• Administrador
Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Contato:
Mensagem por SashaCX75 »
Imagem
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Editado pela última vez por SashaCX75 em 01 Jun 2022, 07:20, em um total de 25 vezes.
spidercrab
Registrado em: 25 Jun 2020, 09:13
Has thanked: 27 times
Contato:
Mensagem por spidercrab »
[mention]SashaCX75[/mention] I was wondering if you could consider adding the following feature to the GTR_editor, if this is possible.
The Pulse Segment feature works really well and allows a display of your heart rate exercise zone and can be useful thing for anyone using their GTR for exercise. The 5 zones should be 50%-60%, 60%-70%, 70%-80%, 80%-90% and 90%-100% of your max heart rate. As the max heart rate decreases with age, the calculations need to be based on a max heart rate form then to work correctly. The max heart rate is calculated using 220 minus your age. Currently as far as I know, the max heart rate is fixed.
So, I was hoping that you can add a new max heart rate function, similar to the Steps Goal that is then used for the daily step progress.
Being able to enter your max heart rate would be idea or to enter your age would also work.
Avatar do usuário
Contato:
[mention]muskatim[/mention]
The instruction is in the program.
[mention]spidercrab[/mention]
Setting the maximum heart rate is not provided by the watch firmware. Therefore, it is not possible to add such a function to the dial.
Even if new functions are added in future firmware, I will not be able to add them to the editor until their support is added to the utility that unpacks bin files.
Magik933
Registrado em: 09 Jul 2020, 19:19
Contato:
Mensagem por Magik933 »
Hi, How can I edit color on the watch face (hour, minute,s, or seconds hands)?
Rafi87
Registrado em: 25 Jul 2020, 09:15
Contato:
Mensagem por Rafi87 »
Hi
I modified the existing dial and when I want to pack and compress the BIN it will open a window for me and instead of SAVE it is there that open a JSON file
how do I save the modified dial to a BIN file?
Anexos
Ashampoo_Snap_sobota 25. júla 2020_20h38m13s_001_.png (374.15 KiB) Exibido 23437 vezes
Avatar do usuário
kyle
Registrado em: 22 Abr 2018, 14:32
Contato:
Mensagem por kyle »
Rafi87 escreveu: 25 Jul 2020, 18:42
Hi
In the pop-up window, select the json file you want to pack, and then pack it
如有需要可联系!
Avatar do usuário
kyle
Contato:
Mensagem por kyle »
Magik933 escreveu: 25 Jul 2020, 11:11
Use photo editing software such as PS to modify the picture you want to change
如有需要可联系!
Rafi87
Contato:
kyle escreveu: 26 Jul 2020, 01:07
Hi
JSON file how to pack in BIN file?
Avatar do usuário
kyle
Contato:
Mensagem por kyle »
Rafi87 escreveu: 26 Jul 2020, 05:25
Hi
Just pack as shown in the figure
Imagem
如有需要可联系!
Rafi87
Contato:
yes, I did
so, can i put that JSON file in my phone and set the dial?
don't need to convert to a BIN file?
Avatar do usuário
kyle
Contato:
Mensagem por kyle »
Rafi87 escreveu: 26 Jul 2020, 06:40
yes, I did
Can only be converted into a bin file and flashed to the watch
如有需要可联系!
dinhlam91
Registrado em: 11 Jul 2020, 15:48
Contato:
Mensagem por dinhlam91 »
First, Thank you SashaCX75 for this tool.
I've the issue with this tool. I'm using it from version 8.1 up to date is 8.3. I can't preview and Edit the WF.
I'm using windows 10 Pro
Error:
Código: Selecionar todos
System.TypeInitializationException: The type initializer for 'NativeMagickSettings' threw an exception. ---> System.TypeInitializationException: The type initializer for 'X86' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'Magick.Native-Q16-x86.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
   at ImageMagick.Environment.NativeMethods.X86.Environment_SetEnv(IntPtr name, IntPtr value)
   at ImageMagick.Environment.NativeEnvironment.SetEnv(String name, String value)
   at ImageMagick.MagickNET.InitializePrivate(ConfigurationFiles configFiles, String newPath)
   at ImageMagick.MagickNET.Initialize(ConfigurationFiles configFiles, String path)
   at ImageMagick.NativeLibraryLoader.ExtractLibrary()
   at ImageMagick.NativeLibraryLoader.Load()
   at ImageMagick.Environment.NativeMethods.X86..cctor()
   --- End of inner exception stack trace ---
   at ImageMagick.Environment.NativeMethods.X86.Environment_Initialize()
   at ImageMagick.Environment.NativeEnvironment.Initialize()
   at ImageMagick.Environment.Initialize()
   at ImageMagick.MagickSettings.NativeMagickSettings..cctor()
   at ImageMagick.MagickSettings.NativeMagickSettings..ctor()
   at ImageMagick.MagickSettings..ctor()
   at ImageMagick.MagickImage..ctor()
   at GTR_Watch_face.Form1.FormColor(Bitmap bitmap)
   at GTR_Watch_face.Form1.PreviewToBitmap(Graphics gPanel, Single scale, Boolean crop, Boolean WMesh, Boolean BMesh, Boolean BBorder, Boolean showShortcuts, Boolean showShortcutsArea, Boolean showShortcutsBorder, Boolean showAnimation, Boolean showCircleScaleArea, Int32 link)
   at GTR_Watch_face.Form1.<pictureBox_Preview_DoubleClick>b__195_0(Object senderResize, EventArgs eResize)
   at System.Windows.Forms.Control.OnResize(EventArgs e)
   at System.Windows.Forms.PictureBox.OnResize(EventArgs e)
   at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds()
   at System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft_NET/Framework/v4.0.30319/mscorlib.dll
GTR_Watch_face
    Assembly Version: 8.3.0.0
    Win32 Version: 8.3.0.0
    CodeBase: file:///D:/LamPD/Amazfit/GTR_Watch_face_(without_Python)/GTR_Watch_face.exe
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.3752.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Newtonsoft.Json
    Assembly Version: 12.0.0.0
    Win32 Version: 12.0.3.23909
    CodeBase: file:///D:/LamPD/Amazfit/GTR_Watch_face_(without_Python)/Newtonsoft.Json.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
GTR_Watch_face.resources
    CodeBase: file:///D:/LamPD/Amazfit/GTR_Watch_face_(without_Python)/en/GTR_Watch_face.resources.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft_NET/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Magick_NET-Q16-AnyCPU
    Assembly Version: 7.14.5.0
    Win32 Version: 7.14.5.0
    CodeBase: file:///D:/LamPD/Amazfit/GTR_Watch_face_(without_Python)/Magick_NET-Q16-AnyCPU.DLL
enabled.
For example:
<configuration>
</configuration>
Anyone can help me?
Joker73
Registrado em: 14 Ago 2019, 09:31
Contato:
Mensagem por Joker73 »
I made a watch face whose compressed .bin file weighs 427Kbs. I installed it on my GTR through the Notify & Fitness app and the watch entered on a bootloop which I could solve by charging the watch. Why this happened if other watch faces weigh way more?
Avatar do usuário
Contato:
[mention]Joker73[/mention]
The size of the uncompressed file is important.
Possible errors in the watch face.
Joker73
Contato:
SashaCX75 escreveu: 08 Ago 2020, 13:38
@Joker73
Uncompressed file weighs 4.16MB.
EDIT: Solved. The problem was related to the big size of the hour hand.
ThierryC
Registrado em: 25 Jun 2020, 07:38
Contato:
Mensagem por ThierryC »
Great program Sasha, thanks for your work.
In future versions, Is it feasible to add more Shortcuts on the list of the existing ones: Steps, Pulse, Weather and Energy saving?
Such like Alarm, Countdown, Screen lock, Auto brightness, etc...
Avatar do usuário
Contato:
Now the watch supports only 4 types of labels. If something changes in future firmware, I will add new types of shortcuts to the program.
dinhlam91
Contato:
SashaCX75 escreveu: 09 Ago 2020, 11:34
Hi Sasha, can you check and help me with this issue: viewtopic.php?p=6029#p6029
Avatar do usuário
Contato:
dinhlam91
I've tested on windows 7 and windows 10 x64. I didn't have such problems, what could be the reason, I don't know.
Avatar do usuário
Contato:
Version 8.4
Avatar do usuário
lawrence-dol
Registrado em: 05 Nov 2019, 04:11
Mensagem por lawrence-dol »
When working on a watch face, I frequently get an error in GIMP that some or another image cannot be saved and I have to close the WatchFace Editor in order to save. Can this be fixed by ensuring that images are always closed after being read, please?
Lawrence Dol
SWCI
Registrado em: 26 Ago 2019, 09:55
Contato:
Mensagem por SWCI »
SashaCX75 escreveu: 10 Ago 2020, 13:48
Version 8.4
GRAZIE.
Avatar do usuário
Contato:
lawrence-dol
Give me your project and tell me which image and under what conditions it is impossible to edit. I'll see what the problem is and try to fix it.
Avatar do usuário
lawrence-dol
SashaCX75 : It happens randomly to all images in all projects from time to time. All I have to do is be editing some of the images used by the project and pretty soon GIMP will be unable to write one of them when I try to export it. I've had it happen often, probably because I am often editing and refining the images in GIMP and using the watch designer to see the end result as I tweak the image.
You can just open a project and just generate random values while using Process Hacker each time to search for file handles containing the folder name of your project; pretty soon you'll see assorted images held open. The exact files vary for each redisplay, and it seems to happen most commonly with images used for digits, though it's definitely not exclusively these.
It's easy enough to replicate in my workflow -- open, say, the 9 digits used for time display in GIMP, export each once to get through the initial prompts for exporting, then randomly generate display values in the watch designer and each time use CTRL-E to re-export each of the images. Before very long, one will fail to export. In Windows its describes a permission error, but that's normal for Windows when a file is in use. Exit the watch designer and you'll immediately be able to export that image.
Lawrence Dol
grigosback
Registrado em: 30 Jul 2020, 20:56
Contato:
Mensagem por grigosback »
Hello SashaCX75, the link is down. Can you reupload it? Thanks!
Avatar do usuário
Registrado em: 22 Mar 2018, 10:00
Has thanked: 1149 times
Been thanked: 276 times
Contato:
Mensagem por GIK-Team »
grigosback escreveu: 15 Ago 2020, 03:48
Hello @SashaCX75, the link is down. Can you reupload it? Thanks!
The link is available.
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 2 visitantes
