I would greatly appreciate someone porting this wear os like watch face for the GTR 2/2e. They're already available on the GTR 42 and 47mm.
https://amazfitwatchfaces.com/gtr/view/8866
Thanks to anyone who can make this, or guide me on how to do this using the GTRtoGTR2 watch face editor GUI tool.
I tried converting, but it gives error saying failed to sync while installing the bin file!
Port request - 8866 for GTR 2
- Has thanked: 406 times
- Been thanked: 2031 times
if you would like to convert GTR to GTR2 I recommend to use "AmazFit_Watchface_Editor_(GTR47ToGTR2)"
viewtopic.php?p=8844#p8844
link Download : Tested on GTR2e work normal.
Thank you so much for sharing this asoo
I was trying to edit this with the GTR 2 editor (AmazFit WatchFace editor 2 for Windows), but it is giving me "unparsable" error. My goal is to customize the AOD screen, can you also help me with that?
I just tried to unpack this bin, but it gives me this exact error -
"PNG file numbering must start at 1"
and then this error [attached screenshot]
That BIN is not BIN GTR2 , it is BIN convert from GRT1 .json is still GTR1 Format if you want to edit you must to use "AmazFit_Watchface_Editor_(GTR47ToGTR2)"prostogi wrote: 19 May 2021, 05:00Spoiler
Thank you so much for sharing this @asoo
if you want to use "AmazFit WatchFace editor 2 " for modify you must make it new all , you can use only picture to create or modify , can not use .json for this BIN to create or modify
