• Administrador
Reglas del Foro
Avatar de Usuario
Contactar:
Mensaje por SashaCX75 »
Imagen
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Última edición por SashaCX75 el 01 Jun 2022, 07:20, editado 25 veces en total.
Avatar de Usuario
maortrol
Has thanked: 27 times
Contactar:
Mensaje por maortrol »
tippo escribió: 10 May 2020, 21:49
How did you get the seconds hand to display under the other two? On the GTS it seems the seconds hand is always on top? (With hours hand on the bottom)
I have no idea how it happened, and that's what I want to fix... :lol:
I'd like to know if there is any way to choose where to put every hand... :roll:
Mithrel
Contactar:
Mensaje por Mithrel »
hello, I'm using GTR_WatchFace version 8, when i packed my bin files they are over 1.95mb.
So i did a test, I downloaded a 1.6mb wachface, unpacked and did not modify it, packed again but it was 2.17mb.
Is something malfunctioning or do I have a bad application configuration?
Avatar de Usuario
Contactar:
maortrol escribió: 10 May 2020, 10:37
I have a watch face in which Seconds hand is shown under Hours and Minutes hands (it passes below them, so when time is 0:00:00 you can't see Seconds hand, it always passes below the other two hands). Is there any way to set Minutes hand to be shown at the bottom, Hours hand at the middle, and Seconds hand at the top?
The hands are usually drawn in this order - hour hand, minute hand, second hand. If you move the second hand from the center, it will be drawn below the rest of the hands.
[mention]Mithrel[/mention]
Maybe 1.6mb is a zipped wachface. And in an unzipped state it is 2.17mb. But then it is not clear how it works. What kind of wachface did you download?
Mithrel
Contactar:
It's not ziped file. I compared the bin files without compression.
I did other test, packed with main.exe and the file is also smaller. I guess is the preview file that makes the difference, is it possible to pack bin without preview? And compressed also?
tippo
Contactar:
Mensaje por tippo »
Mithrel escribió: 11 May 2020, 14:32
I think you can pack without a preview but I haven't tried it. I have packed with a blank preview image to try and cut down on file size and it was fine.
Mithrel
Contactar:
Animated.gif is almost 0.5mb and is always generated when packed the bin.
Then some parts of imagens dont work like day and weather
https://amazfitwatchfaces.com/gtr/view/5603
Avatar de Usuario
Contactar:
According to your link, an unzipped file initially has a size of 2.17mb (English version). Where did you see the size 1.6mb I do not know. Some elements do not work because the size is more than 2mb. The recommended preview file size is 266x266 pixels. If you reduce the size of the preview file, then the size of the bin file should fit into the 2mb limit.
All .png files names that consist of numbers are packed into a bin file, other files are not packed into a bin.
Mithrel
Contactar:
Thanks. Is there a option to reduce the preview?
Avatar de Usuario
Contactar:
Version 8.1
Última edición por SashaCX75 el 12 May 2020, 21:29, editado 1 vez en total.
Mithrel
Contactar:
Thaks for the update
Avatar de Usuario
ManuTdi
Contactar:
Mensaje por ManuTdi »
SashaCX75 escribió: 12 May 2020, 17:38
Version 8.1
Updated translation (French, Italian, Chinese).
Did you include part of my Spanish translation?
tippo
Contactar:
Mensaje por tippo »
Thanks for all your great work [mention]SashaCX75[/mention] !
Avatar de Usuario
Contactar:
[mention]ManuTdi[/mention]
Yes, Included.
SWCI
Contactar:
Mensaje por SWCI »
SashaCX75 escribió: 08 May 2020, 14:07
6. ... and DND mode
Could you please explain to me what DND mode is? thanks.
Endless congratulations for the tool. Thanks
Avatar de Usuario
Contactar:
[mention]SWCI[/mention]
DND (do not disturb) - on the watch in the blind, a crescent-shaped icon.
Avatar de Usuario
kyle
Contactar:
Mensaje por kyle »
没别的意思,就是来纯支持。
No other meaning, just to come to pure support.
如有需要可联系!
gurnoorsi366
Contactar:
Mensaje por gurnoorsi366 »
Hi can someone make a tutorial video for it
Has thanked: 130 times
Been thanked: 19 times
Contactar:
Mensaje por taw_bip »
gurnoorsi366 escribió: 20 May 2020, 17:56
Jackall Digital has a few tutorials on YouTube for the Mi Band but the general concepts are the same. The GTR watchface tool just makes it much easier and faster to put the watchface together.
https://www.youtube.com/watch?v=_j21tufMU-8
dasogoster
Contactar:
Mensaje por dasogoster »
Hello, in the preview gif it looks correct and shows me all the digits, when creating the .bin and testing it in the amazfit GTS, there are some missing steps, calories and time, what could be the fault ?, thanks ...
Avatar de Usuario
maortrol
Contactar:
dasogoster escribió: 24 May 2020, 21:02
Check the uncompressed packed.bin file generated: it must be lesser than 1.5 MB; else, it could work wrongly in the watch.
juanl
Contactar:
Mensaje por juanl »
Reviewing an old my sphere I observed that had defined the step target (8000). When I want to modify it with your program I notice that it does not support that field. The definition of this field is:
"Activity":
"StepsGoal":
"TopLeftX": 60,
"TopLeftY": 293,
"BottomRightX": 60,
"BottomRightY": 40,
"Alignment": "Default",
"Spacing": 1,
"ImageIndex": 12,
"ImagesCount": 10
Do you plan to include it in the next release?
Greetings.
Avatar de Usuario
Contactar:
[mention]juanl[/mention]
If there is a need, I can add. For example, give only a working watchface where this parameter is.
juanl
Contactar:
Mensaje por juanl »
I've put the Bumblebee sphere on the page. The dial is fully functional. You can only see the Stepsgoal statement in json if you unpack it with the old tools.
dasogoster
Contactar:
Hello, as much as I simplify it, I have removed enough images of the weather, it always keeps coming out that it occupies more than 1.5, I see more complex spheres and they work well, I do not understand it, thanks ...
Avatar de Usuario
Lordalpine
Been thanked: 35 times
Contactar:
Mensaje por Lordalpine »
Mithrel escribió: 12 May 2020, 03:30
Preview normally is 266x266 for GTR47mm if you use the 0001.PNG [Background section -> Preview ]
You can resize it to what size you want, do a square with only the name on it... it's as you wish.
But if you want you can use a 1X1 pixel - transparent PNG for the preview if you still want to use the preview feature
or simply don't use it... you leave a blank field [ It means no picture used ] [Background section -> Preview ]
Honnestly now, I don't use it :
You can only have one custom face, I'm always on my custom face.... So^^ it save me time when I sync face to my GTR [ smaller size transfer faster ] and space on my HDD.
Open the spoiler to see an illustrated example, you can zoom on it by simply clicking it :
Imagen
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 5 invitados
