Watchface Maker: Help With 3 Issues
Reglas del Foro
Responder
BenS
Contactar:
Mensaje por BenS »
Hi There,
I'm trying to edit an existing watch face but it's been a year or more since I created it – I'm making edits on a duplicate of the original. Specific issues...
1. TEXT
Imagen
  • The text has defaulted to normal text and no longer uses images.
  • How do I revert it or better yet, set the font?
2. CAN'T EXPORT
  • Always gets stuck on 'action in progress' but nothing happens after a good 5mins.
  • How do you export a download now?
3. CAN'T INSTALL
Imagen
  • When I click the 'Bridge' menu, I no longer see the 'Install' option with the barcode etc.
  • If I click execute, I see a 'Please connect a device or simulator'.
  • How do I see the barcode option so I can install via dev mode in app?
Imagen
Any help or pointers in the right direction much appreciated.
Chers, Ben
BenS
Contactar:
Mensaje por BenS »
After several days, still can't figure this out sorry.
Does Watchface Maker only use fonts now?
I can't find documentation on how you set the font and the image-based text which is documented, doesn't seem to exist - is that right?
Any help much appreciated.
Has thanked: 134 times
Been thanked: 21 times
Contactar:
Mensaje por taw_bip »
I don't think there are many people here who use the online Zepp watchface tool. I will say that the times I've used it, I've walked away from my laptop and done other things when it exports because it takes so long.
You'd probably have better luck contacting Zepp directly on their Discord, specifically in the wf-creators channel.
https://t.zepp.com/t/b6e70
Avatar de Usuario
Been thanked: 1044 times
Contactar:
Mensaje por SashaCX75 »
You cannot use your own font. You can use images as before. The screenshot shows an example of how to use images for the day of the week.
I set the watch face using a QR code. But I rarely use this site.
Imagen
Avatar de Usuario
Contactar:
It seems that if you select a custom preview instead of a generated preview when exporting, it works faster. But I'm not sure.
BenS
Contactar:
Mensaje por BenS »
Thanks for the replies, much appreciated.
SashaCX75 escribió: 20 Jun 2025, 16:35
I guess I don't understand why the tool has auto-converted my image-based day/date to text only - is that normal?
When I initially opened the watch face, it looked correct. But after subsequent opens, it somehow got converted to text - I was simply trying to update the background image. Makes no sense - right?
taw_bip escribió: 20 Jun 2025, 12:47
If nobody uses Watchface maker these days, what tool do you all use now?
Cheers
Avatar de Usuario
Has thanked: 438 times
Been thanked: 2141 times
Contactar:
Mensaje por asoo »
BenS escribió: 21 Jun 2025, 18:19
Cheers
If you use windows you can try this program :
BenS
Contactar:
Mensaje por BenS »
asoo escribió: 22 Jun 2025, 13:27
If you use windows you can try this program : Watch face editor for Amazfit watch on ZeppOS
Unfortunately I'm not on Windows. Anyway, I had to re-make the watch face from scratch.
Cheers
Responder
Volver a “Watchfaces tools (discussion)”
¿Quién está conectado?
