OK so the watchfaces do only work in smart mode?GIK-Team wrote: 30 Aug 2020, 13:29It's normal.GloriousMorningstar wrote: 30 Aug 2020, 12:14It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
AmazFaces APP (Android) open BETA
GloriousMorningstar
- GIK-Team
- root
- Has thanked: 1105 times
- Been thanked: 266 times
Yes.GloriousMorningstar wrote: 30 Aug 2020, 13:46OK so the watchfaces do only work in smart mode?GIK-Team wrote: 30 Aug 2020, 13:29It's normal.GloriousMorningstar wrote: 30 Aug 2020, 12:14It works to set a watch face in smart mode, but when I switch to ultra mode it changes back to a basic watch face.
Need to add APP support for Notify for Amazfit. Personally I'm using it without Zepp or MiFitt or anything else.
I mean direct download watchface to watch via Notify instead of Zepp.
- Stas
- Has thanked: 4 times
- Been thanked: 34 times
You can use “open with” option
https://firebasestorage.googleapis.com/ ... b196b539be
KA_ wrote: 11 Oct 2020, 09:27Need to add APP support for Notify for Amazfit. Personally I'm using it without Zepp or MiFitt or anything else.
YanniFaces
Latest BETA has fixed the installation of watch faces. Thank you guys
Samsung s20 plus after update for Androide 11, still not working with both versions
Hello GK-Team,
I have joined your beta and installed the Beta version 2.1 dated February 28, 2021. I have a Google Pixel 4XL and GTR 2 watch and I can't still install watch faces. When I select a GTR 2 watch face, it starts to install then once it gets to 100% install, I get "failed to sync watch face". Anything I am doing wrong?
Thanks in advance!
Thanks in advance!
- Stas
We will try to solve it as soon as possible
Rcappa wrote: 06 Mar 2021, 19:34Hello GK-Team,
Thanks in advance!
Interesting, Beta March 16th worked on GTR 2 the first time to install watch face but now not working again. Is there something I need to do to make it work on my Pixel 4xl?
Hi everyone! Joined the open Beta test because the version was unable to install the watchface on my GTR 47mm. In the next version, this bug was resolved, but in version 2.4 the bug is back again, I just cannot install any watchface on my GTR 47mm. I've got an Android 11, maybe this is one of the thongs that cause this bug
- Stas
Update to version 2.4.142 and check the installation
Rcappa wrote: 19 Mar 2021, 13:57Interesting, Beta March 16th worked on GTR 2 the first time to install watch face but now not working again. Is there something I need to do to make it work on my Pixel 4xl?
- Stas
keyring wrote: 22 Mar 2021, 15:00Hi everyone! Joined the open Beta test because the version was unable to install the watchface on my GTR 47mm. In the next version, this bug was resolved, but in version 2.4 the bug is back again, I just cannot install any watchface on my GTR 47mm. I've got an Android 11, maybe this is one of the thongs that cause this bug
I was able to install, however what I need to do is delete the last watch face I uploaded to my GTR 2 using the app faces app and then I can add a new one. It gives me a sync error when I try to add watch faces when I already had one installed from the app.
- Stas
Are you using a file overwrite installation?
Rcappa wrote: 26 Mar 2021, 16:54I was able to install, however what I need to do is delete the last watch face I uploaded to my GTR 2 using the app faces app and then I can add a new one. It gives me a sync error when I try to add watch faces when I already had one installed from the app.
I don't know what you mean by file overwrite installation.
Stas wrote: 26 Mar 2021, 17:59Are you using a file overwrite installation?
Ferrarinews
With the latest version 2.5.148 beta, the program does not synchronize faces with my Amazfit GTR 2e and does not detect it.
Are you aware of the situation? Is a new version coming out to correct this problem?
Thanks.
Thanks.
Can't install any watch faces on T-Rex Pro. Newest beta.
Installation starts but nothing happend.
- CASIONFAN2021
- Has thanked: 1 time
- Been thanked: 4 times
sent you an email with a short video clip of the software not working on samsung galaxy s20. no reply yet
- Stas
Fixes for T-Rex Pro will be in the next update, I'll let you know by email
CASIONFAN2021 wrote: 12 May 2021, 11:20sent you an email with a short video clip of the software not working on samsung galaxy s20. no reply yet
I'm trying to use AmazFace version 2.9.175 with android11 on a tree and can not get it to connect to my watch. Zepp does connect. Any help?
HuginnOkMuninn
