Been thanked: 1029 times
ThomasAn.
Post by ThomasAn. »
demiurg1 wrote: 05 Aug 2022, 20:41
If I find some time, I will try to deliver BOTTA elements in black and 24 hours.
I am not sure I follow. Is 24hr analog possible on GTR 3 ?
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
I can't do it, but the SashaCX75 seems to have found a solution.
For example, here are some analog dials in 24h format. You can't do this in the editor. You can add all the elements to the dial in the editor and then edit the code responsible for the hour hand according to the example from these dials.
Thanks demiurg1 for the provided resources.
24h.zip
(1.8 MiB) Downloaded 284 times
demiurg1
Post by demiurg1 »
OK :)
ThomasAn.
Post by ThomasAn. »
SashaCX75 wrote: 08 Aug 2022, 18:59
Thanks @demiurg1 for the provided resources.
:shock: :shock: NICE !!!
I'll look into those files for sure !
Thank you very much.
Good job on the face design too.
eneapoma
Post by eneapoma »
Hi, How do I make the second hand smooth like that of the ROLEX?
demiurg1
Post by demiurg1 »
There is probably no such possibility. You can try to set the second hand as an animation and choose its animation parameters so that a full 360 ° rotation lasts 1 minute. In this case, however, the second hand can only be displayed under the hour and minute hands.
There is no animation in version 3.0 of the program. You have to try to do it in the online editor or "manually" or wait (probably soon) for SashaCX75 to release version 4.0.
Don't forget to support SashaCX75 financially.
Certainly, especially in the current situation in Ukraine, it will help him.
eneapoma
Post by eneapoma »
Yingos have made a watchface whit fluid second hand. Anyone know how this is done?
https://amazfitwatchfaces.com/gtr/view/24130
eneapoma wrote: 16 Aug 2022, 12:10
I already wrote here that a smooth second hand is done by editing the JS code in the dial. You can disassemble the dial and look at the code responsible for the smooth second hand. An example of such code can be found here https://gist.github.com/johnnybui/73106 ... 6bf24bd177
There are other ways to do this, but they all involve editing JS code.
eneapoma
Post by eneapoma »
Sasha What software should I use to disassemble the dial? Notepad ++?
eneapoma The watch face file has a zip extension. You can open it with any program that works with archives. There are also a lot of programs for editing JS code, everyone chooses the one that is convenient for him, you can also use Notepad ++.
eneapoma
Post by eneapoma »
SashaCX75 ok I have made the watchface with smooth second hand. thank you very much
Version 4.0
Added a tab with some tips on working with the editor
Added the ability to display the distance in miles
Not all new features have been translated. If you want to add or correct an existing translation, write to me in private messages.
Perhaps it could also benefit from the option to include a system font to rotate numbers
I didn't see an option to display text at an angle in either the official editor or the official spec docs.
So far, the only way I know of to do this is to programmatically calculate the position of each displayed character. An example of such a dial https://amazfitwatchfaces.com/gtr/view/20048
eneapoma
Post by eneapoma »
SashaCX75 Hi Sasha, there is a way or a script to do the 24 hour analog for the GTR 3 Pro?
demiurg1
Post by demiurg1 »
I have read and inform you that SashaCX75 has already provided a link to such an example:
eneapoma
Post by eneapoma »
demiurg1 This is for smooth second, i need the 24 hour analog
eneapoma You should carefully read the topic. On this page I have already laid out examples of such dials.
eneapoma
Post by eneapoma »
SashaCX75 Thank you very much
Is there a way to put both 12 hour and 24 hour formats together? Analog
eneapoma You can of course make two hour hands. But I do not think that such a dial will be convenient.
eneapoma
Post by eneapoma »
SashaCX75 When I do the dual time the 12 hour hand moves while the 24 hour hand does not move. Do you know why? I have attached the clock file, can you check if it is right?
index.js
(3.79 KiB) Downloaded 262 times
eneapoma Because you have two different elements for the hour hand with the same name. They must have different names.
eneapoma
Post by eneapoma »
SashaCX75 like this?
            // 24h
			normal_analog_clock_time_pointer_hour = hmUI.createWidget(hmUI.widget.IMG, {
              x: 0,
              y: 0,
              w: 480,
              h: 480,
              pos_x: 480 / 2 - 240,
              pos_y: 480 / 2 - 239,
              center_x: 240,
              center_y: 239,
              src: 'Corona.png',
			// 24h end
            normal_analog_clock_time_pointer_hour2 = hmUI.createWidget(hmUI.widget.TIME_POINTER, {
              hour_path: 'Ore.png',
              hour_centerX: 240,
              hour_centerY: 240,
              hour_posX: 239,
              hour_posY: 238,
eneapoma Yes, something similar to this. Only it is necessary not to forget at the beginning, where all the names of objects are listed, to declare also a second name.
Judging by the specified numbers in the properties of the arrow, the image of the arrow occupies the entire screen in size. Usually the image of the arrow is much narrower.
Version 4.1
Mirror
