- Administrador
Request for GTS2 mini
Reglas del Foro
- Kurtyyyyyy
- Has thanked: 6 times
- Been thanked: 2 times
- Contactar:
Was wondering if anyone could make this watchface. It's the multicolour watchface, but I would just like the rings, the nike logo and the DAY all to be red.
https://amazfitwatchfaces.com/gts/view/6857
If not possible, no problem!
- Has thanked: 419 times
- Been thanked: 2109 times
Bip 3 , gts2 mini , Bip U
You can try to do by yourself by use Editor on web.
https://tnxec2.github.io/amazfit-gts2mi ... ace-react/
https://github.com/Tnxec2/amazfit-gts2m ... s2mini.zip
if you want to see new version please use this link to check
https://github.com/Tnxec2/amazfit-gts2m ... face-react
Huaim official online editor
source for main.exe
main.exe for pack , unpack ".json" to ".Bin" or unpack ".Bin" to ".json + image" ( GTS2mini , Bip U , Bip 3 )
Version 04-07-2023 : This main.exe compile by Tnxec2
https://raw.githubusercontent.com/Tnxec ... i/main.exe
How to use main.exe for pack watchface
viewtopic.php?p=15985#p15985
I don't have GTS2mini
That I fulfilled this request. In order to find tools for those who are interested in making their own Gts2mini watch faces. From testing all the tools that have been posted, one can definitely create a watch face. So I probably won't be accepting requests for this GTS2mini again.
therefore learned to know
- Not test on real device only test by Editor on web
Watchface :
source for main.exe
Watchface :
- Kurtyyyyyy
- Contactar:
- Kurtyyyyyy
- Contactar:
Well I tried. It's too complicated without knowing anything
I wish there was guide to follow
- Kurtyyyyyy
- Contactar:
This almost perfect but I would like the time to be white!
How in the hell do you do these request so fast??
Kurtyyyyyy
Download link :
viewtopic.php?p=12537#p12537
And please read carefully before download
If you want to edit on modify this ported watchface , please try it yourself. from the tools previously posted.
_________________________________________________________________________________________________________
Download link :
- Kurtyyyyyy
- Contactar:
My friend I can't thank you enough. Thank you for using your own time to do this. I will no longer bother you
Hi, I'm having difficult times creating my watchface with those tools shown above.
so exhausted...
I would be happy if anyone could look over my bin file and create a proper watchface bin.
What I've done is
1. Unpack downloaded bin from catalog using main_mini.exe.
2. Modify and also create some new images using Photopea.
3. Reduced the size of png using "https://compresspng.com/".
4. Using offline editor(not Huaim) to edit jason.
5. Pack with main_mini.exe and finally get my watchface.bin and other animated gif and else.
6. Install bin via amaztool.app (iOS).
Install successed but the images didn't show on the watchface and crushes...
to PackUnpack bin, I've also tried to use this tool (viewtopic.php?p=10807#p10807) instead but the result was the same.
so exhausted...
What I've done is
First of all let me tell you that I don't have gts2min so I can only check the scritp and resource section.juno-san escribió: 15 Jun 2022, 02:08Spoiler
so exhausted...
What I've done is
rol_rainbow_packed.bin
from the inspection I can't find any abnormality in script "json".
but in resource images section based on the information you provided you get compress png
So I think the problem might be from this part.
Since the device has a specific png format, it may result in the image that you compress the device to be unreadable.
I recommend using a normal PNG image that doesn't have compress.
The PNG I am using has the following format:
Examples that have been uncompress png
I'm not sure if I can work because I don't have GTS2MINI.
But in the "pack process" it's without any error
Thank you so much and I finally made it!
I changed my png format from using palette to truecolor.
also about my jason file, I found that I didin't add preview block. what a laugh...
minhtri0795
- Has thanked: 2 times
- Contactar:
Hi @ juno can you tell me how to pack folder back to bin file, hope you reply soonjuno-san escribió: 15 Jun 2022, 02:08Hi, I'm having difficult times creating my watchface with those tools shown above.
so exhausted...
What I've done is
Pack all resource in the folder to make BIN
- copy main_mini.exe to the folder where the .json that you want to pack.
command line for pack to BIN
Código: Seleccionar todo
main_mini.exe --gts2mini --file filename.jsonͼͽ To request please use the interrelated forum in action ͼͽ
minhtri0795
- Contactar:
SilexMilex
- Contactar:
asoo hey, sorry to bother you, but i cant figure out how to use the editor u send. I wont lent me upload images. also i dont understand how to convert .bin files into .json files.
Could you explain that to me?
command line unpack .binSilexMilex escribió: 04 Nov 2022, 15:43@asoo hey, sorry to bother you, but i cant figure out how to use the editor u send. I wont lent me upload images. also i dont understand how to convert .bin files into .json files.
Could you explain that to me?![]()
main_mini.exe --gts2mini --file filename.binEditor that i post you can open it by use any browser ( Firefox , Chrome .... )
Unzip editor to Folder you want .
Open editor by click index.html
About how to use please try by yourself because I do not how to tell you and I think it not hard to understand
hihaizhi
- Has thanked: 1 time
- Contactar:
Thanks in advance.asoo escribió: 14 Abr 2022, 13:29Spoiler
https://tnxec2.github.io/amazfit-gts2mi ... ce-static/
https://github.com/Tnxec2/amazfit-gts2m ... ace-static
https://watchface.huami.com/create
source for main.exe
main_mini.exe for pack ".json" to ".Bin" or unpack ".Bin" to ".json + image" ( GTS2mini , Bip U )
GTS2mini.zip
-------------------------------------------------------------------------------------------------------------------------------Spoiler
Watchface :
RED_GTS2mini.bin
gray_white_Gts2mini.bin
white_Gts2mini_packed.bin
I create my own watchface whit huami editor but alwaysondisplay not exported...
So I unpack bin file and modify with Tnxec2 editor. In the preview I see it ok.
packing with mini_main I get an error so I pack it with python main.py --gts2mini --file WATCH_FACE_FILE.json command.
But a black screen appears when follow screen AOD.
Wath is the correct JSON syntax for AOD? y would like it whit digital time.
Sorry, I can't verify this issue becausehihaizhi escribió: 26 Ene 2023, 07:53Thanks in advance.
I don't have this device, so I'm not sure what is the issue, because usually if you use the official editor ( huami editor ) to create a watch face, The result should be the same as the preview shown in the editor.
liuzhiaudio
- Contactar:
source for main.exe
main.zip
你好,请问main.exe具体怎么使用呢?
main.zip
goto CMD ( DOS )
type main -h and Enter you will see command line to use it .
Examples of using programs on the command line
viewtopic.php?p=14178#p14178
viewtopic.php?p=13255#p13255
usage: main [-h] [--vergelite] [--gtr {42,47}] [--gtr2 {42,47}] [--gts] [--gts2] [--trexpro] [--oldformat]
[--gts2mini] [--bipu] [--bip3] [--trex] [--x] [--file FILE [FILE ...]] [--to_raw] [--from_raw]
[--border_alignment]
optional arguments:
-h, --help show this help message and exit
--vergelite force VergeLite watchface
--gtr {42,47} force GTR watchface
--gtr2 {42,47} force GTR2 watchface
--gts force GTS watchface
--gts2 force GTS2 watchface
--trexpro force TRexPro watchface
--oldformat force old json format for GTS2 or GTR2
--gts2mini force GTS2 Mini watchface
--bipu force Bip U watchface
--bip3 force Bip 3 watchface
--trex force T-REX watchface
--x force AmazfitX watchface
watchface.bin - unpacks watchface images and config watchface.json - packs config and
referenced images to bin file
--to_raw save raw header and resources
--from_raw generate bin from raw folder
--border_alignment draw border around aligned objects in previewExamples of using programs on the command line
liuzhiaudio
- Contactar:
请问我用这个在线编辑器做的指针表盘有卡顿、流畅性不好的现象,这是什么原因呢?
I can't check anything because I don't have this device.
I suggest you open a new topic about the watchface you are having trouble with.
and upload the watchface with that problem to the topic in case someone with the device can test and fix the problem for you.
New main.exe released (04-07-2023)
main.exe
main.exe
liuzhiaudio
- Contactar:
请问我用这网上编辑器做表盘快捷方式不成功,是哪里没有设定好吗?Kurtyyyyyy escribió: 14 Abr 2022, 11:06Was wondering if anyone could make this watchface. It's the multicolour watchface, but I would just like the rings, the nike logo and the DAY all to be red.
¿Quién está conectado?
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 27 invitados
