of the pointer. But in this way you can not get data for the current temperature, only about the maximum and minimum temperatures. How to get temperature data can be read here. https://docs.zepp.com/docs/watchface/ap ... d/WEATHER/
jerrywm2
Messaggio da jerrywm2 »
Hi SashaCX75! Thank you for all of the new features in version 3.0. Everything is working great for me other than sunrise/sunset times. This works on other faces I have downloaded, but when I create one with your tool, it always shows 0 (zero) for sunrise and sunset. Any ideas? Thanks again!
jerrywm2
This can happen if the separator is not set
jerrywm2
Thank you! That worked perfectly. I noticed it was the same with the humidity as well, in case anyone else runs into this.
rondolfo
Messaggio da rondolfo »
Hey Sasha, I hope you stay safe amidst whatever madness and carnage the Kremlin nutjob and his psycho henchmen inflict on Ukraine. You are a beacon of light in an appalling world!
Guydu91
Has thanked: 58 times
Messaggio da Guydu91 »
Hi Sasha,
Many thanks for all you have done so far.
Now, we can understand that you don't have much time to take care of the development of the editor for GT3 (or other).
Be careful.
Good luck.
Friendships from France.
amazfit@hw
Messaggio da amazfit@hw »
Hello SashaCX75 keep safe and thank you for your excellent tools to help us focus on creating dials for ourself and the GTR 3 community.
From SE Asia
Thank you all for your experiences. I hope all this ends soon. But now the situation in the country is complicated and it is not known what will happen next.
bvannier
Has thanked: 10 times
Messaggio da bvannier »
Dear Sasha,
So sorry for what is going on in your beloved country. DO take precious care of yourself and everybody in your heart.
don1yoor
Messaggio da don1yoor »
How to install watchface when i create watchface. I have only ios phone. Amaztools not working with GT3. Guys please help me....(((
Mirac1453
Messaggio da Mirac1453 »
Will there be a version for the GTS 2 mini 2?
FeRu
Has thanked: 14 times
Been thanked: 8 times
Messaggio da FeRu »
Could someone tell me how rotate day numbers by angle of 30 or 40 degrees? What I need to change or add in index.js script in this section?
"elementName": "DateDay",
"visible": true,
"Pointer": {
"position": 2,
"visible": false,
"show_level": "",
"center_x": 0,
"center_y": 0,
"pos_x": 0,
"pos_y": 0,
"start_angle": 0,
"end_angle": 360,
"cover_x": 0,
"cover_y": 0,
"scale_x": 0,
"scale_y": 0
"Number": {
"position": 1,
"visible": true,
"align": "CENTER_H",
"show_level": "",
"imageX": 319,
"imageY": 42,
"space": 2,
"zero": true,
"img_First": "d01",
"unit": "",
"imperial_unit": "",
"icon": "",
"iconPosX": 0,
"iconPosY": 0,
"invalid_image": "",
"dot_image": "",
"follow": false
asoo Do you know some magic tricks how to do that? :D
Been thanked: 2122 times
Messaggio da asoo »
FeRu ha scritto: 22 mar 2022, 16:29
@asoo Do you know some magic tricks how to do that? :D
You mean showing the letters on the circumference?
if yes can not edit in .json if you would like to make it. you must to manual edit on index.js by use custom script , in my work use I use custom script by SashaCX75 but i am not sure in that scrip is 30 or 40 degrees or not. If you want the sample script to study you can download the attachment .
script_show_angle_step_and_day.txt
(6.47 KiB) Scaricato 379 volte
Example watchface :
https://amazfitwatchfaces.com/gtr/view/20048
But if you mean to tilt the text by degrees. As far as I know, I've never been see a script like that.
ิีBut you can make it by built image font and use coordinates and spacing to make it.
Example watchface :
https://amazfitwatchfaces.com/gtr/view/20494
FeRu
Messaggio da FeRu »
Thanks asoo for reply. I never thought that this will need more than simply add some lines. But I saw taht you was able little rotate days in G290 watchface but I don't know how make something similar in this case....
I send you in attachment watchface wich I made, It's modified G290 and I want make day rotated to right to be something aligned with week day and months. Could you help me with this?
Allegati
F290 PL.zip
(430.18 KiB) Scaricato 374 volte
Messaggio da asoo »
FeRu
G290_FAOD_Yellow2_GTR3_GTR_3_Pro.zip
(395.42 KiB) Scaricato 368 volte
This watchface make it by built image font and use coordinates and spacing to make Font's degrees
This watchface can open and edit by use "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)"
FeRu
Messaggio da FeRu »
Thank you so much @asoo. I also started working with the same idea like in G33....I thought that it will be some other simple solution to rotate numbers but this works fine. Anyway now I know what to do thanks to you.
flabross
Messaggio da flabross »
Hello, please if you have any more programs for this gtr3 pro face creator, post here, I need more. Thanks.
Torna a “Watchfaces tools”
