Been thanked: 1044 times
Messaggio da SashaCX75 »
v18.1
Version 18.1
Ultima modifica di SashaCX75 il 10 set 2026, 17:16, modificato 54 volte in totale.
samuelsan
Messaggio da samuelsan »
Please, add "Value in Font (day)" to the PAI widget. It only displays "Numerical values ​​(day)".
Thank you.
numagari
Messaggio da numagari »
please guide me to add lunar calendar to custom watch face like photo. thanks everyone
Archive
Installer
There are two installation options to choose from. The old option with an archive. And the new option with an installer. However, the archive option does not work for some users due to paranoid antivirus restrictions on downloaded applications in the latest versions of Windows.
Please let us know which variant is more convenient for you.
seythegamer
Messaggio da seythegamer »
SashaCX75 ha scritto: 30 lug 2025, 06:17
@seythegamer
The watch cannot work with gif files, only with png files. There is animation in the watch faces, it is done with a set of png files.
alright got it,
but is it maybe possible to create animation using png files but for weather icons?
so now weather icons go from 1 to i dont remeber, lets say 31
and i would like to create an animation for each of the weather icons
is it possible to achieve or no?
Not in the editor.
But in principle, it can be done. Although I only remember two such attempts.
rush2112
Has thanked: 121 times
Messaggio da rush2112 »
Thanks ;)
@SashaCX75
Just a quick question regarding the watch's balance: for the next version, could you have the AM and PM displayed in font ?
@rush2112
What's wrong with that?
rush2112
Okay , Thanks ;)
rush2112
SashaCX75 ha scritto: 05 set 2025, 04:34
@rush2112
The attachment you're displaying features the "Hours" font along with Hours plus AM and PM , However, I'm referring to the style shown in the picture. Would you be able to apply that font to the "AM" and "PM" sections?
No. This is a standard widget that only works with images.
CASIONFAN2021
Messaggio da CASIONFAN2021 »
Refuses to load on win 11. i have all the previous versions which work perfectly, but this one came up with a red windows security warning, i clicked run anyway but it refuses to load. stuck on ver 13 until a solutuion presents itself.
@CASIONFAN2021 Download the app from the MS Store
CASIONFAN2021
SashaCX75 ha scritto: 08 set 2025, 14:52
thank you, impressive
UlliT.
Messaggio da UlliT. »
you write:
Excuse me - but i do not understand that all...
i made me first and only watchface with the zepp watchface maker.
Is there a easy way to get that in the Watch face editor for Amazfit watch on ZeppOS?
Or have i start from the beginning?
Greetings
Ulli
Has thanked: 438 times
Been thanked: 2142 times
Messaggio da asoo »
UlliT. ha scritto: 11 set 2025, 06:00
you write:
Greetings
Ulli
When you export a file from Zepp's watchface make,
you'll receive a .zab file. Uncompress the file with WinRAR.
You'll find a .zpk file, and then uncompress it again.
You'll find a Device.zip file.
You can "Unpack" Device.zip by use editor, and to continue working on your project without having to rebuild it.
unpack device.zip with program editor
In most cases, the above instructions will work. It all depends on what widgets you use. If you used text with tags, it will not be recognized when unpacking.
Phantan74
Messaggio da Phantan74 »
I use Watch face editor for Amazfit watch on ZeppOS on PC to create watch face, but when I clicking on the watch face, it shows white space around (like the picture), it should be black.
Please guide me to fix it.
thank you.
https://www.dropbox.com/scl/fi/bmn8c0mv ... 75aod&dl=0
Ultima modifica di Phantan74 il 14 set 2025, 03:33, modificato 2 volte in totale.
Messaggio da asoo »
Phantan74 ha scritto: 14 set 2025, 02:58
thank you.
You should attach the file of the watch face you're using and found issue.
Reporting an issue the way you did is difficult to verify.
The issue could be caused by a number of factors, from generated images to custom scripts, and many more.
Phantan74
asoo ha scritto: 14 set 2025, 03:12
thank you.
Yes, I send you the attached file, please check it for me. Thanks.
Messaggio da asoo »
Phantan74 ha scritto: 14 set 2025, 03:36
The white frame issue is likely caused by the white background of your Bg1.
It is unlikely to be caused by editor.
I've already edited the image to make it transparent.
But what I don't understand is that you enabled the Switchable Background, but didn't take any action (I assume you're waiting to proceed).
Watch_face.zip
(56.94 KiB) Scaricato 133 volte
Phantan74
asoo ha scritto: 14 set 2025, 04:02
Watch_face.zip
Yes, thank you, I understand.
frankh93
Has thanked: 27 times
Messaggio da frankh93 »
@SashaCX75 the compass gets buggy when tapping on the shortcut made in the editor, and also the compass info (pointer rotation and degrees text) gets stuck for sometime and the only workaround to get it working again is to turn off/on screen couple times... is this normal? any workaround?
The watchface I'm working on is attatched, ty in advance
Allegati
BigElegant.zip
(216 KiB) Scaricato 133 volte
Messaggio da asoo »
frankh93 ha scritto: 14 set 2025, 19:42
Since you didn't mention which device you're experiencing this issue on, I'm guessing from you att. file you're experiencing it on the Bip6, as I'm also experiencing this issue on the Bip6.
And as far as I know, this issue doesn't occur on any other devices I own.
So, I don't think the issue is with the editor, but rather with the Bip6 itself.
It seems that if you enable the compass widget to display on the watchface, you'll encounter issues using the compass shortcut, as you mentioned. :I don't know the exact cause, so I can only guess that the problem is with the FW.
There are two ways to fix this:
1. Don't use the compass widget on the watchface; so you will can access it via the shortcut normally.
2. If you use the compass widget on the watchface and then use the shortcut (button) hmApp.startApp({url: 'CompassScreen', native: true }); to access the Compass screen, you must stop the compass before enabling CompassScreen as follows:
Add to the compass button
Codice: Seleziona tutto
if (compass) compass.stop();  // add this
Note : This fix sometimes causes a "screen on duration" issue.
The "screen on duration" may not match your default value. It may increase to 16-30 seconds, but is only happend once time after using the shortcut . Which I don't know why either.
BigElegant_Fix.zip
(200.76 KiB) Scaricato 132 volte
However, if you want to calibrate by accessing the compassScreen home screen via the shortcut, from my testing, once you access the compassScreen home screen and calibrate it until it works, when you return to the watchface, you'll notice that sometimes the calibration on the compassScreen home screen doesn't affect the compass on the watchface. The compass on the watchface still doesn't work, or sometimes it freezes, requiring you to switch between screens for the compass on the watchface to work.
I believe this is due to the Bip6 firmware, not the editor.
The best way to calibrate the compass on the watchface is to shake the watch or flick your hands that you wearing the watch. The compass on the watchface will then work.
These are just solutions from my testing and my understanding. So maybe someone else can answer your question better.. I hope this answer is helpful.
rush2112
@asoo
Torna a “Watchfaces tools”
Visitano il forum: Nessuno e 8 ospiti
