Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Been thanked: 1044 times
Contato:
Mensagem por SashaCX75 »
Imagem
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Editado pela última vez por SashaCX75 em 01 Jun 2022, 07:19, em um total de 32 vezes.
Avatar do usuário
Has thanked: 438 times
Been thanked: 2141 times
Contato:
Mensagem por asoo »
NuttyS escreveu: 28 Abr 2021, 12:01
SashaCX75 escreveu: 12 Abr 2021, 07:55
Not all elements work after conversion. Of the advantages of such dials, I consider only working labels and the ability to set different fonts and independent coordinates for tens and units in time.
I’m so sorry to be a pest, but I’m new to this bit, I can’t work out how to convert a gtr face to work on a gtr 2e. That’s what this is for right? But I can’t figure it out.
I assumed it would be the convert bit, but there’s no gtr 2e.
Imagem
Your Picture is not program GTRtoGTR2
Your Picture is "AmazFit_Watchface_Editor_(GTR47ToGTR2)"
viewtopic.php?p=8844#p8844
Imagem
If you want to use this program to convert GTR to GTR2/2e You can do by this step
Use button No.1 to open .BIN GTR47mm that you want to edit or convert
when finish edit use button No.2 Pack to BIN GTR2/2e
pory
Registrado em: 18 Abr 2021, 15:48
Contato:
Mensagem por pory »
Sorry but i'm confused,,, which tool should i use to convert wachface from t rex in to t rex pro?
Avatar do usuário
Contato:
pory
If you only need to convert, then you can use the GTRtoGTR2 or AmazFit_Watchface_Editor_ (GTR47ToGTR2) program.
But the converted watch faces may not work properly. I recommend disassembling the dial using AmazFit_Watchface_Editor_ (GTR47ToGTR2) and re-making it with the program from the first post in this thread.
Avatar do usuário
Contato:
Updated watch faces editor
Added French.
[email protected]
Registrado em: 15 Set 2019, 14:38
Contato:
Mensagem por [email protected] »
I guess nobody has reported it yet? - in the AoD edit mode, the position change preview for the numerical battery value and for the battery icon does not work.
Only after using the Random preview button is the battery position updated. The problem persists in the latest version.
Imagem
zyfish
Registrado em: 24 Ago 2020, 10:55
Contato:
Mensagem por zyfish »
SashaCX75 escreveu: 30 Abr 2021, 14:08
Added French.
gtr2e
There is still a problem with the temperature display in the middle
Avatar do usuário
Contato:
zyfish escreveu: 30 Abr 2021, 20:29
gtr2e
On which watch face is the problem and what is your watch firmware?
Avatar do usuário
JuniorPassos
Registrado em: 11 Jul 2019, 22:21
Contato:
Mensagem por JuniorPassos »
Added French.
Thank you very much for the program.
If you need someone to translate into Portuguese, I'm available to help you. ;)
brain65
Registrado em: 25 Mar 2021, 13:01
Contato:
Mensagem por brain65 »
I had made a Watchface for the GTR2 with the editor2. I use for the weather indicator only the "Image progress" and the "current temperature". The coordinates (x and y) of both are different, but on the watch the current temperature is displayed over the Image Icon on the xy-place of the ImageIcon.
If I deactive the current temperature, the ImageIcon ist displayed on his x,y-coordinate. Reversed, the current temperature is displayed on his xy-place. But together, both is displayed on the same place.
What have i done wrong?
Brain
pory
Contato:
Mensagem por pory »
hi guys i'm trying to convert this wachface:
https://amazfitwatchfaces.com/t-rex/view/1816
for t rex pro, but when i try to load it on the watch it says it's incompatible.
can you help me?
this in my bin file and log:
http://www.filedropper.com/md205
thank you!
Avatar do usuário
Contato:
pory
This dial works for me. Perhaps you should try to remove unnecessary dials from the watch or try another installation method.
pory
Contato:
Mensagem por pory »
it still does not work. I tried install manually and with amaz tools but nothing, the staran thing is that the file for trex weighs 1mb while my 250 kb,
thank you
EDIT:
Solved!
Editado pela última vez por pory em 15 Mai 2021, 17:12, em um total de 1 vez.
pavan9100
Registrado em: 24 Abr 2021, 17:23
Contato:
Mensagem por pavan9100 »
can we make animated watch faces for gts 2?
Jtkz
Registrado em: 11 Mai 2021, 15:56
Contato:
Mensagem por Jtkz »
Hi Sasha,
I'm trying to make a watchface that displays the date with a different image for each day of the month (1-31).
This editor doesnt support this at the moment but is there a way to edit the JSON code such that it display a different image for each day of the month instead of combining images?
I tried changing the ImagesCount from 10 to 31 but it still combines images 1 to 10 only.
Thanks in advance!
Editado pela última vez por Jtkz em 15 Mai 2021, 11:48, em um total de 1 vez.
Avatar do usuário
Contato:
Jtkz
As far as I know, there is no such possibility. Therefore, I did not add it to the editor, unlike the ability to set a separate picture for each month.
Fulvio_61
Registrado em: 21 Mar 2021, 13:59
Contato:
Mensagem por Fulvio_61 »
Hello Sasha, one question: will it be possible in the future that through the editor the seconds can also be displayed in AOD?
Avatar do usuário
Contato:
Fulvio_61
Not. The watch cannot display seconds in AOD mode. More precisely, the seconds can be displayed, but they will be updated once a minute or less.
Jtkz
Contato:
Mensagem por Jtkz »
What about displaying different images each hour? Is that possible?
Avatar do usuário
Contato:
Jtkz
You can try to do this by converting the dial from GTR 47
Jtkz
Contato:
Mensagem por Jtkz »
I have managed to do this by changing the ImagesCount and DisplayFormAnalog to true. However, the image is appearing in the AOD although I did not select it to display in AOD.
You may refer to attached BIN file if you wish to do so.
Anexos
iwc_dark_tourbillon_test4.bin
(2.08 MiB) Baixado 146 vezes
Avatar do usuário
Contato:
Jtkz
Create AOD and add only the elements you need.
ham.kasturi
Registrado em: 10 Mai 2021, 19:03
Contato:
Mensagem por ham.kasturi »
Hi.
how to move seconds pointer behind hours pointer?
Imagem
[email protected]
Contato:
Are there any components that affect battery consumption? I noticed that my watchfaces, even without AoD, take about 12-15% a day, and those from the store take 12-15% but with AoD on (mine with AoD is about 18-20% a day).
Does the amount of graphics affect the battery consumption of the dial? Or some other factor?
Avatar do usuário
Contato:
ham.kasturi
Set the hour and minute hands in the center (coordinates for GTR2 227 / 227)
[email protected]
I have no verified information that some elements in the dial affect the autonomy of the watch.
But in some forums I saw the opinion that the presence of an analog clock and a large number of elements (when the size of the dial is more than 1 MB) affects autonomy.
[email protected]
Contato:
All my dials were well over 5MB;)
Now I made one without a background which is 1.25MB. She sees how she can handle it.
Would it be possible to add the same size numerator as the editor has for the first GTR for the new editor?
Imagem
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 2 visitantes
