MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Maikeldevil
Been thanked: 44 times
Post by Maikeldevil »
Oh btw im not using latest palletmode of MiBandWDTool but v3 or so because this is the only one that not makes the images ugly but only has a color limiter. SRRY!
mysiak
Has thanked: 11 times
Post by mysiak »
Maikeldevil wrote: 03 Oct 2019, 07:11
Please give me a version that is unable to downsize, i'll fix it my way. It just needs some tricks that are hard to explain. You need to put all images in 1 pgn and run it in pngquant. (Drag file on .exe) then all images are reduced without quality loss with max 256 colors and you can separate them in 0001 0002 etc. PNGQUANT does not make the image ugly so its not the same as pallette mode!
Try it on that PIPboy WF mentioned before. Images are already with less than 256 colors (in fact small numbers have only 2 colors). Pure RAW mode won't be generated because it's bigger than the limit, pure palette mode generates jagged images (it's not visible in the gif preview, you need to load the bin file in N&F or upload to the band to see it). Mixed palette mode creates nice WF with ~120kb file size.
Left mixed mode, right palette. Look at the numbers (battery, steps, distance), this is how it looks on the band.
Image Image
Maikeldevil
mysiak wrote: 03 Oct 2019, 07:36
Image Image
Ok, give me some time with this one, ll make all HD even the time numbers, np.
Maikeldevil
Image Image
HD is possible:
https://amazfitwatchfaces.com/mi-band-4/view/4380 Download > fallout
(its hidden under download under that redbull thing (old face a made a while ago) beceause its not my own creation)
extraxt with RAW mode, i think your pallette mode is broken, havent make the numbers transperant (no time) but the original version is unlike the preview not that hd as it should be, dont know why, even if u unpack it with RAW. So i changed the numbers to show you difference, i packed it with my own pallete mode btw.
Maikeldevil
I see what you meen btw. About heart rate and km. But i could fix it same way like time date and weekday. But not today.. no time!
Maikeldevil
I have looked in to it and it seems like an issue that occurs beceause:
- creator used a different miband tool or version
- the png items are compiled a way that triggers this error. You know there are lots of ways that png files can be compiled right? As example my corel photo shop is acting wierd to so i use a combo of paint and photoshop.
- manually change png can fix this problem. Its just the way how they are saved and what tool was used to make em transparant.
Do you want a hd version of that face? I can complete it this week?
mysiak
Post by mysiak »
Interesting.. Your "HD" version really looks better. Couldn't the transparency be the problem for those small PNGs?
HD PIP boy would be nice to have for sure (also these colored versions which I did https://amazfitwatchfaces.com/mi-band-4/view/7167 :) ). If you'll share the "how-to" secret or just HD images, I could update the WFs myself.
Btw. I believe that raw.exe and palette.exe create identical images from bin files. At least that was the case when I tried to compare them.
Maikeldevil
mysiak wrote: 02 Oct 2019, 05:10
I guess you're using RAW mode. Try to pack the WF with palette exe again. Quality of some WFs suffer with pure palette mode, in such case make a "raw.cfg" file in the same folder as the WF.json and put numbers of small images in there (small letters/numbers) - e.g. "11,12,13,14" and pack it with palette.exe. Explicitly defined images will use raw mode, the rest of them palette. You can achieve much smaller bin file size with almost the same quality.
I still wonder, how can you mix both modes? Your explanations is still a bit complicated. Can you explain the steps of making a raw.cfg? Cant find the file!
mysiak
Post by mysiak »
Once you have your WF ready (json + images 0000, 0001, ... , 0070), create an empty file named raw.cfg in the same folder. Then edit it and put images numbers for which you want to use RAW mode and pack the json with palette exe. For example "0,11,12,13,14,60,61,62" - images with these indexes will be packed as RAW, the rest of them as palette.
Maikeldevil
mysiak wrote: 04 Oct 2019, 05:11
Ok then, when i have time i'll test it so i'll make a RAW.cfg file and put in:
0,11,12,13,45
Or
"0,11,12,13,45"
Or
0000,0011,0012,0013,0045
I'll test all XD but if you have a straight answer its apriciated!
mysiak
Post by mysiak »
The first option, just numbers without quotes works fine.
cowborgs
Post by cowborgs »
thank you very much, you are absolutely right, thank you again.
Maikeldevil
mysiak wrote: 04 Oct 2019, 11:56
Ok, i used your method and mine and created
Ps: download the falloutpiptest file XD. HD enough? I think you can easy recolor these the way i edited it! Hope you like it!
:-D
Maikeldevil
Only pipboy is walking slower now-_- no idea why:-(
mysiak
Post by mysiak »
Maikeldevil wrote: 04 Oct 2019, 16:04
:-D
Thanks a lot, it really looks better. I'll reuse the source images and give you the credit :) I noticed the slower animation too, but interestingly when I rebuilt your WF with pure palette mode, it was going in normal speed - have you used RAW mode for animation images?
But, if we return back to the initial question which started this discussion, it doesn't really matter how you generate/pack/optimize source PNG pictures, some of them require RAW mode and won't work correctly with palette mode (especially small transparent images). :)
Maikeldevil
mysiak wrote: 04 Oct 2019, 17:00
:-D
No i made a mistake to include image 0000 in raw, that made all slower (replaced last item now it works :-) ) Well thanks for your tips! Perhaps it will come to use sometimes! My faces doesnt need this method because i make my images costum for palette without quality loss. So you see, everyone has an own way of designin XD. I hope you enjoyed our combined strenght of making faces more beautifull :D
mysiak
Post by mysiak »
Maikeldevil wrote: 04 Oct 2019, 17:23
Definitely yes, I'm always happy when I learn something new :) And thanks for the explanation, RAW mode for 0000.png might be useful to make the animation slower without the need to have double amount of frames (I think that WFtool creator mentioned it already, but I didn't understand it before).
mysiak
Post by mysiak »
@lvpokka - is it possible to have distance in miles instead of kilometres? If yes, how to define it please? Thanks!
lumenvindex
Been thanked: 49 times
Post by lumenvindex »
mysiak wrote: 06 Oct 2019, 06:00
There is no way to switch the units on a watchface level - there is only one Distance subsection with only one SuffixImageIndex. But there is a Unit section in MiFit app. Maybe you should try switching it.
MESS WITH THE BEST
DIE LIKE THE REST
mysiak
Post by mysiak »
Switching the units in Mi Fit changes them in Mi Fit and band/status section, but not on the WF - they are still in KM. I was hoping that it's possible to hard-code the imperial units (something like DD-MM vs MM-DD date format).
lvpokka
Post by lvpokka »
Tested inherited property for miles and it's not working) available only km for preview.
Are you sure that switching in MiFit km to miles not recalculating numbers on MiBand4? check that one more time, also switch language to UK or another parameters of you phone) we have lack of testing in this area
mysiak
Post by mysiak »
Phone language UK or US, Mi Fit metric:
Band: WF 2.31km, status 2.31km
Mi Fit: 2.31km
Phone lanugage UK or US, Mi Fit imperial:
Band: WF 2.31 (km), status 1.43mi
Mi Fit: 1.43mi
Not sure what else to test, WF does not recalculate the value. Date format was changed on the default WF between DD-MM and MM-DD when I switched UK-US phone language, so I'm sure that it synced with the band.
Btw. it's not a big issue, I am a strong believer in metric units. :D Just saw this question somewhere and it kept me wondering..
filipemcalmeida
Post by filipemcalmeida »
Hello. Is it possible to provide a .json file with all the options we have to make a Watchface (for last version)?
I have been using version 1.3.7 on my watchfaces, but I wanted to update and wanted to know all the possibilities I have to do something different ...
lumenvindex
filipemcalmeida wrote: 08 Oct 2019, 19:29
Here is my "all sections" json. It should be up to date. I think.
right_order.zip
(1.34 KiB) Downloaded 189 times
MESS WITH THE BEST
DIE LIKE THE REST
filipemcalmeida
lumenvindex wrote: 09 Oct 2019, 02:33
Here is my "all sections" json. It should be up to date. I think.right_order.zip
Thanks.
Users browsing this forum: Bing [Bot] and 2 guests
