ZOOM Watchface port for GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
Hello to forum. Can anyone port this watchface for GTR3 Pro and if it's possible add the ability to change colours and make the animation work like prototype for seconds, otherwise convert it as possible. Thank you.
https://www.facer.io/watchface/s3lD5UXg ... atch4black
mrbutthead
- Has thanked: 60 times
- Has thanked: 436 times
- Been thanked: 2137 times
amazfitfacesafrica wrote: 24 May 2023, 14:42Spoiler
I'm not responsible for anything that might happen with your upload and don't need to give me credit.[/i
Click change color screen on the left side area of the PWR icon
( after click change color screen display will be black color , you must click again to update screen color )
Click change color Digital time on the right side area of the PWR icon
GTR3 pro : GTR3 :
GTR3 pro : GTR3 :
Wow, what amazing watchface you made. Thank you.
mrbutthead
I'm not sure if the animations will work correctly because GTR3/3Pro is scripted differently than GTR4. I've edited it but I'm not sure if it's completely correct. But as far as testing on "Amazfit Balance", it works.
However, on GTR4 I was unable to test it. Because I don't have it
and the editor program and simulator cannot test this watch face.
Because there are many custom scripts used in the preparation.
If the dial display is incorrect I would like to make no further changes. Because it can't be done. From the reasons mentioned initially
mrbutthead
- Has thanked: 132 times
- Been thanked: 21 times
Nice! The animations work on T-Rex 2 with this conversion.asoo wrote: 28 Feb 2024, 18:40I'm not sure if the animations will work correctly because GTR3/3Pro is scripted differently than GTR4. I've edited it but I'm not sure if it's completely correct. But as far as testing on "Amazfit Balance", it works.
ZOOM Watchface_C_Script_GTR4.zip
