搜索找到 19 个匹配
Return
Wilco
06 9月 2019, 16:56
Jump to forum
Jump to topic
Re: Discussion of watch faces for Mi Band 4
lvpokka 写了: 06 9月 2019, 16:42
remove
"DrawingOrder": "1234"
it's not valid
Thanks. Did remove that line and upload it with Notify&Fitness. Now it's working again.
I will notify the owner of this design.
IamFensterbredl
26 9月 2019, 11:34
Jump to forum
Jump to topic
Re: [ANALOG] Mix-colored hands
Anyways, I am trying to figure out the issue here, but it just won't work.
The same hand, but 2 different instances.
I took away the minute hand so I have 3 hands (1 hour;2 second) in total but no change.
.bin for further testing is attached if anyone is bored enough to care.
The finished one ...
lumenvindex
26 9月 2019, 12:16
Jump to forum
Jump to topic
As I've heard, the CenterImage PNG on BIP was able to rotate with hands.
This feature is disabled on Mi Band - CenterImage stands still.
jfernandezcaro
15 7月 2019, 19:23
Jump to forum
Jump to topic
Re: MiBandWFTool
I found out a complete list of accepted parameters on a chinese forum called bandbbs. Attached, I hope it helps:
It contains 2x json files. One with Chinese explanations, another in plain format.
Also a picture showing how it looks like.
hyippiemon
02 9月 2019, 02:57
Jump to forum
Jump to topic
Re: MiBandWFTool
[mention]cndjonno[/mention]
I don't know if that's an issue, but there are several examples which prove that it's possible to show all 12 months with 10 images.
lazimk
05 9月 2019, 20:36
Jump to forum
Jump to topic
Re: MiBandWFTool
[mention]lvpokka[/mention]
Also, In addition (as suggestion),
In generated previews, animations included in WF are repeating again and again even if i set RepeatCount = 1.
If Generated Preview could follow Repeat count , it would be nice
lumenvindex
09 9月 2019, 07:17
Jump to forum
Jump to topic
Download WF_Builder 1.0.4
1.0.4
Added [F9] hotkey for fast switching to/from Selective ...
lumenvindex
23 9月 2019, 10:17
Jump to forum
Jump to topic
Re: MiBandWFTool
is exactly the same
Nope. It has BatteryConfig section.
"Battery": {
"BatteryConfig": {
"BoxWidth": 0,
"Alignment": 0,
"Order": 0
"Text": {
"TopLeftX": 90,
"TopLeftY": 20,
"BottomRightX": 117,
"BottomRightY": 31,
"Alignment": "Center",
"Spacing": 1,
"ImageIndex": 11,
"ImagesCount ...
mediatouch
06 7月 2020, 04:08
Jump to forum
Jump to topic
Re: MiBandWFTool
Well.., my first Band 5 WF complete and works well! ;)
Here is the all bundle:
Waiting for an upload category...
Pebbler
05 8月 2020, 09:36
Jump to forum
Jump to topic
feedback on 2.1.4
Hi, have been using it since Mi Band 4, great tool!
Found some inconsistency between generated preview and real device display:
In PreviewStatesV2.1.4.json, when "Bluetooth" is set to false, Status.Bluetooth.ImageIndexOn is shown, and ImageIndexOff is shown when Bluetooth is true. I find it ...
diopter
13 8月 2020, 10:15
Jump to forum
Jump to topic
Re: MiBandWFTool
Here you have:
- my BIN
- the GIF created by watchface.exe from json compilation
- the extracted first image from GIF
- a photo of my MI Band 5 with this watch face
DelimiterImage.zip
As you can see, the progress bar background and date delimiter point are visible on MI Band, but not in the ...
14 8月 2020, 17:58
Jump to forum
Jump to topic
Re: MiBandWFTool
Lienarhba, we have no limits. If you have any problems, please contact us.
diopter
17 8月 2020, 19:49
Jump to forum
Jump to topic
Re: MiBandWFTool
OK, animation speed IS a firmware bug, sorry.
But:
Unpacking stock WF "Aurora Glass": Trace|12.2.3 'ImageIndex': 63
Trace|12.2.4 'ImagesCount': 6
Debug|Generating previews...
Error|System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei WatchFace.Parser ...
franluciani
23 8月 2020, 19:59
Jump to forum
Jump to topic
Re: MiBandWFTool
lvpokka 写了: 21 8月 2020, 15:11
... Still not clear, but try to decompile it and check SpacingY & SpacingX, probably it help you
i got it and this help me. thx
diopter
26 8月 2020, 12:45
Jump to forum
Jump to topic
Re: MiBandWFTool
"Alarm" - preview bug
"Text": OK
"ImageOn": OK
"ImageOff": OK
"ImageNoAlarm": The red line in my example should start at X=0 and Y=17, but starts at the position defined in "Text"
On MB5 all works like expected.
diopter
26 8月 2020, 21:12
Jump to forum
Jump to topic
Re: MiBandWFTool
Next preview bug:
"StepsProgress": - "CircleScale":
MB5 stops drawing the progress bar if "EndAngle" is reached, preview drawes around...
franluciani
18 9月 2020, 14:31
Jump to forum
Jump to topic
Re: MiBandWFTool
Bug report: the comands TopCenter and BottomCenter to align numbers doesn't work properly, allways align as i put Center. I don't know if this problem from the tool or MiBand5 but doesn't work.
Also the comand TopRight and BottomRight move the text in y-y when the number increase one digit (for ...
jefoce
25 11月 2020, 14:16
Jump to forum
Jump to topic
[4.0] XMI Watch - Mi Band 4 | 5 | 6 (Editor + Converter)
lvpokka thanks a lot for *.bin support
My WatchFaces
XMI Watch
https://i.postimg.cc/8ctZj8J9/icon.png
Version: 4.0 Release (auto-update)
Platform: Windows ( .NET Core 3.1 )
Developer: jefoce
Official site: xmi
Documentation: docs
New:
Saving format for app ...
