Inquire about problems that occur when creating a watch face.
Hi, @asoo
Thank you very much for the quick response.
I made the suggested changes to the index.js file, then compressed it with a zip file.
The problem remains the same. I noticed that in my index, the scale_call() function is inside: if (screenType != hmSetting.screen_type.AOD) { ...
If you don't mind, could you review the attached index.js file?
Excuse my question, thank you very much in advance.
- Attachments
- index.js
- (21.34 KiB) Downloaded 65 times
- Has thanked: 420 times
- Been thanked: 2122 times
If you want your project reviewed,lobianco wrote: 21 Sep 2025, 18:57Hi, @asoo
i recommend submitting your entire project.
If you only want to verify the validity of a script,
you can send only index.js . But you want to check the entire project, I think you should be attach all file about your project. The problem might not be with the script, but rather with other components, including the display order.
The index.js script you provided is correct.
However, there might be a display issue. When you click the color-changing button, the progress bar might not change. If you want the change to be immediate when the button is pressed, you can do this in two ways:
1. Add scale_call() in Button_1 widget
code 1
Button_1 = hmUI.createWidget(hmUI.widget.BUTTON, {
x: 156,
y: 156,
w: 100,
h: 100,
text: '',
color: 0xFFFF8C00,
text_size: 25,
press_src: 'btn.png',
normal_src: 'btn.png',
click_func: (button_widget) => {
click_Color();
scale_call()
}, // end func
}); // end buttonOR
2. Add the script ( normal_battery_circle_scale.setProperty(hmUI.prop.MORE,) to the file user_functions.js
code 2
let colornumber_main = 1
let totalcolors_main = 7
let colors = "0xFFFFFFFF"
function click_Color() {
colornumber_main=1;
else {
if(colornumber_main==1) {
colors = "0xFFC9C9C9"
else {
if(colornumber_main==2) {
colors = "0xFFFFCC00"
else {
if(colornumber_main==3) {
colors = "0xFFBAC095"
else {
if(colornumber_main==4) {
colors = "0xFFFFB3BA"
else {
if(colornumber_main==5) {
colors = "0xFFBAE1FF"
else {
if(colornumber_main==6) {
colors = "0xFFFF9224"
else {
if(colornumber_main==7) {
colors = "0xFFFF0000"
///// add MORE in this
center_x: 207,
center_y: 83,
start_angle: 0,
end_angle: 360,
radius: 27,
line_width: 16,
corner_flag: 0,
// Change color code with variable values in this line
color: colors,
}From the index.js you provided, I made the changes I mentioned earlier and briefly tested it on zeppPlayer, as shown in the image. Some widgets may be missing in the sample image due to the lack of resources and limitations in zeppPlayer's simulation.
ZeppPlayer :
And next time, I also recommend opening a new topic in the GTR's "Watchfaces discussion" forum.
viewforum.php?f=38
This might be more in line with your request.
@asoo
Here is the whole project, I just didn't put it up before because I didn't know I could.
- Attachments
RessensseV4.zip- (150.46 KiB) Downloaded 62 times
@lobiancolobianco wrote: 22 Sep 2025, 11:35@asoo
I have moved your post to a new topic in the relevant forum for easier searching and to avoid confusion with the original topic.
I don't have a gtr mini, so all testing was done on zeppPlayer only. This is the watch face I modified.
You can see the fixes in index.js.
The main issue causing the watch face to malfunction
is the use of "object literals" for setting values.
I'm not sure why it doesn't work when I use the values from the "object literal" in the widget. However, I need to set the value of the object literal in the variable and use that variable in the widget for it to work properly.
Since I was also wondering why I couldn't use the object literal directly in the widget,
Your "Object literal"
const colors = {
1: 0xFFC9C9C9,
2: 0xFFFFCC00,
3: 0xFF479135,
4: 0xFFFFB3BA,
5: 0xFF5D6DD1,
6: 0xFFFF9224,
7: 0xFFFF0000
colorss = colors[colornumber_main]However, I'm not sure of this answer because I haven't found any official documentation.
@asoo
Thank you, it worked perfectly as expected.
If you don't mind, what reading material could you recommend for studying JS for Amazfit development?
I looked at various information from https://docs.zepp.com/docs/intro/. As for JS, I studied from the watch faces that I was interested in. If there was a command set that I didn't understand, I would search for it using google , chatgpt , or other Including asking other knowledgeable people.lobianco wrote: 22 Sep 2025, 15:53@asoo
Hi, @asoo
In the example above, the battery cycle is changing color, as you taught me, but I've run into another problem: changing the color of the battery text element. I've tried everything, but I can't. I looked for a watchface that changes the color of the battery value, but I couldn't find it. Could you help me, if possible?
color: colorss,
radius: 27,
line_width: 16
normal_battery_current_text_font.setProperty(hmUI.prop.COLOR, colorss);
normal_day_text_font.setProperty(hmUI.prop.COLOR, colorss);
normal_battery_current_text_font = hmUI.createWidget(hmUI.widget.TEXT_FONT, {
x: 133,
y: 70,
w: 150,
h: 30,
text_size: 18,
char_space: 0,
font: 'fonts/Panton-Bold.ttf',
color: colorss,
line_space: 0,
align_v: hmUI.align.CENTER_V,
align_h: hmUI.align.CENTER_H,
type: hmUI.data_type.BATTERY,
**hmUI.createWidget(hmUI.widget.TEXT_FONT, {
normal_day_text_font = hmUI.createWidget(hmUI.widget.TEXT, {
x: 133,
y: 320,
w: 150,
h: 30,
text_size: 26,
char_space: 0,
color: colorss, //inicial cor cinza
line_space: 0,
// padding: true,
**hmUI.createWidget.TEXT, {...
normal battery current text_font - does not work
normal_day_text_font - works
color: colorss,
radius: 27,
line_width: 16
x: 133,
y: 70,
w: 150,
h: 30,
text_size: 18,
char_space: 0,
color: colorss,
line_space: 0,
x: 133,
y: 320,
w: 150,
h: 30,
text_size: 26,
char_space: 0,
line_space: 0,
// padding: true,
- Attachments
RessensseV4trytofix_color.zip- (140.66 KiB) Downloaded 61 times
- index.js
- (19.04 KiB) Downloaded 58 times
lobianco wrote: 23 Sep 2025, 22:52Hi, @asoo
Thank you very much in advance.Spoiler
color: colorss,
radius: 27,
line_width: 16
x: 133,
y: 70,
w: 150,
h: 30,
text_size: 18,
char_space: 0,
color: colorss,
line_space: 0,
x: 133,
y: 320,
w: 150,
h: 30,
text_size: 26,
char_space: 0,
line_space: 0,
// padding: true,
I think some of the scripts in the attached file might be corrupted.
I can't unpack it properly, and I'm busy right now. So, I do not like to check your index.js for errors.
I'll rebuild it from the old file I created and add some your script
The problem you mentioned, that you can't change the battery text color, might be due to the widget's property change style.
I recommend that if you've tried to chang properties with ".setProperty( xxxx)" and it doesn't work, try using ".setProperty(hmUI.prop.MORE" to change the property. It's the most effective change I've tested. I recommend typing in all the widget data for when use the ".setProperty(hmUI.prop.MORE" change, because some widgets, even if you use "MORE," if you not put complete information may not work.
From your "user_functions.js", I modified it as follows:
// start user_functions.js
let totalcolors_main = 7; // 7
let colornumber_main = 0; // actual color: 0..6
let colorss = 0xFFC9C9C9;
// Cores Tabs
let colors = [
0xFFC9C9C9, // 0 -> cinza claro (initial)
0xFFFFCC00, // 1 -> amarelo
0xFF479135, // 2 -> verde
0xFFFFB3BA, // 3 -> rosa claro
0xFF5D6DD1, // 4 -> azul
0xFFFF9224, // 5 -> laranja
0xFFFF0000 // 6 -> vermelho
// alterna cor (volta pra 1 se passar do total)
colornumber_main = (colornumber_main + 1) % totalcolors_main;
// pega a cor natural
colors = colors[colornumber_main];
// Atualiza ponteiros and funds
normal_analog_clock_pro_hour_pointer_img.setProperty(hmUI.prop.SRC, `pontHor${colornumber_main+1}.png`);
normal_analog_clock_pro_minute_pointer_img.setProperty(hmUI.prop.SRC, `pontMin${colornumber_main+1}.png`);
normal_analog_clock_pro_second_pointer_img.setProperty(hmUI.prop.SRC, `pontSec${colornumber_main+1}.png`);
normal_background_bg_img.setProperty(hmUI.prop.SRC, `Back${colornumber_main+1}.png`);
// aplica a cor ao círculo a bateria
color: colorss,
radius: 27,
line_width: 16
// normal_battery_current_text_font.setProperty(hmUI.prop.COLOR, colorss); // not work in this case
// use this to change color
normal_battery_current_text_font.setProperty(hmUI.prop.MORE, {
x: 192,
y: 74,
w: 32,
h: 25,
text_size: 20,
char_space: 0,
color: colorss ,
line_space: 0,
align_v: hmUI.align.TOP,
normal_time_hour_text_font.setProperty(hmUI.prop.COLOR, colorss);
normal_time_minute_text_font.setProperty(hmUI.prop.COLOR, colorss);
// end user_functions.js
The battery color changes normally.
I've attached the edited file. For GTRMiNi : You can see edited in index.js.
Hi, @asoo
It worked very well. Congratulations on your teachings and knowledge, and thank you very much for your patience.
Thank you again.
Thank you again.
