domenicopardo
Post by domenicopardo »
@SashaCX75
I made this change but it doesn't work
// Start combined color change
let colornumberCombined = 1;
const totalcolorsCombined = 2;
function click_HAND_S() {
if (colornumberCombined >= totalcolorsCombined) {
} else {
colornumberCombined++;
// Update second hand
let namecolorS = colornumberCombined == 1 ? "Red" : "Blue";
normal_analog_clock_pro_second_pointer_img.setProperty(hmUI.prop.SRC, "Hand_S" + colornumberCombined + ".png");
// Update background
let namecolor = colornumberCombined == 1 ? "Style 1" : "Style 2";
normal_background_bg_img.setProperty(hmUI.prop.SRC, "main" + colornumberCombined + ".png");
// Update hour hand
normal_analog_clock_pro_hour_pointer_img.setProperty(hmUI.prop.SRC, "Hand_H" + colornumberCombined + ".png");
// Update minute hand
normal_analog_clock_pro_minute_pointer_img.setProperty(hmUI.prop.SRC, "Hand_M" + colornumberCombined + ".png");
// Show toast message
hmUI.showToast({ text: `Colors Updated to ${namecolorS} and ${namecolor}` });
// Funzione per attivare automaticamente alle 6:00 del mattino e alle 18:00 di sera
function time_update() {
if (hour == 6 || hour == 18);
click_HAND_S();
rush2112
Has thanked: 119 times
Post by rush2112 »
@SashaCX75
Good Morning,
Small question maybe you do know the GTR3 Pro for the next update on this watch is finish or not, I did send a lot of request at the Amazfit Team but they never did reply :( that is really sad that is a watch still for sale everywhere ( Store ,Amazon....... ) still expensive , that means the Zepp OS will stay 1.0
@rush2112
I am not an employee of Amazfit and don't know about their plans. But my opinion is that GTR3 (Pro) will not be updated anymore.
@domenicopardo
I wrote about adding these lines to an existing function. And judging by your post, you are creating a new function with the same name. Of course, it will not work correctly.
When adding code to your post, I recommend that you set appropriate tags. Otherwise it is difficult to read it.
Emiliomc
Post by Emiliomc »
Hello. My english is terrible, sorry. First of all, thank you for this great application. It's very good. I have an Amazfit GTS 4 and I have already created some watchfaces. But now I want to introduce a progressive circle into a watchface and only part of this circle is shown starting with a pulse of 75. I have read that it could be corrected by modifying the index.js file. But that element to modify does not appear. I have also looked at other files inside the watchfaces folder, but nothing. I have the latest version of the application. How could I correct that?
Been thanked: 2122 times
Emiliomc wrote: 22 Apr 2024, 21:51
In index.js[/spoiler]
                let valueHeartRate = heart_rate.last;
                let targetHeartRate = 179;
                let progressHeartRate = (valueHeartRate - 71)/(targetHeartRate - 71);
                if (progressHeartRate < 0) progressHeartRate = 0;
                if (progressHeartRate > 1) progressHeartRate = 1;
                let progress_cs_normal_heart_rate = progressHeartRate;
Emiliomc
Post by Emiliomc »
I am very sorry for having asked the wrong place. Thank you very much for the reply. I'll try it. I suppose that I can put the line you suggest at the end, as an addition, in the index.js file.
Emiliomc wrote: 23 Apr 2024, 09:26
Not adding more
If you pack with sasha's editor
You can found this code in index.js.
You simply edit 71 to the value you want.
Emiliomc
Post by Emiliomc »
I apologize for continuing on the wrong site, but I don't know if they should redirect the query to another place. Very sorry. I'm trying what you're telling me and it's clear that I'm doing it wrong. In the Files_templates folder is the only place where I find an index.js file. I open it with the Windows 11 Note Block app, and at the end I add and save this:
(My intention is for the progressive pulse circle to move between a minimum of 0 and a maximum of 140)
** Watch_Face_Editor tool
** watchface js version v2.1.1
** Copyright © SashaCX75. All Rights Reserved
try {
//start of ignored block
const __$$app$$__ = __$$hmAppManager$$__.currentApp;
function getApp() {
return __$$app$$__.app;
function getCurrentPage() {
return __$$app$$__.current && __$$app$$__.current.module;
const __$$module$$__ = __$$app$$__.current;
const h = new DeviceRuntimeCore.WidgetFactory(new DeviceRuntimeCore.HmDomApi(__$$app$$__, __$$module$$__));
const {px} = __$$app$$__.__globals__;
const logger = Logger.getLogger('watchface_SashaCX75');
//end of ignored block
//dynamic modify start
//Variable declaration section
//dynamic modify end
__$$module$$__.module = DeviceRuntimeCore.WatchFace({
init_view() {
//Item description section
onInit() {
logger.log('index page.js on init invoke');
build() {
this.init_view();
logger.log('index page.js on ready invoke');
onDestroy() {
logger.log('index page.js on destroy invoke');
} catch (e) {
console.log('Mini Program Error', e);
e && e.stack && e.stack.split(/\n/).forEach(i => console.log('error stack', i));
{ let valueHeartRate = heart_rate.last;
let targetHeartRate = 140;
let progressHeartRate = (valueHeartRate - 0)/(targetHeartRate - 0);
Emiliomc wrote: 23 Apr 2024, 10:24
I think you are misunderstanding.
The index.js file is in the .zip file that you will get when packing the watch face.
When you finish creating a watch face and pack it, you will get a watch face file with .zip extension.
The index.js file will be in that .zip file. When you uncompress the zip file, you will find the index.js file in the "watchface" folder.
index.js is the file that stores the dial code.
So if you want to edit the code of any watch face
You have to look in the .zip file of that watch face. that you received from the pack
Emiliomc
Post by Emiliomc »
How clumsy I am... I was misunderstanding you. I think I've already done it well. It seems that now the progressive circle of the pulsations works as I have configured. That is to say; between 0 - 140. Thank you very much for your patience and help. I hope I'm not wrong.
huesitos
Post by huesitos »
How can i get a press on the center of the dial to change color numbers?
Emiliomc
Post by Emiliomc »
First of all, I apologize if I shouldn't ask a question here in the forum.
I use SashaCX75's great tool to create a watchface for my Amazfit GTS 4. It recently occurred to me that perhaps through code the index.js file of a created watchface could be modified so that a button created (by modifying the line) would change directly from watchface to another watchface. Both watchfaces in my smartwatch store. One with the name White Watch and the other with the name Analog Black.
Something like:
hmApp.startApp({url: 'White Watch',native:true});
But it's not that simple. At least for me. Or is it not possible?
Thank you.
@Emiliomc
The hmApp.startApp command is designed to start applications. Some watch faces can be started with this command, but even then not all elements on a watch face started this way work.
Emiliomc
Post by Emiliomc »
Thank you. I understand that you can't do what I want then, right? not even adding something else to the line of a created watchface selection button (this one does exist)? My idea could perhaps start from this sphere selection button, but it would directly select the one that I indicate in the line that I modify, although I don't know what would be added and if it would work.
Emiliomc
Post by Emiliomc »
Impossible then?
I have tried adding more lines to the preset "choose watchface" button so that it can then select the one I want, but with no results.
I understand that with javascript you can achieve many things, but I don't know this language. For example, I know that the Notify for Amazfit app has a plugin for Tasker (which I know how to use) that includes the possibility of changing the watchface by pressing the physical button. But I don't like this app. I use Zepp.
@Emiliomc
It works so badly that you can consider it not working.
If Notify for Amazfit has this feature, it's done on the phone, not on the watch. Most likely the tap just sets a new watch face when the trigger is activated.
Emiliomc
Post by Emiliomc »
Exact. Notify for Amazfit, with that plugin for Tasker, offers the opportunity to establish a new watchface with that touch. That's precisely what I want, but with a transparent button on my minimalist analog watchface. So from my main watchface I can set another watchface with more detailed information with a single tap on a transparent button. And from this second watchface I can return to my main watchface with another transparent button or a .png text. But if I remember correctly (I'm almost sure that's the case) it is by configuring the physical button on the watch. That is, I am almost sure that among the possibilities offered by the plugin, one of them is to establish a watchface by pressing the physical button on the watch. And I assume it was created with JavaScript language.
Downloadking
Post by Downloadking »
I'm new and I'm Italian. Sorry if this is a stupid question.
How to manage .bin files?
I have to convert a bin watch face of a GTS mini 2 to active.
Downloadking wrote: 23 May 2024, 20:12
You posted a question on the wrong forum . Next time, recommend checking the forum before posting, and we recommend "Search" first before make a question.
You can find tools and more details about GTS2mini in this post.
viewtopic.php?p=12537#p12537
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
Hello, if i make a new face for GTR 4 it does not show pointer for Heartrate anymore. Can someone help me?
Downloadking
But my question is in fact inherent to the whatchface editor for an Amazfit Active.
I would like to convert the watchfaces of the GTS 2/GTS 2 Mini into watchfaces for my Amazfit Active.
I've already searched a lot in the forum but so far I haven't found anything that leads me to the solution. I only found a way to unpack the Bin file but then I don't know how to create the zip for my Active
Lattenknaller
Has thanked: 60 times
Been thanked: 133 times
Post by Lattenknaller »
You'll have to do a bit of work yourself.
Unzip with this program: viewtopic.php?t=1888
Then you have to adjust the size of all graphics with a graphics program (Gimp, Photoshop or similar) and then you can use this tool:viewtopic.php?t=2743
create a new WF for the Active with the graphics from the old one.
A direct conversion from generation 2 to generation 3 or higher is not possible.
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Hey, @SashaCX75 can You somehow fix conversion / exporting for huge image size files? Ofc I try better quality set in settings, but on Gtr 3 there are black squares not images... I mean You can check my latest wf called TRK D008 and there You can see my result - top of hour isn't sharp at all, edges are torn... I use transparent text on black background method to displays many types of colors backgrounds.
It is difficult to say something without seeing the original files. I can advise you to switch on the option to convert images without quality loss in the editor settings and make sure to force the ARGB format.
You can also try to change the colour of one pixel from #000000 to #000001. Then the image should not be perceived by the software as black and white and it may affect the conversion algorithms.
