Been thanked: 1029 times
Messaggio da SashaCX75 »
Jel If the watch supports the functions "new Date()" and "getMilliseconds()" then this method should be better. This eliminates possible calculation errors. If you use "new Date()" and "getMilliseconds()" then the line "const now = hmSensor.createSensor(hmSensor.id.TIME);" probably not needed.
I'm just not sure that the clock can rotate the picture by a fractional number of degrees. If the clock cannot do this, then there is no point in such an accurate determination of the angle and such a frequent update of the position of the hand. Try to just draw an arrow with a width of 1px and display it with three pictures with different angles of 0; 0.5; 1 degree. If three pictures are displayed, then you can set the angle in fractional numbers and it makes sense to experiment with this further.
Ultima modifica di SashaCX75 il 14 nov 2022, 19:01, modificato 1 volta in totale.
Jel
Messaggio da Jel »
SashaCX75 , the above code is working on my GTR4. The only "issue" is, that it does not look, like 60fps. I would expect a continious move, but the second hand is some kind of "ticking". This may be related to hardware limitation. Anyway, it's working fine and I can't count the steps between the full seconds with my eyes ;) . Best regards.
zgdwj01
Messaggio da zgdwj01 »
SashaCX75 ha scritto: 29 ago 2022, 06:40
@belikeKara Using standard tools, it is impossible to make a shortcut for the calendar either in my editor or in the official editor. But there are workarounds, for this you will need to manually edit the watch face code.
Can you share the scripts? Thank you.
zgdwj01
Codice: Seleziona tutto
            normal_img_click_1 = hmUI.createWidget(hmUI.widget.IMG, {
              x: 184,
              y: 10,
              w: 86,
              h: 86,
              src: '0006.png', // transparent image
	    normal_img_click_1.addEventListener(hmUI.event.CLICK_DOWN, function (info) {
		hmApp.startApp({ appid: 1, url: 'ScheduleCalScreen', native: true })
zgdwj01
SashaCX75 ha scritto: 13 nov 2022, 07:43
@zgdwj01
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Wow! With this you can basically add shortcuts to any app. Where did you get the appid and url? Is it in the documentation?
mixxx
Messaggio da mixxx »
Hello, any advice how solve issue with AOD.
I made all of need to do, but dont recognize it.
Dont folow watch face.
NanR20
Messaggio da NanR20 »
Big thanks to SashaCX75 for this awesome tool.
Keep it up with the great work.
Cheers buddy!!! ;)
Guydu91
Has thanked: 55 times
Messaggio da Guydu91 »
Hello Sasha,
Is there a way to put a shortcut to the music player in the current editor or could this function be integrated in a future version?
Thank you in advance for your answer and congratulations again for your excellent work.
Best regards.
Guydu91
With this code you can open the player
              x: 184,
              y: 10,
              w: 86,
              h: 86,
		hmApp.startApp({ appid: 1, url: 'PhoneMusicCtrlScreen', native: true })
Guydu91
SashaCX75 ha scritto: 20 nov 2022, 14:15
@Guydu91
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Thank you very much Sasha, you're really great!
I'll try to use that as soon as possible.
Best regards.
kwakykwaky1
Has thanked: 8 times
Messaggio da kwakykwaky1 »
Hi ,
just for the sake of interest, in which program this program is created.
Face editor GTR 3, GTR 3 Pro, GTS 3, T-Rex 2, GTR 4, GTS 4 Mini, Amazfit Band 7
Thanks for replying
kwakykwaky1 The editor is made in Visual Studio, if that's what you asked.
euskaljantza
Messaggio da euskaljantza »
Guydu91 ha scritto: 20 nov 2022, 17:12
@Guydu91
              x: 184,
              y: 10,
              w: 86,
              h: 86,
Best regards.
Where this code has to be placed?
1mylord
Messaggio da 1mylord »
Thank you always.
How can I open the aod settings shortcut?
I want to make it easy to turn on or off the aod.
1mylord
The code itself is the same as for launching the player in the previous post. Only use one of the following options as the url parameter:
Settings_standbyHomeScreen
Settings_standbyModelScreen
Settings_standbyStyleScreen
1mylord
Thank you very much.
Now you can use it conveniently by adding an AOD shortcut.
Have a nice day.^^
Guydu91
Hello Sasha,
Sorry to revive you on this subject, but I can't find where I should copy this code to create a shortcut to the audio player...
Do I have to integrate this element in the JSON file or in the ZIP file after creating the watchface? Somewhere else...?
Thank you in advance for your answer.
Best regards.
Lattenknaller
Has thanked: 60 times
Been thanked: 132 times
Messaggio da Lattenknaller »
The code needs to be in the index.js after you create the .zip
Guydu91
Thank you very much for your answer.
I will try this as soon as possible.
Best regards.
A collection of code examples for use in watch faces.
- smooth second hand for GTR 3;
- smooth second hand for GTR 4;
- change the background with a button on the screen;
- switching between different elements with a button on the screen;
- starting vibration;
- data output at an angle;
- data output in a circle.
Version 6.0
Mirror
Superwitschi
Messaggio da Superwitschi »
Thanks for the new update
ZduneX25
Been thanked: 6 times
Messaggio da ZduneX25 »
nevermind
Ultima modifica di ZduneX25 il 28 dic 2022, 11:51, modificato 4 volte in totale.
In order to add Falcon support to my watch face editor, I need people willing to test new features on Falcon.
wp456
Messaggio da wp456 »
Hi, what is the difference why one step progress circle renders with continous color vs. the other one renders in a segmented way? I can't spot the diff in the resp. watchface json nor in the editor :)
Torna a “Watchfaces tools”
Visitano il forum: drex60 e 1 ospite
