Правила форуму
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
v18.1
Version 18.1
Востаннє редагувалось 10 вересня 2026, 17:16 користувачем SashaCX75, всього редагувалось 54 разів.
Аватар користувача
Jel If the watch supports the functions "new Date()" and "getMilliseconds()" then this method should be better. This eliminates possible calculation errors. If you use "new Date()" and "getMilliseconds()" then the line "const now = hmSensor.createSensor(hmSensor.id.TIME);" probably not needed.
I'm just not sure that the clock can rotate the picture by a fractional number of degrees. If the clock cannot do this, then there is no point in such an accurate determination of the angle and such a frequent update of the position of the hand. Try to just draw an arrow with a width of 1px and display it with three pictures with different angles of 0; 0.5; 1 degree. If three pictures are displayed, then you can set the angle in fractional numbers and it makes sense to experiment with this further.
Востаннє редагувалось 14 листопада 2022, 19:01 користувачем SashaCX75, всього редагувалось 1 раз.
Jel
З нами з: 21 жовтня 2022, 15:55
Повідомлення Jel »
SashaCX75 , the above code is working on my GTR4. The only "issue" is, that it does not look, like 60fps. I would expect a continious move, but the second hand is some kind of "ticking". This may be related to hardware limitation. Anyway, it's working fine and I can't count the steps between the full seconds with my eyes ;) . Best regards.
zgdwj01
З нами з: 16 жовтня 2022, 22:27
Повідомлення zgdwj01 »
SashaCX75 писав: 29 серпня 2022, 06:40
@belikeKara Using standard tools, it is impossible to make a shortcut for the calendar either in my editor or in the official editor. But there are workarounds, for this you will need to manually edit the watch face code.
Can you share the scripts? Thank you.
Аватар користувача
zgdwj01
Код: Виділити все
            normal_img_click_1 = hmUI.createWidget(hmUI.widget.IMG, {
              x: 184,
              y: 10,
              w: 86,
              h: 86,
              src: '0006.png', // transparent image
	    normal_img_click_1.addEventListener(hmUI.event.CLICK_DOWN, function (info) {
		hmApp.startApp({ appid: 1, url: 'ScheduleCalScreen', native: true })
zgdwj01
SashaCX75 писав: 13 листопада 2022, 07:43
@zgdwj01
Код: Виділити все
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Wow! With this you can basically add shortcuts to any app. Where did you get the appid and url? Is it in the documentation?
mixxx
З нами з: 14 грудня 2020, 23:54
Повідомлення mixxx »
Hello, any advice how solve issue with AOD.
I made all of need to do, but dont recognize it.
Dont folow watch face.
NanR20
З нами з: 16 вересня 2022, 08:24
Повідомлення NanR20 »
Big thanks to SashaCX75 for this awesome tool.
Keep it up with the great work.
Cheers buddy!!! ;)
Аватар користувача
Guydu91
З нами з: 06 жовтня 2019, 18:49
Has thanked: 59 times
Повідомлення Guydu91 »
Hello Sasha,
Is there a way to put a shortcut to the music player in the current editor or could this function be integrated in a future version?
Thank you in advance for your answer and congratulations again for your excellent work.
Best regards.
Аватар користувача
Guydu91
With this code you can open the player
Код: Виділити все
              x: 184,
              y: 10,
              w: 86,
              h: 86,
		hmApp.startApp({ appid: 1, url: 'PhoneMusicCtrlScreen', native: true })
Аватар користувача
Guydu91
SashaCX75 писав: 20 листопада 2022, 14:15
@Guydu91
Код: Виділити все
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Thank you very much Sasha, you're really great!
I'll try to use that as soon as possible.
Best regards.
kwakykwaky1
З нами з: 10 лютого 2022, 15:48
Has thanked: 8 times
Повідомлення kwakykwaky1 »
Hi ,
just for the sake of interest, in which program this program is created.
Face editor GTR 3, GTR 3 Pro, GTS 3, T-Rex 2, GTR 4, GTS 4 Mini, Amazfit Band 7
Thanks for replying
Аватар користувача
kwakykwaky1 The editor is made in Visual Studio, if that's what you asked.
euskaljantza
З нами з: 04 жовтня 2022, 12:59
Повідомлення euskaljantza »
Guydu91 писав: 20 листопада 2022, 17:12
@Guydu91
Код: Виділити все
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Best regards.
Where this code has to be placed?
1mylord
З нами з: 18 січня 2022, 02:52
Повідомлення 1mylord »
Thank you always.
How can I open the aod settings shortcut?
I want to make it easy to turn on or off the aod.
Аватар користувача
1mylord
The code itself is the same as for launching the player in the previous post. Only use one of the following options as the url parameter:
Settings_standbyHomeScreen
Settings_standbyModelScreen
Settings_standbyStyleScreen
1mylord
Thank you very much.
Now you can use it conveniently by adding an AOD shortcut.
Have a nice day.^^
Аватар користувача
Guydu91
Hello Sasha,
Sorry to revive you on this subject, but I can't find where I should copy this code to create a shortcut to the audio player...
Do I have to integrate this element in the JSON file or in the ZIP file after creating the watchface? Somewhere else...?
Thank you in advance for your answer.
Best regards.
Lattenknaller
З нами з: 09 серпня 2022, 08:43
Has thanked: 62 times
Been thanked: 168 times
Повідомлення Lattenknaller »
The code needs to be in the index.js after you create the .zip
Аватар користувача
Guydu91
Thank you very much for your answer.
I will try this as soon as possible.
Best regards.
Аватар користувача
A collection of code examples for use in watch faces.
- smooth second hand for GTR 3;
- smooth second hand for GTR 4;
- change the background with a button on the screen;
- switching between different elements with a button on the screen;
- starting vibration;
- data output at an angle;
- data output in a circle.
Аватар користувача
Version 6.0
Mirror
Superwitschi
З нами з: 30 червня 2020, 03:11
Повідомлення Superwitschi »
Thanks for the new update
Аватар користувача
ZduneX25
З нами з: 12 жовтня 2022, 16:22
Been thanked: 6 times
Повідомлення ZduneX25 »
nevermind
Востаннє редагувалось 28 грудня 2022, 11:51 користувачем ZduneX25, всього редагувалось 4 разів.
Аватар користувача
In order to add Falcon support to my watch face editor, I need people willing to test new features on Falcon.
wp456
З нами з: 25 грудня 2022, 15:11
Повідомлення wp456 »
Hi, what is the difference why one step progress circle renders with continous color vs. the other one renders in a segmented way? I can't spot the diff in the resp. watchface json nor in the editor :)
Зображення
Зображення
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 3 гостей
