Been thanked: 1044 times
v18.1
Version 18.1
Guydu91
Has thanked: 59 times
Post by Guydu91 »
I am creating a new watchface and I ran into this problem... and I got around it with the online converter.
Version 13.1
Mirror
Xemic
Post by Xemic »
Hello Folks,
@SashaCX75
Apologies if this has been discussed or answered in the past.
Please can you help me? Is there a way to turn "Day of the Week in font" at an angle either in the app or index file.
@Xemic The watch cannot display the font at an angle.
Emiliomc
Post by Emiliomc »
Hi. I don't know if what I'm trying to do is possible or not. I've created a watchface ("new"). And I've created another watchface ("new2"). I have both installed. I want that when I click on a button I created in "new", when this watchface is the one I have on the screen, it will directly select the "new2" watchface and display the latter on the screen.
The closest I've found is to create a button that opens the option to select an installed watchface, the code for which is: hmApp.startApp({url: 'WatchFaceScreen'. native: true }). But I don't want to have to select it; instead, I want the button to directly select "new2".
I've tried adding the expression "new2" (without quotes) to this code in several ways to achieve what I'm trying to achieve, but none of them work. For example: hmApp.startApp({url: 'WatchFaceScreen= new2'. native: true })
I hope I've explained myself well and that you can help me.
@Emiliomc The hmApp.startApp command tries to open the watch face as an application. Therefore, if they are opened, they will work with errors. I tried it with several watch faces.
Well, the command itself should look different. It goes something like this hmApp.startApp({ appid: 1051195, url: 'watchface/index', });
I don't know of a normally working way to switch the watch face using code.
Emiliomc
Post by Emiliomc »
I understand the theory you've explained to me. You say it doesn't work for you, but I sense that the code that makes what I want possible must be very similar to what you describe. I don't know... maybe some detail is missing or missing.
Emiliomc
Post by Emiliomc »
I've been trying to solve the problem for a while, but I can't find a solution. I created a folder called "button_scripts" and placed it next to the application executable. I've created several .js files with possible functions that do what I want. All the .js files are more or less the same... Starting with hmApp.startApp({ appid: new2, url: (etc.). I assign these functions to buttons on the "new" watchface, and after installing the .bin file, the watchface simply doesn't display. The screen goes black. Something that seems strange to me. At least if the watchface were displayed with the buttons not working. But the watchface doesn't even display. I don't know if anyone could help me or tell me where I could go, please.
@Emiliomc Show the project for the editor so we can see what the problem is. I'm not sure if anyone uses the ‘button_scripts’ folder, so I don't know how stable this function is.
The editor does not work with .bin formats, so it is not clear what you are doing and why.
I tested the ability to start watch faces using the hmApp.startApp command a few years ago. Perhaps something has been changed in the latest firmware. Besides, I would choose the simplest watch faces for testing. For example, containing only the background.
Emiliomc
Post by Emiliomc »
Well, the project is very basic for now. I've created a watchface on a black background that shows the time, day of the week, day of the month, and month. I've included a transparent button that takes up the extension of all this data. This watchface is called "new." And when I package it in .zip format, I rename it to .bin to install it with the AmazFaces app. I've always done it this way, and my watchfaces install and work correctly. On the other hand, I have another watchface ("new2") that has activity data (steps, heart rate, calories, etc.), a small time in the top right, and a button to return to the "new" watchface. I also package this second watchface in .zip format and rename it to .bin format, and finally, I install it with the AmazFaces app. My idea is to be able to go from "new" to "new2" and from "new2" to "new."
zyfish
Post by zyfish »
血氧SPO2数值,变化后,表盘上无法自动更新。
@zyfish SPO2 is updating normally.
zyfish
Post by zyfish »
no,在gts3表盘上,spo2不会自动更新,一直显示第一次测出来的数值。
使用了角度值
zyfish
Post by zyfish »
感谢🙏,我知道了..
zyfish
Post by zyfish »
zyfish wrote: 03 Apr 2025, 21:02
使用了角度值
如果您没有列出错误图像,那么手表就会将其视为缺失信息并且无法正常工作。
我列出了错误图像,表盘上spo2还是不会自动更新数值。
Read what is written at the top of the page on the red background. The discussion should be in English.
The author sent me a watch face to check. He's using an angled data display. And for this, the data is taken from the sensor But the sensor returns the last manual measurement value, not the automatic measurement. There is a way to get the data from the last automatic measurement. But it can lead to cyclic resetting of the watch (the problem is in the sensor itself and I don't know on all models or not). I wrote to the author how to get round this. But everything is done under your responsibility.
Here is what the person who faced this problem (leXxiR) writes on the forum
So I gradually determined that the reason was a long initialisation of the blood oxygen level sensor spo2 = hmSensor.createSensor(hmSensor.id.SPO2).
In my function, I used the properties spo2.retcode, spo2.time and spo2.hourAvgOfDay. Accessing one of them immediately after loading the clock (most likely the last one) caused a bootloop.
No additional checks or try-catch wrapper helped. Apparently, the problem occurred inside the method itself.
That's why the bootloop was not always present. If the screen showed the Oxygen readings, the clock froze on reboot. If the second tab of indicators was displayed, there was no bootloop.
I solved the problem in the following way: at the first call to the oxygen calculation function it returns an empty value ‘--’, at subsequent calls to the spo2 sensor (which already has time to initialise) and performs calculations.
Francko76
Post by Francko76 »
any news about Bip 6 ?
Has thanked: 438 times
Been thanked: 2141 times
Francko76 wrote: 08 Apr 2025, 10:16
version 13.2 beta supported Bip 6
I am a tester , as far as I tested, at now it still no found any issue.
However, we will have to ask you to wait until SashaCX75 has done the final verification before releasing the complete version for everyone to download.
https://amazfitwatchfaces.com/search/bi ... ible=Bip_6
This is all the Bip 6 watchfaces that I created to test the editor version 13.2 beta.
Francko76
Post by Francko76 »
Thanks Asoo for your reply.
I tried one of them and I would like to port some of my old wf on bip6 too.
let's wait Sasha
asoo wrote: 08 Apr 2025, 11:05
The watch faces for the Bip 6 are the same as for the GTS 4. There may be a slight difference in the radius of rounded corners. And a different preview skin. There are no other differences in the editor for these models. So until the new version comes out you can just make watch faces for GTS 4.
Francko76
Post by Francko76 »
SashaCX75 wrote: 08 Apr 2025, 15:42
thanks a lot sasha, but how to test the wf?
Guydu91
Post by Guydu91 »
Francko76 wrote: 10 Apr 2025, 08:41
The easiest way is to test it directly on the watch.
I installed a Bip 6 watch face made by Asoo on my GTS4, and everything works perfectly.
It seems that the two models are compatible.
However, the two watches use slightly different versions of ZeppOS, so some features may not be supported.
If you are asking how to install a watch face on a watch, here are the instructions
viewtopic.php?t=3873
Zecodorna
Post by Zecodorna »
What is the url to add a shortcut to the training history screen?...
