Tool to unpack gts 2 mini
Правила форуму
Відповісти
Max88
З нами з: 30 травня 2019, 17:54
Контактна інформація:
Повідомлення Max88 »
Hello guys, I need help about gts 2 mini.
It has passed a lot of time since when I did some wf for this watch, and now I totally forgot which tools to use and where to find them.
To start I'd need a tool to unpack wf, but I'm not able to find anything I could use on windows.
Аватар користувача
Has thanked: 438 times
Been thanked: 2142 times
Повідомлення asoo »
Max88 писав: 23 січня 2024, 14:15
viewtopic.php?p=12537#p12537
Max88
asoo писав: 23 січня 2024, 14:34
Thank you. I had already seen that post, but that main.exe file doesn't work for me.
It doesn't unpack wf I have downloaded from this site.
Moreover, to be honest I haven't understood exactly how to use it.
I have imagined it was sufficient to download just the main.exe file and drag the bin I'm interested in on top of that exe.
Аватар користувача
Повідомлення asoo »
Max88 писав: 23 січня 2024, 21:11
You can view the command line by
Open "CMD" (Dos mode) and type main --help
Код: Виділити все
usage: main [-h] [--vergelite] [--gtr {42,47}] [--gtr2 {42,47}] [--gts] [--gts2] [--trexpro] [--oldformat]
            [--gts2mini] [--bipu] [--bip3] [--trex] [--x] [--file FILE [FILE ...]] [--to_raw] [--from_raw]
            [--border_alignment]
options:
  -h, --help            show this help message and exit
  --vergelite           force VergeLite watchface
  --gtr {42,47}         force GTR watchface
  --gtr2 {42,47}        force GTR2 watchface
  --gts                 force GTS watchface
  --gts2                force GTS2 watchface
  --trexpro             force TRexPro watchface
  --oldformat           force old json format for GTS2 or GTR2
  --gts2mini            force GTS2 Mini watchface
  --bipu                force Bip U watchface
  --bip3                force Bip 3 watchface
  --trex                force T-REX watchface
  --x                   force AmazfitX watchface
                        watchface.bin - unpacks watchface images and config watchface.json - packs config and
                        referenced images to bin file
  --to_raw              save raw header and resources
  --from_raw            generate bin from raw folder
  --border_alignment    draw border around aligned objects in preview
or you can see how to use main.exe in this link.
( in the topic "usage" )
Max88
asoo писав: 24 січня 2024, 02:02
Код: Виділити все
options:
Thank you again for help, but where do I have to open CMD and how?
Because if I write cmd in windows task and then I write main --help nothing happens
Edit: oh and I haven't understood how to use that main.exe, sorry.
Аватар користувача
Повідомлення asoo »
Max88 писав: 24 січня 2024, 08:39
Open CMD :
Зображення
command line for unpack
main --gts2mini --file yourwatchface.bin
command line for pack
main --gts2mini --file yourwatchface.json
Max88
asoo писав: 24 січня 2024, 09:05
Open CMD :
Зображення
Вкладення
Screenshot 2024-01-24 101725.png (23.24 Кіб) Переглянуто 3678 разів
Аватар користувача
Повідомлення asoo »
if you want to use main.exe , main.exe must be in the same folder as file.bin that you want to unpack.
Or, if you don't want to copy main.exe into the same folder as file.bin, you can copy main.exe into the folder c:\windows or the folder where Windows is installed. Doing this, you can run main.exe anywhere.
Max88
asoo писав: 24 січня 2024, 09:59
Ok, i got it. I have changed the working directory of cmd to the one where main and bin are.
I have given the command you wrote and unpack has worked.
Thank you a million for your kindness and patience
Відповісти
Повернутись до “Watchfaces tools (discussion)”
Хто зараз онлайн
