py amazfit tool
afwafwafw
Been thanked: 14 times
py amazfit tool
Post by afwafwafw »
what is...
what isn't...
requirements
  • python3(tested on 3.7.4)
  • pillow(tested on 6.1.0)
## usage
* for verge lite
  * see scripts folder
    * to unpack
    * to pack
      * to pack
      * to unpack
* for GTR
  * to unpack
  * to pack
      * to pack
      * to unpack
Pinkabou
Post by Pinkabou »
Did you have a GTS version ?
I try your soft but have a error. My .Bin file is a GTS watchFace
ajs
Post by ajs »
Horatius80 wrote: 11 Nov 2019, 16:49
HI I do not know how to contact lolyinseo directly, but in his last dev-gtr the battery scale is not working...
I wrote to him about this problem, if there is any answer. I’ll let you know, or maybe he will write it himself.
Horatius80
Post by Horatius80 »
It is OK, I've already figured it out. There are syntax differences in the *.json between GTR and DEV-GTR version .. that was the problem ... here is watchface that works as I wanted
https://amazfitwatchfaces.com/gtr/view/2040
H078
Post by H078 »
Any recommendations on how to keep .bin under 2Mb?
I was making digital watch and size of .bin file kept increasing eventhough all images put together are at most 500kb.
hikashi
Post by hikashi »
Any plans to port in hearts and linear scale i.e. segments? I tried to port in with new elements using the c# as reference but to no avail.
Im not too sure what is the equivalent of list<xy> to python.
pacomar
Post by pacomar »
H078 wrote: 29 Nov 2019, 08:21
reducing the number and size in pixels of png files.
Horatius80
pacomar wrote: 03 Dec 2019, 15:46
... :idea: Or do not use antialiasing to prevent occurrence of semitransparent and partially transparent pixels, reduce the number of colors per image, color palette has to be RGB and using maximal PNG compression ... :idea:
dpassaggio
Post by dpassaggio »
Hi guys, I just tried the Gts version of this tools in python, but I find myself with the same error I had with the gtr version, or following the whole unpack guide, I get the following error
  File "main.py", line 4, in <module>
    from watchFaceParser.config import Config
ImportError: No module named watchFaceParser.config
how do I fix it? :roll:
DJArty
Post by DJArty »
dpassaggio wrote: 04 Dec 2019, 18:42
.. same error
+1 have same error (Ubuntu 16.04 x64)
P.S. but maybe its because default "python main.." starts python ver 2.7 so may be just need start like "python3 main ..."
P.P.S. Yes need start
python3.7 main_py --gts --file watchface_bin
and pillow 6+ for python3.7
hikashi
Post by hikashi »
500kb is too big
> Reuse asset i.e. same 'number' asset for different element like date, activity
> Use assets with smaller dimension
> Use 266 pixel size for the 0001 preview asset
Cheers!
Luizneto100
Post by Luizneto100 »
I'm new, help me, because every time I pack, the bin comes out with a different color from the original? Ex: Green color dial; Installed: Turns Red.
H078
Post by H078 »
What are acceptable transparecy levels for .png files? I tried 32bit and anything lower than that tool throws an error in a log file " invalid transparecy mask".
32bit transparecy generally increases file size in kb.
schwedenpaule
Post by schwedenpaule »
hikashi wrote: 10 Dec 2019, 00:52
500kb is too big
but why is 500kb too big ? For me it seems there is something unnecessary in the bin-file.. or the images are rewritten NOT compressed (if I have 2 bigger images in, the .bin-size increases more than the filesize of the two bigger images!)..
Is there something that can be left out, like the preview gif ? I tried modifiying the python script setting the size of the gif to 1x1, sadly has no effect to the bin-size. Other ideas ?
hikashi
Post by hikashi »
schwedenpaule wrote: 18 Dec 2019, 17:25
500kb is too big
Unfortunately we have to work around with the 2 mb limit. The biggest contributor to the bin size is the asset dimension size regardless of content or quality of compression.
hikashi
Post by hikashi »
Sharing some working syntax with analog dial.
"DaysProgress": {
"AnalogMonth": {
"OnlyBorder": false,
"Color": "0x00000000",
"CenterOffset": {
"X": 84,
"Y": 0
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": 0,
"EndAngle": 33000
"Image": {
"X": 5,
"Y": 44,
"ImageIndex": 12
"AnalogDOW": {
"CenterOffset": {
"X": 0,
"Y": 92
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": 0,
"EndAngle": 30858
"Image": {
"X": 5,
"Y": 35,
"ImageIndex": 13
"StepsProgress": {
"ClockHand": {
"CenterOffset": {
"X": -84,
"Y": 0
"Shape": {
"X": 0,
"Y": 0
"Sector": {
"StartAngle": -15000,
"EndAngle": 15000
"Image": {
"X": 5,
"Y": 44,
"ImageIndex": 13
Louis_Cypher
Post by Louis_Cypher »
500kb is too big
Resizing 001.png (the preview image) to 266 pixels reduced my .bin from 2mb to 1,5mb. Perhaps making it even smaller can decrease .bin for less than 1mb (I didn't try yet).
It looks like the problem is with .gif created during packing. It uses 10 frames, and I think it's not compressed.
hikashi
Post by hikashi »
Louis_Cypher wrote: 31 Dec 2019, 09:43
500kb is too big
Yes. The 266 sized png is meant for 0001.
The gif created is not part of the bin file.
aliense
Post by aliense »
Why sometimes when i try unpack bin i got this err:
2020-01-04 16:07:49,979 - root - DEBUG - Opening watch face 'gtr.bin'
2020-01-04 16:07:49,979 - root - DEBUG - Reading parameters...
2020-01-04 16:07:49,979 - root - INFO - Reading header...
2020-01-04 16:07:49,988 - root - INFO - Header was read:
2020-01-04 16:07:49,988 - root - INFO - Signature: b'O3\x04\x00\x00\x00\x10', Unknown: 3725067530, ParametersSize: 308940802, isValid: False
2020-01-04 16:07:49,988 - root - DEBUG - Parsing parameters...
2020-01-04 16:07:49,988 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
File "C:\Users\alien\Desktop\Zegarek\py_amazfit_tools-master\program*py", line 161, in parseResources
return ParametersConverter.parse(WatchFace, reader.getParameters())
File "C:\Users\alien\Desktop\Zegarek\py_amazfit_tools-master\watchFaceParser\reader*py", line 12, in getParameters
return self._parameters
AttributeError: 'Reader' object has no attribute '_parameters'
afwafwafw
Post by afwafwafw »
aliense wrote: 04 Jan 2020, 15:11
There's a issue with negative values for spacing or positions.
I've fixed some but let me know if you still have this issue with latest codes.
vadim.t
Post by vadim.t »
afwafwafw wrote: 04 Jan 2020, 15:29
File "program*py", line 161, in parseResources
File "\watchFaceParser\reader*py", line 12, in getParameters
Hi! Thank you for this amazing tool! I would like to make few changes to the standard watch face "Orange light" provided for GTR 47, but I get the same error while unpacking a bin file (I use the latest version of your app). Can you please advise? The file is on google drive /open?id=1NE8sYuYnihxpFVJVB8-51Lv9Ud_EIDAO
Here is a fragment of my log:
2020-01-06 00:37:18,502 - root - INFO - Header was read:
2020-01-06 00:37:18,502 - root - INFO - Signature: b'O\xc8\x05\x00\x00\x00\x10', Unknown: 2735211786, ParametersSize: 305074177, isValid: False
2020-01-06 00:37:18,502 - root - DEBUG - Parsing parameters...
2020-01-06 00:37:18,503 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
afwafwafw
Post by afwafwafw »
vadim.t wrote: 06 Jan 2020, 00:02
It seems like compressed bin.
Normal bin should have 'HMDIAL' for signature field as far as I know.
Maybe SashaCX75's tool can decompress these kind of .bin. ( viewtopic.php?f=29&t=1076 )
Is there any open explanation for compression used in these format? I want to know.
Horatius80
Horatius80 wrote: 06 Jan 2020, 11:49
Amazfit_RainbowCircle.zip
(149.7 KiB) Downloaded 339 times
afwafwafw
Post by afwafwafw »
Horatius80 wrote: 06 Jan 2020, 11:51
This one also looks like compressed one.
Not normal(uncompressed) header.
kampanita
Has thanked: 8 times
Been thanked: 7 times
Post by kampanita »
I'm having trouble with this one.
Seems to be ok but does not get installed. I see no error but does not run at watch ( gtr-47 )
If i quit weather and weekday parts, it runs ok...
https://amazfitwatchfaces.com/gtr/view/2714
Has thanked: 414 times
Been thanked: 2073 times
kampanita wrote: 07 Jan 2020, 14:25
After adding "weather" and "weekday"
Your .BIN file (uncompress) size over 2M or not?
If the .BIN (uncompress) size is over 2M. It may not be able to be installed.
Users browsing this forum: Baidu [Spider] and 1 guest
