Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
[mention]LoboGT[/mention]
Add day / night temperature (can be outside of the screen) and it will work.
https://drive.google.com/open?id=1g6TfF ... dtXzmBeweQ
Version 8.0
Landuh
Post by Landuh »
SashaCX75 wrote: 21 Apr 2020, 16:32
You are the real deal.
Thank u so much for your work.
Stay safe
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
Version 8.0
Amazing! Great work! Thanks!
tippo
Post by tippo »
Hi all, I'm just getting into designing watch faces and have a quick question...
Is it possible to have a 12hr digital watch face without the '0' at the front for times less than 10:00? So, '2:36' instead of '02:36'?
Thanks for your time.
tippo
Post by tippo »
[deleted]
tippo
Post by tippo »
tippo wrote: 22 Apr 2020, 20:48
Hmmm... doesn't seem like it is possible. Bit of a shame but I'm working on a half fix
herve68
Post by herve68 »
Hello everybody,
i'm a real newbie, this is my first project started from a blank project. I have made all the PNG's, the json. In the software all seems good, but when i want to pack the .bin file nothing is happening, no log, no bin file. There is just a black window who appears for a second. I would be delighted if someone could help me.
Thank you
LoboGT
Post by LoboGT »
[mention]SashaCX75[/mention]
ThankU very much for help with my first project for GTR. Now it's working well.
maortrol
Has thanked: 27 times
Post by maortrol »
You could use (and select them in the editor) a fully transparent image for "0", and standard "1" and "2" images, just for the first digit in hours (tens).
For the rest of the digits (the second hour digit, and both minutes digits), use standard images from "0" to "9" (and select them in the editor), and that's it.
I think it should work, try it and tell us... ;-)
[mention]herve68[/mention]
Make sure that the path to json files does not contain spaces, the json file and png files must be in the same folder.
maortrol wrote: 25 Apr 2020, 13:48
This will not work. Everything will be displayed normally in the editor. On the watch, a different set of pictures for the first digit (tens) and for the second digit (ones) does not work.
On previous firmware it was like that. Maybe on the next firmware this defect will be fixed.
tippo
Post by tippo »
Yeah I tried that but it doesn't work unfortunately. Still racking my brain for a solution. Thanks anyway!
xuanthuydhtn
Post by xuanthuydhtn »
" Uncompressed file size exceeds 1.5 MB" Help me pls!
tippo
Post by tippo »
xuanthuydhtn wrote: 30 Apr 2020, 07:18
Generally you have to reduce the size of the pngs as much as possible. Cut out any unneeded pixels from around the elements. I believe you can also not include the preview png or add one that's blank to save space.
Post by taw_bip »
I've gotten similar messages but the program usually continues if you click to proceed. Larger watchfaces have installed fine on my Verge Lite.
xuanthuydhtn
tippo wrote: 30 Apr 2020, 12:55
I download a file on this web. I unpack and pack again that time. But it still error on file source
For GTR and GTS, users have roughly determined the maximum possible size of their dials. For T-Rex and Verge Lite is no accurate data on what size dials can be installed. Therefore, for them I have set a limit as well as for the GTS 1,5MB. If someone has verified data on what maximum size of the dials can be installed on these models, then let me know and in future versions I will fix it.
Mercutio
Post by Mercutio »
I love this soft. Thank you!
Alitface
Post by Alitface »
Dear Sasha, I am unable to decipher the program. Can help build a WF as per image provided?
Alithir
Malaysia
[mention]Alitface[/mention]
To create such a dial you need the following images:
1. background (size depends on the watch model)
2. Three hands for an analog clock
3. seven pictures to display the day of the week
4. at least ten pictures to display numbers (if the data will be displayed in different fonts, then the number of pictures must be increased)
5. Five to ten pictures to display the battery level (preferably ten)
6. Images to display bluetooth status and DND mode
Alitface
Post by Alitface »
OK thanks. I still can figure our the difference between .wfz, .json and .bin of how to play with them. Thanks for your advice.
Alithir
Malaysia
maortrol
Post by maortrol »
I have a watch face in which Seconds hand is shown under Hours and Minutes hands (it passes below them, so when time is 0:00:00 you can't see Seconds hand, it always passes below the other two hands). Is there any way to set Minutes hand to be shown at the bottom, Hours hand at the middle, and Seconds hand at the top?
Thanks in advance.
yinas
Post by yinas »
Hello community!
Looking for an update on the filesize limit issue, particularly for Amazfit GTS
Especially, how to use most of the screen, for example with a large font for time plus several complications?
I believe there was some python packaging tool mentioned somewhere in the past, that allowed for smaller packed file size which does not break the watchface on upload to the watch?
Cant seem to find that post/comment anymore...
Or maybe I am mistaken.
Anyhow, help on the issue is appreciated!
tippo
Post by tippo »
yinas wrote: 10 May 2020, 18:54
Hello community!
In my usage (I'm pretty new to this) the tool (currently on version 8 and linked in this thread) spits out a packaged watch face and a zipped and packaged watch face. Either can be uploaded to the watch, but the zipped version is much smaller to transfer but once loaded to the watch it unzips to the full size. So it's not a way to get around the file size limit, just a bit faster to download.
For example, this face I just designed for the GTS https://amazfitwatchfaces.com/gts/view/1894 had to be redesigned multiple times to get it under 1.5MB and it's currently 1.41MB packaged but only 0.217MB zipped and packaged. So it uploads fast but barely scrapes into the size limit.
In my testing, the pixel size of the images included are what blows the file size budget. A complex image ends up eating into the file size budget roughly the same as a one colour highly optimised image of the same pixel dimensions. So basically you just have to keep the number of large images to a minimum.
tippo
Post by tippo »
maortrol wrote: 10 May 2020, 10:37
Thanks in advance.
How did you get the seconds hand to display under the other two? On the GTS it seems the seconds hand is always on top? (With hours hand on the bottom)
Users browsing this forum: State808 and 1 guest
