Been thanked: 1044 times
Messaggio da SashaCX75 »
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Ultima modifica di SashaCX75 il 01 giu 2022, 07:19, modificato 32 volte in totale.
mplayer
Messaggio da mplayer »
It works to design GTR Faces yet?
Or does it only supports GTR2?
Version 2.1
Updated the file.
Fixed bug when saving weather in AOD.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Messaggio da demiurg1 »
demiurg1 ha scritto: 25 mar 2021, 17:36
SashaCX75 ha scritto: 25 mar 2021, 12:00
Version 2.0
Hi SashaCX75,
It's great that there is a new version and it's already numbered as 2.0.
Thanks for your work.
SashCX75 - in the "VeeValdi HWY" watch face I used the AOD function implemented in your program.
demiurg1
In this watch face I used the AOD function implemented in Version 2.1 of SashaCX75: https://amazfitwatchfaces.com/gtr/view/13505 .
demiurg1
demiurg1
SashaCX75 ha scritto: 27 mar 2021, 18:50
Version 2.1
Updated the file.
Thanks for the next changes updating the program.
demiurg1
But still a big thank you for updating the program.
Darkstalix
Messaggio da Darkstalix »
Thank you for updating this magic!
however i cant seem to download 2.1 :/
Darkstalix
Can anyone upload the 2.1 version? 2 days now the link it says that is down, i would really appreciate this
skippy_skippy_9
Messaggio da skippy_skippy_9 »
Darkstalix
the link is ok
retry it
Darkstalix
i try it and it say unable to connect :/
i tried with edge too
"Firefox can’t establish a connection to the server at www.dropbox.com."
JuniorPassos
Messaggio da JuniorPassos »
yishuyan1105
Messaggio da yishuyan1105 »
Hello, when will amazfit watchface Editor 2 be able to update the "animation" function? Without this function, gts2 and other models will have great difficulties and lack of many effects in making dial. Thank you very much!
sfreud
Messaggio da sfreud »
will be added option for convert to another smartw ?
sfreud There are no plans to add conversion capabilities in the near future.
demiurg1
Version 2.1
Updated the file.
================= Error ==============
I think I found an error in "AmazFit_Watchface_Editor_2".
The error is in: "Activity" -> "Heart rate" -> "Pointer". It is based on incorrect display of the "Heart rate" value with the pointer. This value agrees with the "Numerical values" given in the program, but it does not match after uploading the BIN file to the watch.
The error is that the maximum "Heart rate" given in the "Pointer" function is 200 beats per minute, and in the "Numerical values" function there is no this limitation and this value is not related to the circumference of the circle.
In order for the pulse to be displayed correctly, the following assignment must be entered into the program:
"End angle" - "Start angle" / 200 = angular value for 1 heart rate "Heart rate".
When we use the entire circumference of the circle to indicate "Pointer", it will be:
360-0 / 200 = 1.8 ° / 1 heartbeat.
When we use a part of the circumference of a circle, e.g. from 0 to 200 °, but rotate the indications by some angle, it can be, for example:
500-220 / 200 = 1.4 ° / 1 heartbeat.
I found an example of an error trying to make a Polish version of the dial from the project https://amazfitwatchfaces.com/gtr/view/13522.
relax
Messaggio da relax »
Hey.sasha,nihao,why gts2 not "animation" function.i like astronaut dial
demiurg1
There are problems with the correct display of the heart rate. The fact is that the scale does not change from 0 to 200, but from about 20 to 160. More precisely, it can be calculated only empirically. I plan to fix this in future versions.
GTR2 (GTS2) do not support animation. If you have any other information, please provide the clock face with the animation working. And then, by analogy with him, there is a chance to add animation to the editor.
yishuyan1105
That's too bad Hearing this answer, I am very depressed
demiurg1
SashaCX75 ha scritto: 01 apr 2021, 14:41
@demiurg1
OK.
I guess from 0 to 20 and from 160 to 200 the clock hand of the pulse was also moving and showing something. Only when it reached the value of 200 (displayed numerically for comparison) did the pointer stop.
su8044
Messaggio da su8044 »
Amazing editor. Will there be an option to add hot zones (link to app)? That would be the cherry on top
demiurg1
The SashCX75 editor is great. Besides, Sasha knows what he is doing, which I could see in my discussion with him.
Darkstalix
Any chance ever to add conversion from GTS 1 to GTS 2?
ntnntp
Messaggio da ntnntp »
I’m not sure if I did anything wrong, but it seems like the watch won’t accept more than two watchfaces generated by the editor.
It goes like this:
Synced first wf successfully. Try syncing the second one, the watch says “failed to sync watch face” after enabling wf.
What I tried (but failed):
- Generated new watchface id
- Checked and unchecked watchface id (in background tab)
- Checked and unchecked Save watchface id
- Tried different design
- Delete and regenerate bin file
- Checked log file
What I suspect:
It looks like the watchface id feature isn’t working and the application is not writing wf id to the bin file as I found no lines in the log file indicating the watchface id. The wf id might conflict in the watch and produce the error.
Torna a “Watchfaces tools”
