• Адміністратор
Правила форуму
Аватар користувача
Контактна інформація:
Повідомлення SashaCX75 »
Зображення
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Востаннє редагувалось 01 червня 2022, 07:19 користувачем SashaCX75, всього редагувалось 32 разів.
jorgealmeida.rs
З нами з: 16 липня 2020, 01:28
Повідомлення jorgealmeida.rs »
I hope you change your mind and make some solution to GTS2 Mini, in the future. Because this is one of the best Amazfit smartwatch. I had a GTS and now I have a GTS2 Mini. It´s much better, but I miss to make my own watchfaces.
Congratulations for you job. And Thank you very much for all.
Jorge.rs
demiurg1
З нами з: 23 лютого 2020, 22:49
Has thanked: 23 times
Been thanked: 17 times
Повідомлення demiurg1 »
I just guess. In fact, it happens that the seconds hand "freezes" for a while in some watch faces. The GTR 2 stores all loaded watch faces and may run out of memory. It may also be caused by an overly large BIN file (with some applied graphics) which has to be processed by the watch firmware. It can help to delete some of the less used watch faces from the smartwatch memory. Generally, it is rather a hardware or firmware problem and you can hope that the Chinese will fix it with the next update.
demiurg1
SashaCX75, this watch face "VR Patek Philippe future-proof" for GTR 2 (https://amazfitwatchfaces.com/gtr/view/13121) is already made with your program. Thanks again.
Зображення
Pal57
З нами з: 09 лютого 2021, 21:10
Повідомлення Pal57 »
Hi Sasha,
I unpaked a .bin file with your prg, of a watchface that I uselly use for my GTR2 and I took a look at it's json text file and found out many other functions for GTR2, like the "ScreenIdle".
Do you think to update the prg to sue these functions?
Thanks.
Pal57
Аватар користувача
Of course the editor will be updated and new features will be added. But it takes time.
skippy_skippy_9
З нами з: 09 березня 2021, 21:24
Повідомлення skippy_skippy_9 »
thanks Sasha for this great tool
Denis56
З нами з: 26 грудня 2020, 07:32
Повідомлення Denis56 »
Hi Sasha,
Congratulations for the tool. I am a total newbie in this game and I am trying to edit a watchface and replace the english date labels (Monday, Tuesday etc.) by the French ones (Lundi, Mardi...), as a first exercise. I can't find the way to do it... Also, is there a tutorial explaining the process of building a face, I have a couple of ideas I would like to try. But no clue what json is. Thank you so much. Denis
joebar78
З нами з: 27 жовтня 2019, 16:39
Повідомлення joebar78 »
Salut,
1) Use "unpack compressed .bin " button and choose the bin file you would like to modify
2) This will create a new folder in "Watch_face" folder with png and json files
3) Replace english png files by french ones and adjust positions if needed (this will modifiy json file)
4) Save json file
5) Rebuild the bin file with "Pack and compress .bin" button by selecting json file.
We can discuss about this in french by private messages.
Denis56
Thanks Joebar, will try and come back to you. I did not find how to replace the pngs ...
Denis
demiurg1
SashaCX75 писав: 07 березня 2021, 10:37
The editor supports watch faces from GTR 2(e), GTS 2.
Зображення
Version 1.2
AOD and widgets are not yet supported, but when editing watch faces with them, they should be preserved.
v1.2 Added Spanish language
I do not know if it is very important, but you have to be careful that the loaded graphics, entered in the "named watch face" .json file, cannot be too large, because then this file resets and all work goes to the trash if we do not have a copy. There is no error message while saving the * .json file.
Greetings.
Аватар користувача
demiurg1 писав: 21 березня 2021, 20:38
Greetings.
Send the project in which the json file does not want to be saved and describe in detail the actions leading to this. I'll try to check.
demiurg1
Unfortunately, I do not have it anymore, because I have improved the PNG files by limiting their size ("thinning" them).
While doing my next project, I can try to simulate something.
Generally, the problem appeared when saving * .json from "AmazFit_Watchface_Editor_2". Suddenly, this edited file, after saving it, had the same content as the "PreviewStates.json" file, ie without the program line.
Аватар користувача
demiurg1
There is an error in the current version of the editor. If you save the "named watch face" .json file immediately after saving the PreviewStates.json file, then PreviewStates.json will be saved in its place. This is similar to the case you described.
Also, in the next version, in order not to confuse files, PreviewStates.json will be renamed to Preview.States.
skidoo38
З нами з: 24 березня 2021, 09:59
Повідомлення skidoo38 »
Hello, sry for my question but that's make few days I search a tool for create watch face for the gts 2 mini, I know your editor doesn't work with mini but do you now a tool who do that plz ?
Thx a lot
Аватар користувача
Version 2.0
zyfish
З нами з: 24 серпня 2020, 10:55
Повідомлення zyfish »
thanks
Djulze
З нами з: 12 січня 2021, 16:55
Повідомлення Djulze »
Hi Sasha,
Thank you so much for this excellent work! Your editor is great and user friendly for a newbie like me!
One question: Is there a trick to reversing the progression of a circle ("Activity -> Circle progress") ?
demiurg1
SashaCX75 писав: 25 березня 2021, 12:00
Version 2.0
Hi SashaCX75,
It's great that there is a new version and it's already numbered as 2.0.
Thanks for your work.
Аватар користувача
Guydu91
З нами з: 06 жовтня 2019, 18:49
Has thanked: 58 times
Повідомлення Guydu91 »
Well done Sascha for this remarkable work.
Congratulations on the quick release of version 2.0 which incorporates AOD support.
This is a real plus that will allow better achievements.
Thanks again for what you did!
demiurg1
It would be nice if the changes in the energy circle were simulated when we changed the percentage of energy.
The same is true for e.g. steps.
Screenshot attached.
Зображення
Аватар користувача
Djulze писав: 25 березня 2021, 15:30
Hi Sasha,
The start angle needs to be less than the end angle.
For example, the starting angle is 90, the ending angle is 0. For angles, it is better not to use negative values.
Аватар користувача
demiurg1 писав: 25 березня 2021, 22:44
In the latest version, when using a picture for circular progress, the display does not work correctly.
This will be fixed soon.
bird81309
З нами з: 27 квітня 2018, 01:46
Повідомлення bird81309 »
Thank you for the tool you designed. I used this to make some watch faces.
I also tried to move GTR to GTR2, and it succeeded.
This tool is really awesome
Зображення
demiurg1
SashaCX75 писав: 26 березня 2021, 12:23
OK, Super ! :)
BravoCharlie
З нами з: 24 березня 2019, 01:28
Повідомлення BravoCharlie »
Thanks for the fantastic update to support AOD :D
I notice a small bug in version 2 with the circle progress. In version 1.2 you could preview a coloured image for the circle progress but in version 2 it's only showing as a black circle so when you have a black background you won't see it.
Зображення
Зображення
Відповісти
Хто зараз онлайн
