• 管理员
版面规则
回复
头像
来自: Ukraine
Has thanked: 13 time
Been thanked: 1036 time
联系:
帖子 SashaCX75 »
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
上次由 SashaCX75 在 01 6月 2022, 07:19,总共编辑 32 次。
头像
来自: ͼͽ Thailand ͼͽ
Has thanked: 419 time
Been thanked: 2109 time
帖子 asoo »
NuttyS 写了: 28 4月 2021, 12:01
SashaCX75 写了: 12 4月 2021, 07:55
Not all elements work after conversion. Of the advantages of such dials, I consider only working labels and the ability to set different fonts and independent coordinates for tens and units in time.
I’m so sorry to be a pest, but I’m new to this bit, I can’t work out how to convert a gtr face to work on a gtr 2e. That’s what this is for right? But I can’t figure it out.
I assumed it would be the convert bit, but there’s no gtr 2e.
Your Picture is not program GTRtoGTR2
Your Picture is "AmazFit_Watchface_Editor_(GTR47ToGTR2)"
viewtopic.php?p=8844#p8844
If you want to use this program to convert GTR to GTR2/2e You can do by this step
Use button No.1 to open .BIN GTR47mm that you want to edit or convert
when finish edit use button No.2 Pack to BIN GTR2/2e
pory
来自: Italy
联系:
帖子 pory »
Sorry but i'm confused,,, which tool should i use to convert wachface from t rex in to t rex pro?
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
pory
If you only need to convert, then you can use the GTRtoGTR2 or AmazFit_Watchface_Editor_ (GTR47ToGTR2) program.
But the converted watch faces may not work properly. I recommend disassembling the dial using AmazFit_Watchface_Editor_ (GTR47ToGTR2) and re-making it with the program from the first post in this thread.
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Updated watch faces editor
Added French.
[email protected]
来自: Poland
Has thanked: 3 time
联系:
帖子 [email protected] »
I guess nobody has reported it yet? - in the AoD edit mode, the position change preview for the numerical battery value and for the battery icon does not work.
Only after using the Random preview button is the battery position updated. The problem persists in the latest version.
zyfish
来自: china
联系:
帖子 zyfish »
SashaCX75 写了: 30 4月 2021, 14:08
Added French.
gtr2e
There is still a problem with the temperature display in the middle
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
zyfish 写了: 30 4月 2021, 20:29
gtr2e
On which watch face is the problem and what is your watch firmware?
头像
JuniorPassos
来自: Brasil
Has thanked: 5 time
联系:
帖子 JuniorPassos »
Added French.
Thank you very much for the program.
If you need someone to translate into Portuguese, I'm available to help you. ;)
brain65
来自: Germany
联系:
帖子 brain65 »
I had made a Watchface for the GTR2 with the editor2. I use for the weather indicator only the "Image progress" and the "current temperature". The coordinates (x and y) of both are different, but on the watch the current temperature is displayed over the Image Icon on the xy-place of the ImageIcon.
If I deactive the current temperature, the ImageIcon ist displayed on his x,y-coordinate. Reversed, the current temperature is displayed on his xy-place. But together, both is displayed on the same place.
What have i done wrong?
Brain
pory
来自: Italy
联系:
帖子 pory »
hi guys i'm trying to convert this wachface:
https://amazfitwatchfaces.com/t-rex/view/1816
for t rex pro, but when i try to load it on the watch it says it's incompatible.
can you help me?
this in my bin file and log:
http://www.filedropper.com/md205
thank you!
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
pory
This dial works for me. Perhaps you should try to remove unnecessary dials from the watch or try another installation method.
pory
来自: Italy
联系:
帖子 pory »
it still does not work. I tried install manually and with amaz tools but nothing, the staran thing is that the file for trex weighs 1mb while my 250 kb,
thank you
EDIT:
Solved!
上次由 pory 在 15 5月 2021, 17:12,总共编辑 1 次。
pavan9100
来自: hyderabad
联系:
帖子 pavan9100 »
can we make animated watch faces for gts 2?
Jtkz
来自: Malaysia
联系:
帖子 Jtkz »
Hi Sasha,
I'm trying to make a watchface that displays the date with a different image for each day of the month (1-31).
This editor doesnt support this at the moment but is there a way to edit the JSON code such that it display a different image for each day of the month instead of combining images?
I tried changing the ImagesCount from 10 to 31 but it still combines images 1 to 10 only.
Thanks in advance!
上次由 Jtkz 在 15 5月 2021, 11:48,总共编辑 1 次。
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Jtkz
As far as I know, there is no such possibility. Therefore, I did not add it to the editor, unlike the ability to set a separate picture for each month.
Fulvio_61
来自: Novara
联系:
帖子 Fulvio_61 »
Hello Sasha, one question: will it be possible in the future that through the editor the seconds can also be displayed in AOD?
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Fulvio_61
Not. The watch cannot display seconds in AOD mode. More precisely, the seconds can be displayed, but they will be updated once a minute or less.
Jtkz
来自: Malaysia
联系:
帖子 Jtkz »
What about displaying different images each hour? Is that possible?
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Jtkz
You can try to do this by converting the dial from GTR 47
Jtkz
来自: Malaysia
联系:
帖子 Jtkz »
I have managed to do this by changing the ImagesCount and DisplayFormAnalog to true. However, the image is appearing in the AOD although I did not select it to display in AOD.
You may refer to attached BIN file if you wish to do so.
附件
iwc_dark_tourbillon_test4.bin
(2.08 MiB) 已下载 144 次
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
Jtkz
Create AOD and add only the elements you need.
ham.kasturi
来自: Klang
联系:
帖子 ham.kasturi »
Hi.
how to move seconds pointer behind hours pointer?
[email protected]
来自: Poland
Has thanked: 3 time
联系:
Are there any components that affect battery consumption? I noticed that my watchfaces, even without AoD, take about 12-15% a day, and those from the store take 12-15% but with AoD on (mine with AoD is about 18-20% a day).
Does the amount of graphics affect the battery consumption of the dial? Or some other factor?
头像
来自: Ukraine
联系:
帖子 SashaCX75 »
ham.kasturi
Set the hour and minute hands in the center (coordinates for GTR2 227 / 227)
[email protected]
I have no verified information that some elements in the dial affect the autonomy of the watch.
But in some forums I saw the opinion that the presence of an analog clock and a large number of elements (when the size of the dial is more than 1 MB) affects autonomy.
[email protected]
来自: Poland
Has thanked: 3 time
联系:
All my dials were well over 5MB;)
Now I made one without a background which is 1.25MB. She sees how she can handle it.
Would it be possible to add the same size numerator as the editor has for the first GTR for the new editor?
回复
回到 “Watchfaces tools”
在线用户
正浏览此版面之用户: 没有注册用户 和 3 访客
