请问有zeppz系列的表盘吗
13785318899
- Has thanked: 429 times
- Been thanked: 2132 times
From the information I've found, I think you can use the GTR2 watchface on the Zepp Z, as they both use the same OS and have the same screen size.
https://amazfitwatchfaces.com/gtr/fresh ... R_2&paid=0
However, I've never tested it because I don't have a Zepp Z.
So, you'll have to manage your own risk when testing.
Text translated by Google Translator :
根据我找到的信息,我认为你可以在 Zepp Z 上使用 GTR2 表盘,因为它们使用相同的操作系统,屏幕尺寸也相同。
不过,我从未测试过,因为我没有 Zepp Z。
所以,测试时你必须自行管理风险。
所以,测试时你必须自行管理风险。
- SashaCX75
- Has thanked: 14 times
- Been thanked: 1043 times
I'm not sure that will work. As far as I remember, the watch faces were assembled for a specific model and could not be installed on another model. Several bytes in the watch face file header were changed to encode the model. I don't remember there being a watch face assembler for Zepp Z.
Translated by Google Translator :
不確定這是否可行。據我所知,當時錶盤是針對特定型號組裝的,無法安裝在其他型號上。錶盤檔案標題中會修改幾個位元組,以此編碼型號。我不記得有針對Zepp Z的錶盤組裝工具。
