gingerbeardman
Been thanked: 11 times
Post by gingerbeardman »
- #222222 grey @ 32px: %,♥
gingerbeardman
If anybody uses it please let me know!
Been thanked: 2122 times
Thank you very much.
I think it is another useful tool for me to create font sets.
gingerbeardman
Let me know what you like or don't like about it, and I will improve the tool.
gingerbeardman wrote: 12 Apr 2025, 13:13
Personally, I like it.
I like the part where you can input your own words, making it very convenient to create a set of characters that you only want to use.
What should be added is in the setting of
- Left - Right margin
- Top - Botton margin
- Setting the background color as transparent or color and font
- And the function that combines the created files into a single zip file for easy downloading and use.
I usually use
to create fonts, but this one cannot enter the desired words to create an image.
It will only create images according to the managed script.
gingerbeardman
I can't promise all of these features but I'll add some of them soon!
Currently margins are present but preset.
Background colour should be easy.
ZIP file I will try, but I think it's complicated—is it an important requirement?
gingerbeardman wrote: 12 Apr 2025, 14:28
As far as I've tried it, I think what I have is good enough to use.
But the recommendations I have made, I think if there were more, it would make the page more interesting and more usable.
In the zip section I tried to make chatgpt create an example using your script as a base. It works fine. I have sent you a private message. Hope it will be useful for you.
gingerbeardman
Got it, thanks that was very useful!
I've added background colour (default: transparent) and zip download.
conan777
Post by conan777 »
Congratulation, good job.
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Nice, but You can't generate just , if You want this type of separator, also will be awesome to have option to change preview shape from square to round maybe?
One more think... Maybe You can add option to set font as transparent with background (cutted / not filled) ?
Like this - > Image
Sometimes this is very useful - especially for wf's with many colors.
Anyway... Good job!
gingerbeardman
I'll put these on my to-do list. I can't promise or give an estimate when I might get to them.
This file is gen. by ChatGPT. It can work to some extent. It can create a text outline and can choose the color and thickness. It can also create "cut out" style by choosing the transparency and color level using Font Opacity.
As far as I have checked the script and tested its usage, it works fine.
index.html can be enabled offline using on Firefox browser (including Chrome, Edge, Brave, etc.)
✅ No need to install anything else because it uses:
✅ Pure HTML + CSS + JavaScript
✅ Use system fonts or fonts selected from TTF files
✅ Use <canvas> which is supported by all modern browsers
✅ Use JSZip loaded via CDN (no installation required)
I hope it will be useful for those who are interested in modifying it further.
Need download JSZip script on internet at the first time.
After downlload JSZip you can use it offline until you do a hard reload or clear the cache.
index.rar
(2.29 KiB) Downloaded 150 times
Full Offline
CHATGTP_Generator_files7Fulloffline.rar
(28.51 KiB) Downloaded 144 times
TRK88PL
Post by TRK88PL »
Interesting... So maybe I can put more colors and few extra things? ;) Download file and check how this look - should be responsive, darken, and with extra tricks :D
Changelog compared to asoo work :)
Visual & Layout Enhancements
1. Dark Theme: Changed background and foreground colors to dark mode (dark gray backgrounds, light text).
2. Modern Buttons: Updated button styling with gradient backgrounds, transitions, hover effects, rounded corners.
3. Responsive Design: Layout made fully responsive using Flexbox and media queries to adapt to different screen sizes.
4. Google Font - Lato: Replaced the default font with the Lato font from Google Web Fonts.
5. Input Styling: Enhanced appearance of <input>, <select>, and <label> elements for better readability and usability.
Functional Changes
6. Animated UI: Added smooth transitions and animations to buttons and field highlights for a modern user experience.
7. ZIP Filename Generator: Each ZIP file downloaded now gets a unique name like characters0001.zip, characters0002.zip, etc., to avoid overwriting.
8. Improved Font Border (Stroke Width) Display:
Converted stroke width input from number to range input with dynamic percentage label.
9. Color Picker Upgrades:
Replaced basic color pickers with enhanced input using better styling for usability (can later be swapped with external color picker libraries if needed).
10. Added hex fields.
Accessibility & Usability
11. Improved Labels: Labels have better spacing and visibility, ensuring users can easily identify input fields.
12. Preview Area Enhancements: The preview section has a darker background with padding and cleaner layout for generated images.
//Edit 13:07:
Added v2 version with font shadow and Moore...
Demo of this version it's no longer available. New version it's available on amazfitwatchfaces.com/gen/
image generator for amazfit characters modded with fix for font opacity.zip
Latest version like on my demo
(3.14 KiB) Downloaded 139 times
image characters generator modded v2.zip
Versiin with some improvements...
(3.09 KiB) Downloaded 125 times
character_image_generator_modded_with_values.zip
First version
(2.89 KiB) Downloaded 108 times
gingerbeardman
Should I put my version on GitHub so we can all work on the same code?
TRK88PL
Post by TRK88PL »
This decision is Yours but I don't think there is a lot to do with this generator and need many new options to implement in...
For me this my current, final version. Demo on the same page as before :)
PS. If You still see old demo version - clear Your browser cache ( shortcuts: Ctrl +F5 / Ctrl + R) or use other browser.
New version available below in newer post!
current version by me.zip
(3.35 KiB) Downloaded 130 times
rush2112
Has thanked: 119 times
Post by rush2112 »
@TRK88PL
TRK88PL
Post by TRK88PL »
No problem I even have a newer version @rush2112 :) take a look attachments section below*. Demo on https://trk88pl.7m.pl/gen/old.html
*Language switcher not included - if You really need this let me know.
new version 260425 by TRK88PL.zip
New version from 26.04.2025 - EN
(4.34 KiB) Downloaded 152 times
rush2112
Post by rush2112 »
Thanks Buddy
TRK88PL
Post by TRK88PL »
Hello! The latest version of the generator is now available on my website.
Here’s what’s new: a completely redesigned and more polished interface, support for text rendering with or without gradients, more precise control over angles (for shadows and gradients), and several other improvements.
The generator is available at
Preview
Has thanked: 1162 times
Been thanked: 279 times
TRK88PL wrote: 11 May 2025, 14:21
PS. Sorry for ads on website, unfortunately this is free hosting with ads... Maybe someday I will change this.
Right now if You don't like this ads I highly recommend you use Ublock or other ads blocker.
Thanks for sharing the updated version — it looks great!
If you’d like, we can host the generator directly on our website (without ads) to make it more accessible to users. Just let us know — we’d be happy to help you with that.
TRK88PL
Post by TRK88PL »
GIK-Team wrote: 11 May 2025, 16:58
Wow, thank you so much, I really didn’t expect that :) I’ll message you privately if that’s okay — I’ll also send you a non-public version, which is even more advanced. In short, I’m not sure if anyone will even need Photoshop or any other tool for creating graphics and basic watch faces anymore ;) I’ll explain everything in a private message :)
TRK88PL wrote: 11 May 2025, 17:06
No problem at all — we’ll be happy to hear from you! Looking forward to your message ;)
TRK88PL
Post by TRK88PL »
I'm very pleased to share that my generator has now found a home on the AmazfitWatchFaces servers! From now on, link to page is available in the Tools section on the website, as well as directly at: https://amazfitwatchfaces.com/gen/
Enjoy using it — and once again, thank you for providing the space @GIK-Team!
// Edit 13.05.25
Added background generator for rounded watch faces!
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
Very cool @TRK88PL I haven't made a watchface for a while but I remember thinking it would be excellent to get a generator to make outlines and here it is! These people don't know the struggle we had making all our elements by hand. hahaha
TRK88PL
Post by TRK88PL »
Yeah @taw_bip, now they can feel half of "our pain" ;), unfortunately for now they still need to create own watch face with editor from @SashaCX75 to implement all graphics, move them on correct place etc but still... This generator make life easier :)
