Reglas del Foro
Avatar de Usuario
Been thanked: 1044 times
Contactar:
Mensaje por SashaCX75 »
v18.1
Version 18.1
Última edición por SashaCX75 el 10 Sep 2026, 17:16, editado 54 veces en total.
Avatar de Usuario
Contactar:
Puckersunch escribió: 24 Abr 2026, 10:23
Could you advise, what I am doing wrong? The font is copied into the fonts folder inside the assets folder of the project.
Please describe in more detail what you are doing. Judging by the error message, the editor cannot find the font file.
Puckersunch
Contactar:
Mensaje por Puckersunch »
I have edited the Watchface to feature several Fields with the same font:
Imagen
This Font is also already copied in the fonts folder:
Imagen
However, once I click on the button to pack the Watchface, I get the posted error message.
Avatar de Usuario
Contactar:
Puckersunch escribió: 24 Abr 2026, 14:57
If the error occurs not during the preview but specifically when packaging the dial, please send me the project in which the error occurs and I will look into it.
Puckersunch
Contactar:
Just tested it again, it's specifically when packaging. Will send the Link via DM.
Avatar de Usuario
Contactar:
Puckersunch escribió: 24 Abr 2026, 19:33
An error in the editor. It occurs if the font extension is written in uppercase letters. I’ll look into why this is happening and fix it in future versions.
Avatar de Usuario
Contactar:
Version 17.0
Archive
Installer
EmaPolice
Contactar:
Mensaje por EmaPolice »
Guys I have a question. When I create my watchface and when I use digital time by font or PNG images, how I can avoid the change continuous of position of number? For example, in terms of space occupied, 11:11 takes up less space than 00:00. How can I make this space uniform?
Avatar de Usuario
frankh93
Has thanked: 26 times
Contactar:
Mensaje por frankh93 »
EmaPolice escribió: 30 Abr 2026, 19:53
It shouldn't happen if you use png images for the clock cause you have to use images with the same dimensions (width and height) to use them. Just be sure to enable the option to add zeros to both hour and minutes digits and it should be fine. But if you wanna use font file it's kinda complicated cause it's gonna follow the tracking of the font itself.
Avatar de Usuario
Contactar:
If you are using images, they should all be the same size. If you are using a font, you can centre-align the text.
EmaPolice
Contactar:
frankh93 escribió: 30 Abr 2026, 20:08
SashaCX75 escribió: 30 Abr 2026, 20:53
OK, I'll take a closer look. My problem is that when the number 1 appears, it messes up the position because it's smaller. I'm basing this on the font, and even if I set it to center alignment, the problem persists.
https://ibb.co/BV8nn4qm
https://ibb.co/zHJ2T5rL
Avatar de Usuario
frankh93
Contactar:
@EmaPolice as I said, the best you can do is to use the numbers as images. As they gotta de the same dimensions (width and height) it should fix your problem on the spacing
EmaPolice
Contactar:
frankh93 escribió: 01 May 2026, 08:49
II'm working on this, thanks
Avatar de Usuario
Contactar:
You can also create the separator as a stand-alone text element and position it where you want. Then create the hours using text and align them to the right. Create the minutes using text and align them to the left.
EmaPolice
Contactar:
Using PNG or font?
Avatar de Usuario
Contactar:
EmaPolice escribió: 01 May 2026, 20:23
Using PNG or font?
If your aim is for the separator between the hours and minutes to always remain in the same place, it’s easier to use a PNG image.
But you can also achieve this using a font. In my previous post, I explained how to do this.
Has thanked: 134 times
Been thanked: 21 times
Contactar:
Mensaje por taw_bip »
Use a monospaced font where every character has the same fixed width.
https://fonts.google.com/?preview.scrip ... FMonospace
Avatar de Usuario
Contactar:
Version 17.1
Archive
Installer
Postmortem
Contactar:
Mensaje por Postmortem »
I have an issue with the font colors after importing a watch face. They get a sort of black outline. Here is the before and after unpacking a watch face:
Imagen
Imagen
How do i prevent this from happening?
@SashaCX75
Avatar de Usuario
Contactar:
Postmortem escribió: 21 May 2026, 11:43
I can’t tell from the screenshot exactly what’s going wrong. And I’m not entirely sure what you’re trying to do. Perhaps some artefacts are simply appearing when the dial is unpacked, or maybe a particular element isn’t displaying.
Postmortem
Contactar:
SashaCX75 escribió: 21 May 2026, 17:55
Hello and thank you for the fast reply:
Before:
Imagen
After unpacking:
Imagen
As you can see, there's now a black line around the white clear parts of the number. This happens after i unpack a watchface. The black outline is not present in the original watchface. It's like an under shadow is being added to the font after unpacking.
loznic89
Contactar:
Mensaje por loznic89 »
Hi, is version 17.1 compatible with the Amazfit Bip Max? Thanks and great work with the editor!
Edit:I saw that this is 17.2 beta :D
Última edición por loznic89 el 27 May 2026, 11:19, editado 1 vez en total.
awrun
Contactar:
Mensaje por awrun »
Hi SashaCX75.
I saw that someone is using the 17.2 beta app to create bip max watch faces.
I would like to try it too, but I can't find it. Is it possible to download it somewhere?
The watch is not available here yet, maybe it will be from June 1st, but I thought I would create the watch faces by then.
And thank you for your work, I really liked using your editor for the gts 4 mini.
And sorry for my engilsh.
Avatar de Usuario
Contactar:
No. This is a closed-beta version.
awrun
Contactar:
Mensaje por awrun »
Ok, I'll wait for the final version then. 😇
Thanks in advance.
Avatar de Usuario
frankh93
Contactar:
SashaCX75 escribió: 29 May 2026, 06:00
@SashaCX75 is there a way to join the closed beta? I'm interested on it, also could help to test and find bugs (as watchface maker I use your editor pretty often)
Responder
Volver a “Watchfaces tools”
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 7 invitados
