搜索找到 11 个匹配
Return
lvpokka
06 9月 2019, 16:14
Jump to forum
Jump to topic
Re: Discussion of watch faces for Mi Band 4
[mention]Wilco[/mention] send me your watchface!
[mention]mysiak[/mention] chnage speed to 5 or more
lumenvindex
25 9月 2019, 10:38
Jump to forum
Jump to topic
Re: How to make the text grow to the left?
Alignment to [Smth]Center and [Smth]Right works only if there is enough space between X1 and X2 (X2 must be larger than X1) for all the images that must be shown at the moment. Otherwise, images will be drawn from X1.
Same works with Y axis. Alignment to Center[Smth] or Bottom[Smth] works only if ...
lvpokka
08 7月 2019, 12:57
Jump to forum
Jump to topic
MiBandWFTool
Author
lvpokka
Tool Description
4. Mi band 5 supports 15,499,008 colors ...
lvpokka
08 9月 2019, 09:05
Jump to forum
Jump to topic
Re: MiBandWFTool
v1.4.0
https://yadi.sk/d/hZnqJhUsUK6zow
- Added image quantization converter algorithm, it will compress image if it will have too much palette colors.
-- Will not affect RAW images. Added flag (ForceImageCompressor) to config
- If animation RepeatCount is 1, it will repeat only once
- Gif animation ...
lumenvindex
09 9月 2019, 07:17
Jump to forum
Jump to topic
Download WF_Builder 1.0.4
1.0.4
Added [F9] hotkey for fast switching to/from Selective ...
lvpokka
19 9月 2019, 10:21
Jump to forum
Jump to topic
Re: MiBandWFTool
nope) limit of colors is 255, do what you want with it...
To use palette mode you can use paint.net and save it with 8 bit, or use JUST one background raw image by using raw.cfg
if you have 3 results of file size then there is 100% using mixed raw images with palette mode
lumenvindex
26 9月 2019, 18:28
Jump to forum
Jump to topic
Re: WF_Builder (watchfaces for Mi Band 4)
mysiak 写了: 26 9月 2019, 16:38
Did I miss something? :)
There IS exe in the archive. Your antivirus must have eaten it. :mrgreen:
lumenvindex
27 9月 2019, 08:17
Jump to forum
Jump to topic
mysiak 写了: 27 9月 2019, 07:08
share the au3 file
Only if you promise me not to share it with anyone else. :D Mail me about it (see help message in any version of a program).
lumenvindex
01 10月 2019, 17:21
Jump to forum
Jump to topic
Well, the FileOpenDialog function returns a string with a list of filenames. On Windows XP this function places last filename at the begining. On other versions of Windows this behaviour has changed - filenames list is sorted alphabetically.
Will make some workaround for this situation in 1.0.1 ...
lumenvindex
02 10月 2019, 07:32
Jump to forum
Jump to topic
mysiak 写了: 02 10月 2019, 05:05
So you probably don't need to do anything, maybe just raise a warning
I'll better sort the filenames array for WinXP. You can now try WF_Builder 1.0.1 (first message updated).
lumenvindex
02 10月 2019, 08:40
Jump to forum
Jump to topic
mysiak 写了: 02 10月 2019, 08:23
Just wondering - is this new FileOpenDialog going to show on all Windows versions or is it exclusive to XP?
Oops, this window is for debugging purposes only, I just forgot to remove it. It won't show on other systems than XP.
UPD: Recompiled the binary without it. Redownload, please. Sorry.
