Правила форуму
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
v18.1
Version 18.1
Востаннє редагувалось 10 вересня 2026, 17:16 користувачем SashaCX75, всього редагувалось 54 разів.
Аватар користувача
JAGGER писав: 27 лютого 2026, 14:26
The hourly value matches BIP 6 in the editor. However, the foreground and background are reversed in the minutely value. See photo.
Please send me the project where the error occurs. That will make it easier for me to test it.
Аватар користувача
Has thanked: 438 times
Been thanked: 2141 time
Повідомлення asoo »
SashaCX75 писав: 26 лютого 2026, 17:46
Version 16.1
Hello Sasha,
When I try to overlay the numbers (effect for colors) in the editor, the foreground and background are swapped!
Best regards, JAGGER
Зображення
I've encountered this problem before, and it's not a issue of program , but rather a requirement of the program's digital time generation method. If in widget "Digital time" if you use layer
Seconds , Minute , Hour
Зображення
after you packed, elements seconds , minute , hour it will create in one widget ( normal_digital_clock_img_time )
It won't separate the widget into:
normal_digital_clock_img_time_hour
normal_digital_clock_img_time_minute
and that's the problem. When it doesn't separate them,
it combines all the "digital_clock_images" into a single widget.
Therefore, the layers aren't arranged correctly as you want.
if you use layer seconds , minute , hour script will pack like this :
Код: Виділити все
            normal_time_hour_text_font = hmUI.createWidget(hmUI.widget.TEXT, {
              x: 193,
              y: 88,
              w: 150,
              h: 65,
              text_size: 52,
              char_space: 19,
              color: 0xFFFF8C00,
              line_space: 0,
              align_v: hmUI.align.TOP,
              align_h: hmUI.align.LEFT,
              // padding: true,
            normal_digital_clock_img_time = hmUI.createWidget(hmUI.widget.IMG_TIME, {
              hour_startX: 171,
              hour_startY: 103,
              hour_array: ["Time_0.png","Time_1.png","Time_2.png","Time_3.png","Time_4.png","Time_5.png","Time_6.png","Time_7.png","Time_8.png","Time_9.png"],
              hour_zero: 1,
              hour_space: 0,
              hour_angle: 0,
              hour_align: hmUI.align.LEFT,
              minute_startX: 169,
              minute_startY: 179,
              minute_array: ["Time_0.png","Time_1.png","Time_2.png","Time_3.png","Time_4.png","Time_5.png","Time_6.png","Time_7.png","Time_8.png","Time_9.png"],
              minute_zero: 0,
              minute_space: 0,
              minute_angle: 0,
              minute_follow: 0,
              minute_align: hmUI.align.LEFT,
            normal_time_minute_text_font = hmUI.createWidget(hmUI.widget.TEXT, {
              x: 187,
              y: 164,
              w: 150,
              h: 79,
              text_size: 57,
              char_space: 14,
              color: 0xFFFF8C00,
              line_space: 0,
The easiest solution is to move the seconds layer to the bottom.
Зображення
Then after you pack , you'll have separate digital_clock widgets for hour, minute, and seconds.
And the layering will be correct as you want.
if you use layer minute , hour, seconds script will pack like this :
Код: Виділити все
              x: 193,
              y: 88,
              w: 150,
              h: 65,
              text_size: 52,
              char_space: 19,
              color: 0xFFFF8C00,
              line_space: 0,
              // padding: true,
            normal_digital_clock_img_time_hour = hmUI.createWidget(hmUI.widget.IMG_TIME, {
              hour_startX: 171,
              hour_startY: 103,
              hour_zero: 1,
              hour_space: 0,
              hour_angle: 0,
              x: 187,
              y: 164,
              w: 150,
              h: 79,
              text_size: 57,
              char_space: 14,
              color: 0xFFFF8C00,
              line_space: 0,
            normal_digital_clock_img_time_minute = hmUI.createWidget(hmUI.widget.IMG_TIME, {
              minute_startX: 169,
              minute_startY: 179,
              minute_zero: 0,
              minute_space: 0,
              minute_angle: 0,
              minute_follow: 0,
Preview on Bip6 if you layer hour,minute,second
Зображення
Зображення
Аватар користувача
@asoo That's why I usually ask for the entire project to check for errors. Sometimes the problem arises in a completely different place than you think.
I think it can be considered an editor error. In any mode, the preview in the editor should match what will be displayed on the clock.
Perhaps, as you said, the problem is caused by the fact that if you don't change the order of hours, minutes and seconds, they are created by a single widget. This is done so that the minutes can be set to follow the hours and you don't have to set separate coordinates for them (and for the seconds too). But few people use this feature. In addition, this can now be done using fonts, and there is a separate widget for this in the numeric time block in the editor. So maybe we could remove this option and always separate the hours, minutes and seconds into separate widgets? Maybe that would cause less confusion?
Аватар користувача
Повідомлення asoo »
SashaCX75 писав: 27 лютого 2026, 18:49
Based on everything you've said, I agree. And I think removing that option should not cause any problems, because normally, every time I create a digital time, I always arrange the HMS layout first, as I want the widgets to be separate.
I think separating the HMS widgets makes them work better in custom script.
Emiliomc
З нами з: 31 липня 2022, 10:43
Повідомлення Emiliomc »
Sasha, integration with Tasker would be a real revolution.
Аватар користувача
JAGGER
З нами з: 12 січня 2026, 10:46
Has thanked: 11 times
Повідомлення JAGGER »
SashaCX75 писав: 17 лютого 2026, 15:05
Hi, I've uploaded the ZIP file. If you want to take a look, here's the link; it's the last file, the one that starts with "Test"! The overlay is displayed correctly in the editor, but not on the clock where the minutes are. I used this effect because I was too lazy to display the numbers in a graphic like that ;-) Unfortunately, it's unusable because the minutes are swapped. Best regards
https://amazfitwatchfaces.com/bip/view/44668
Download "Test"!!!
Аватар користувача
JAGGER
Unfortunately, I'm not a program author like you or my brother, who works at Audi Ingolstadt.
As a user, it looks to me like the overlay is simply reversed for the minutes. Because the overlay is correct for the hours!
Best regards
Аватар користувача
Повідомлення asoo »
JAGGER писав: 27 лютого 2026, 23:05
Download "Test"!!!
Based on the files you submitted, my review confirms that all the issues are as I previously described:
viewtopic.php?p=21792#p21792
This is the project file after the modifications I mentioned.
File use compress by Winrar Version 7.20 https://www.rarlab.com/download.htm
The project can be opened and edited with Editor Version 16.1 viewtopic.php?p=21787#p21787
File that Fixed issue in this project
This is not a watchface file.
This file contains:
- The project you mentioned
- Watchface.zip
Therefore, please uncompress before using it.
test_bip6_quantenworld_w_v1_aod_de_jagge-869952-3c42bde123.rar
(2.07 МіБ) Завантажено 110 разів
It now displays like this on Bip6.
Зображення
Hopefully, this is helpful.
Аватар користувача
Emiliomc писав: 27 лютого 2026, 21:40
How do you envision this integration with Tasker, and for what purpose?
Emiliomc
Assign a Tasker task to a button created with your application (Task Shortcut). Or to one of your application's default shortcuts. Many applications and launchers contain "Tasker Shortcuts" (to a Tasker task). Button Mapper, Nova Launcher, etc.
Аватар користувача
But Tasker works on your phone. And the watch face is on your watch. The watch face cannot send data or commands to your phone.
For this to work, you need an intermediary application on the watch that will transmit commands to the phone. And you may need an intermediary application on the phone that will transmit commands to Tasker. Even if someone makes these applications, most users will not use them and will find them too complicated.
Emiliomc
I understand it can't be easy. You're right. But on the other hand, one thinks we could, for example, reply to WhatsApp messages from the watch... replies that would then go to a phone. Now, the Balance 2 doesn't have Amazon Alexa. They've replaced it with Zepp Flow (which is more limited). Perhaps with Amazon Alexa on the watch, I could turn a smart bulb on/off. With Zepp Flow, that's impossible. One also thinks about the feature some watches have that locates your phone by sending a command that makes it vibrate. I don't know, I think maybe something could be done. It would certainly be revolutionary and very practical. Let's not forget that the watch records activity and transmits it to the watch itself. Anyway, I don't know anything about programming. I've just been an average Tasker user for over 10 years.
Аватар користувача
Version 16.1
Archive
Installer
cjlin
З нами з: 09 червня 2021, 12:02
Повідомлення cjlin »
Where can I find a user manual or instructional materials?
Аватар користувача
Повідомлення asoo »
cjlin писав: 12 березня 2026, 08:46
You can find links related to Lessons and Guides
on the program's About page, but they aren't in English. However, they aren't difficult to understand.
Preview About page
Зображення
cjlin
What are the minimum and maximum heart rate ranges in Amazfit Balance 2?
cjlin
Can the position of the displayed number change over time?
Аватар користувача
cjlin писав: 13 березня 2026, 00:21
I suppose it varies depending on age. It may also depend on other factors.
Аватар користувача
cjlin писав: 13 березня 2026, 03:01
Could you please specify exactly what you’d like?
cjlin
SashaCX75 писав: 13 березня 2026, 18:23
I want numbers to change both their content and position over time, like a second hand, displaying the number 5 at 5 seconds and at a 30-degree angle, and the number 30 at 30 seconds and at a 180-degree angle.
thank you
Аватар користувача
Повідомлення asoo »
cjlin писав: 14 березня 2026, 04:32
thank you
You mean like this :
Preview
Зображення
if yes , you can do it by use custom script. You can unpack and view script in index.js at the additional section.
https://amazfitwatchfaces.com/balance/view/744
However, there may be other, potentially better ways to do this, depending on the individual scriptwriter.
Mano.Laikrodis
З нами з: 06 березня 2026, 17:56
Повідомлення Mano.Laikrodis »
Hello, I would like to ask why does adding ttf does not work? I mean it shows as though it is added, but it is still using system fonts i guess. How do i make it use my added font?
Edit: All is working, somehow my system can use this ttf font, but editor does not, although other fonts do work. Sorry.
demiurg1
З нами з: 23 лютого 2020, 22:49
Has thanked: 23 times
Been thanked: 17 times
Повідомлення demiurg1 »
Question: https://amazfitwatchfaces.com/balance/view/744
Can this watch face be converted into a watch face compatible with the GTR3 using the editor?
I was unable to import this watch face into the editor.
Аватар користувача
Повідомлення asoo »
demiurg1 писав: 15 березня 2026, 10:48
Editor Version 16.1 can unpack and convert this watchface but after convert you must edit some value in " user_script.js" suitable for screen sizes of 454x454 (GTR3).
And after conversion, the current temperature section will not be displayed.
Because, if I remember correctly, ZeppOS 1 does not support the current temp (Value with angle) widget.
This file is project after unpack , convert and edit user_script.js
combattaddscriptv2_4_sasha_GTR_3.rar
(2.86 МіБ) Завантажено 93 разів
If possible, next time your question relates to a watchface you want to convert, it's recommended to ask in the watchface section of that device.
I will not be taking any further action.
If you require any further corrections, please proceed yourself.
demiurg1
Thank you very much.
I imported this watch face design for the GTR 3 into the editor without any problems. Now I'll work on it a bit and upload it to my GTR 3 smartwatch. Once everything is OK and I've verified it, I'll post this modified watch face design in "WatchFaces," which is here.
I added:
Unfortunately, I was unable to create numerical seconds running around the circumference of the watch face for the GTR 3. That's what I cared about most. It's probably not possible for this model.
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 7 гостей
