AmazFaces APP (Android) open BETA
Has thanked: 1166 times
Been thanked: 279 times
Amazfit WatchFaces is the largest watchface collection in the world for Amazfit watch. Instantly get everything you need to customize & personalize your Amazfit watch!
Join the thousands and get access to 180 000+ amazing watchfaces! With a huge number of new watchface that are added every day!
One app! And more than 180 000 watchface!
AmazFaces BETA on Google Play
Antotamara
Post by Antotamara »
No funciona en mi stratos
Antotamara wrote: 29 Mar 2019, 23:04
Can you, please, explain little bit more clear? What exactly does not work for you and how you use our application. Thank you!
FashionUomo
Post by FashionUomo »
Non funziona su amazfit stratos
FashionUomo wrote: 31 Mar 2019, 15:47
Kamakzie
Post by Kamakzie »
When I try to download a watch face it gives me the error that it can't connect to the watch. Any ideas?
Kamakzie wrote: 05 Apr 2019, 05:58
Update version ;)
Greg
Post by Greg »
hello
pls tell me how can i install this app on my watch
Greg wrote: 09 Apr 2019, 07:15
hello
https://forum.xda-developers.com/androi ... y-t3358711
or
http://apkinstaller.com/downloads/
Erkuky
Post by Erkuky »
Poner aqui el link para descargar la APK a instalar en el Watch.
Es mas trabajoso si solo podemos bajarlo al smartphone desde la app del smartphone.
Saludos
Erkuky wrote: 30 Apr 2019, 13:52
Saludos
https://amazfitwatchfaces.com/api/app/a ... ch_app.apk
merry007
Post by merry007 »
Really nice
merry007
Post by merry007 »
It helped me a lot.
Jeroen Verhoeven
Post by Jeroen Verhoeven »
So far working ok on Android 9 on Oneplus 6. Thanks a lot for this program!
rosey12
Post by rosey12 »
Wow. This is just awesome. Is the updated version suitable for ASUS device? Please help me with a suitable solution.
rosey12 wrote: 22 May 2019, 04:37
Requires Android
5.0 and up
Notoriez
Post by Notoriez »
I've installed the app and it's working fine. Some of the watch faces that i downloaded via the AmazFaces appears on the Amazfit App.
But there is also quite few watchfaces that i tried to downloaded is not appearing on the app after few tries. Any reason for this?
Great job btw.
Notoriez wrote: 22 May 2019, 09:35
Great job btw.
What watchfaces did not appear? Can you provide links?
dpisaacs
Post by dpisaacs »
Hi, I've downloaded and installed the app on my phone and the watch companion apk (on Stratos).
Just curious as to what the installed companion app on the watch calls itself?
Using the APK Installer, I can see an app that I suspect it might be called is "com,st,receiverwatch", is this it?
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
Yes that's right com.st.receiverwatch
daydreaming
Post by daydreaming »
In some reasons, i can't use Google play in China.
Is there any other way to download the AmazFace app?
daydreaming wrote: 08 Jun 2019, 23:00
https://apk-dl.com/amazfaces/com.amazfitwatchfaces.st
TXK
Has thanked: 150 times
Been thanked: 99 times
Post by TXK »
GIK-Team wrote: 09 Jun 2019, 06:04
On PC, display:
403 Forbidden
Return to “AmazFaces app”
