Been thanked: 1044 times
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
rooooi
Post by rooooi »
Hello, hope someone still uses this!
I was able to make a Watchface from scratch using the program but once I try packing it nothing happens, a black window appears and shortly vanishes with no .bin in sight.
On the bottom right corner of the index thing it said 3.3MBs so I thought it was the size but even after lowering it to 1.75 the results were the same, black window and nothing.
Guydu91
Has thanked: 59 times
Post by Guydu91 »
rooooi wrote: 23 Jan 2022, 02:27
The maximum size is 1.5...
I think it's your problem. 😉
The maximum size depends on the watch model.
Exceeding the maximum size affects the operation of the watch face on the watch, but does not affect the created bin file. Look for errors in the log file.
FeRu
Has thanked: 14 times
Been thanked: 8 times
Post by FeRu »
Check if the png files are numbered consecutively from 0000 to last . Even when only one is missing or when you have mistake with one file name, your WF file will not be created. Check the log file.
rooooi
Post by rooooi »
I umm.. I don't think I have a log file...
I'm sorry i'm really really new to this.. I have the PNG's, the .JSON file and the preview states but no log... How do I get it?
I've also numbered the PNGs nicely and have no errors when loading the .JSON on the app. I've since lowered the size down to a nice 1.6MBs but nothing. Black window, and nothing..
Edit. I'm challenged... I made sure to note that every folder leading to the files but not the folder on which the files were actually on... thank you so much for all your help! I'll finally be able to move on to trying it on the watch!
rooooi
The log file should appear next to the .JSON file when the watch face is created.
FeRu
Post by FeRu »
rooooi wrote: 23 Jan 2022, 17:41
(-‸ლ) 😆
I'm glad that you found a solution...I'm sure that every WF maker from this community made some simple, idiotic and funny mistake that took a lot of nerves :lol:
rooooi
Post by rooooi »
I come to you with another ridiculous issue.. This time I have no issues with the files themselves.
It's the animations I'm having trouble with, I set an icon to move between the bottom of the screen up a tiny bit, looks fine in the app but doesn't work on the watch..
I have the animation speed set to 1000 and timer to 1, so it's not incredibly fast. It's also not the last PNG which I know is an issue
If I remember correctly, the animation time should be 0 or a multiple of the animation speed.
Animation speed is the duration of one animation cycle in milliseconds.
rooooi
Post by rooooi »
I have finally made it work. I tinkered with a lot of different animation speed and animation time combinations and multiples but nothing worked, only after trying to use both animations at once (movement and frame animations) did I actually get it to work...
It happened last time I tried this too so maybe you need to export one with both for them to work? and then you take the one you don't want out? Definitely seems like it, i'll be doing another final watchface soon and will do the same thing to check if having both works right away
YNOVAD
Post by YNOVAD »
Tengo este problema al querer empaquetar y comprimir el bin para una esfera del trex
YNOVAD
It's hard to say without seeing the project. It seems that the "distance" parameter does not contain all the necessary parameters.
YNOVAD
Post by YNOVAD »
Thanks so much. You are so acerted. I fix the problem with a png dot for decimals. Thanks Genius!
demieg
Post by demieg »
Hi All,
I'm very happy with this editor. Big thumbs upp for Sasha ;D
I have a problem with icons for the battery. I've designed 6 icons for the battery. When I test the icon in the editor it works fine. When I test in with my GTS watch the battery icon doesnt match the percentage. (the icon displays a lower percentage). Anyone knows how to fix this? Thanks in advance! 8-)
ps. I've included the compressed Bin-file.
Spongebob_Watch_NL.bin
(473.88 KiB) Downloaded 344 times
demieg
No way.
Huami recommends using 10 images to display the battery charge. The preview in the editor was checked for exactly 10 images. If you use fewer images then it will work, but it may not match what is displayed in the editor.
demieg
Post by demieg »
SashaCX75 Thx, I'll try again with 10 images!
tsvettydjs74
Post by tsvettydjs74 »
With this program can I change an already existing face for t-rex pro who is with .bin? And how does this happen?
Guydu91
Post by Guydu91 »
tsvettydjs74 wrote: 02 Apr 2022, 06:43
To open and create watchfaces for T-Rex Pro you must use this editor:
viewtopic.php?f=29&t=1888
Read the whole post carefully. It's a bit long but very useful...
Best regards
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Giraz82
Post by Giraz82 »
Hello to everyone!
I'm new to WF editing, so please be patient if my question is stupid.
I want to edit an existing WF, but when I download it, I just get a zip file, not a bin file.
I tried to add bin extension and to unpack with this tool, but it didn't work.
How should I proceed?
The WF is this one: https://amazfitwatchfaces.com/gtr/view/25903
Thank you in advance.
Has thanked: 438 times
Been thanked: 2141 times
Giraz82 wrote: 08 Sep 2022, 23:59
Hello to everyone!
"AmazFit WatchFace editor for Windows by SashaCX75"
That you can't unpack because the tool you are using It's a GTR tool. It's not for GTR3
But that WF link you talk about is GTR3 watchface
Normally, the watchface of the GTR3,4 already has a zip extension.
If you want to unpack and edit GTR 3 you must to use this program
"Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)"
!! Watchfaces of GTR , GTR2 , GTR3 have different format and cannot sync across models !!
So after unpacking, you can only use the unpack image to create a new watch face.
Giraz82
Post by Giraz82 »
Thank you so much!
ziramog777
Post by ziramog777 »
Its valid for Trex2?
ziramog777 wrote: 13 Jan 2023, 12:27
Program for editor or create T-Rex 2 watchface , you can found in this link :
HenriiTT
Post by HenriiTT »
Amazfit Band 7?
