ZOOM Watchface port for GTR3 Pro
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello to forum. Can anyone port this watchface for GTR3 Pro and if it's possible add the ability to change colours and make the animation work like prototype for seconds, otherwise convert it as possible. Thank you.
https://www.facer.io/watchface/s3lD5UXg ... atch4black
mrbutthead
Has thanked: 60 times
Post by mrbutthead »
I support the request, for gtr 3
Has thanked: 436 times
Been thanked: 2137 times
amazfitfacesafrica wrote: 24 May 2023, 14:42
I'm not responsible for anything that might happen with your upload and don't need to give me credit.[/i
Image.Image
Click change color screen on the left side area of the PWR icon
( after click change color screen display will be black color , you must click again to update screen color )
Click change color Digital time on the right side area of the PWR icon
GTR3 pro :
zoomGTR3pro_Cscript_AOD.zip
(636.81 KiB) Downloaded 150 times
GTR3 :
zoomGTR3_Cscript_AOD.zip
(837.17 KiB) Downloaded 164 times
Wow, what amazing watchface you made. Thank you.
mrbutthead
@asoo Hello, can I have a version for GTR4?
mrbutthead wrote: 28 Feb 2024, 11:51
I'm not sure if the animations will work correctly because GTR3/3Pro is scripted differently than GTR4. I've edited it but I'm not sure if it's completely correct. But as far as testing on "Amazfit Balance", it works.
However, on GTR4 I was unable to test it. Because I don't have it
and the editor program and simulator cannot test this watch face.
Because there are many custom scripts used in the preparation.
If the dial display is incorrect I would like to make no further changes. Because it can't be done. From the reasons mentioned initially
ZOOM Watchface_C_Script_GTR4.zip
(1016.78 KiB) Downloaded 139 times
mrbutthead
@asoo Checked it, works great. Thank you.
Has thanked: 132 times
Been thanked: 21 times
Post by taw_bip »
asoo wrote: 28 Feb 2024, 18:40
Nice! The animations work on T-Rex 2 with this conversion.
