AmazFaces APP (Android) open BETA
GloriousMorningstar
Post by GloriousMorningstar »
GIK-Team wrote: 30 Aug 2020, 13:29
GloriousMorningstar wrote: 30 Aug 2020, 12:14
It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
It's normal.
OK so the watchfaces do only work in smart mode?
Has thanked: 1138 times
Been thanked: 275 times
GloriousMorningstar wrote: 30 Aug 2020, 13:46
It's normal.
Yes.
KA_
Post by KA_ »
Need to add APP support for Notify for Amazfit. Personally I'm using it without Zepp or MiFitt or anything else.
I mean direct download watchface to watch via Notify instead of Zepp.
Stas
Been thanked: 34 times
Post by Stas »
You can use “open with” option
https://firebasestorage.googleapis.com/ ... b196b539be
KA_ wrote: 11 Oct 2020, 09:27
YanniFaces
Post by YanniFaces »
Hi everyone, this is not a bug but just a minor UI correction:
The "Add to favorites" button is still misspelled in the app (see attached screenshot).
I'm on the open beta v2.0.114 of the app (Android).
sHawTY
Post by sHawTY »
The latest version still failed to install watchface on GTR
sHawTY
Post by sHawTY »
Latest BETA has fixed the installation of watch faces. Thank you guys
jmvsilva
Post by jmvsilva »
Samsung s20 plus after update for Androide 11, still not working with both versions
Rcappa
Post by Rcappa »
Hello GK-Team,
I have joined your beta and installed the Beta version 2.1 dated February 28, 2021. I have a Google Pixel 4XL and GTR 2 watch and I can't still install watch faces. When I select a GTR 2 watch face, it starts to install then once it gets to 100% install, I get "failed to sync watch face". Anything I am doing wrong?
Thanks in advance!
Stas
Post by Stas »
We will try to solve it as soon as possible
Rcappa wrote: 06 Mar 2021, 19:34
Hello GK-Team,
Thanks in advance!
Rcappa
Post by Rcappa »
Stas wrote: 06 Mar 2021, 20:52
Thanks !
Rcappa
Post by Rcappa »
Just an FYI, I installed the latest beta March 15th on my google pixel 4xl is now working for GTR 2 watch faces! Thanks!
Rcappa
Post by Rcappa »
Interesting, Beta March 16th worked on GTR 2 the first time to install watch face but now not working again. Is there something I need to do to make it work on my Pixel 4xl?
keyring
Post by keyring »
Hi everyone! Joined the open Beta test because the version was unable to install the watchface on my GTR 47mm. In the next version, this bug was resolved, but in version 2.4 the bug is back again, I just cannot install any watchface on my GTR 47mm. I've got an Android 11, maybe this is one of the thongs that cause this bug
Stas
Post by Stas »
Update to version 2.4.142 and check the installation
Rcappa wrote: 19 Mar 2021, 13:57
Stas
Post by Stas »
keyring wrote: 22 Mar 2021, 15:00
Rcappa
Post by Rcappa »
Stas wrote: 22 Mar 2021, 22:42
I was able to install, however what I need to do is delete the last watch face I uploaded to my GTR 2 using the app faces app and then I can add a new one. It gives me a sync error when I try to add watch faces when I already had one installed from the app.
Stas
Post by Stas »
Are you using a file overwrite installation?
Rcappa wrote: 26 Mar 2021, 16:54
Rcappa
Post by Rcappa »
I don't know what you mean by file overwrite installation.
Stas wrote: 26 Mar 2021, 17:59
Ferrarinews
Post by Ferrarinews »
With the latest version 2.5.148 beta, the program does not synchronize faces with my Amazfit GTR 2e and does not detect it.
Are you aware of the situation? Is a new version coming out to correct this problem?
Thanks.
tlausl
Post by tlausl »
Can't install any watch faces on T-Rex Pro. Newest beta.
Installation starts but nothing happend.
CASIONFAN2021
Post by CASIONFAN2021 »
sent you an email with a short video clip of the software not working on samsung galaxy s20. no reply yet
Stas
Post by Stas »
Fixes for T-Rex Pro will be in the next update, I'll let you know by email
CASIONFAN2021 wrote: 12 May 2021, 11:20
Chito_a
Post by Chito_a »
I'm trying to use AmazFace version 2.9.175 with android11 on a tree and can not get it to connect to my watch. Zepp does connect. Any help?
HuginnOkMuninn
Post by HuginnOkMuninn »
Can't install wf after Android 11 MIUI 12.5 update. Endless permission request. Permissions granted in full.
App version: 2.9.180
Watch model: T-Rex
Phone model: Redmi Note 8 Pro
OS version: Android 11 MIUI 12.5
Return to “AmazFaces app”
