Has thanked: 14 times
Mazaias
Post by Mazaias »
SashaCX75 wrote: 07 Jan 2022, 14:16
Alternative watch face editor GTR 3, GTR 3 Pro, GTS 3.
Thanks!!!!
I was looking forward to it! She knew you wouldn't let us down.
The huami editor is not bad, but it is much better not to depend on the cloud and also absurdly they do not have the circle scale, which you do include (this will allow me to more easily convert my previous GTR wartchfaces to GTR3). As soon as I can I try it.
Sorry for my bad English and thank you very much again!
Mazaias
Post by Mazaias »
The option to add climatological data is disabled. Will it be available in future update?
The number of images for heart rate indicator is locked at 6. Can you make it variable as in the rest of the indicators?
Great job. Thanks.
Mazaias
Weather related items will be added in the next update.
There are only 6 images for the heart rate, this cannot be changed. This is due to the fact that the watch only understands 6 heart rate zones.
Mazaias
Post by Mazaias »
SashaCX75 wrote: 07 Jan 2022, 18:46
Yes, I know that's why, but I for example in my last sphere (and I have seen it in other authors) I have used only three levels to simplify and save space on the screen. In fact, Huami's online editor recommends using 6 levels but allows you to use the amount you want.
The solution that I have done in the test that I am doing of the program is to use the same image for levels 1 and 2, 3 and 4, and 5 and 6.
Hopak
Post by Hopak »
Hi, I have to absolutely acknowledge the maximum and great software for editing GTR 1-3 dials and the great work you do Sasha CX 75. And huge thanks!
kyle
Post by kyle »
I'm coming.
如有需要可联系!
amazfit@hw
Post by amazfit@hw »
Hello SashaCX75 thanks for the great work for making life easy for watchdial makers. I tried to load the .zip file packed from to GT3 v1.0 but is saying wrong dial type for GTR3 selection... is there something I am doing wrong? Thanks for any tips
amazfit@hw
I downloaded a dial from amazfitwatches here and then unpacked and repacked and cannot upload ... get error message wrong dial file type
amazfit@hw
I sorted it out ... I am using mac running a windows emulator and need to load under windows environment not mac environment ... not sure why but seems to work ...
Has thanked: 1162 times
Been thanked: 279 times
amazfit@hw wrote: 09 Jan 2022, 07:31
Attach the file here, we'll see what's wrong with it.
FeRu
Been thanked: 8 times
Post by FeRu »
Thank you SashaCX75 so much for this editor😍.
It's very easy to use like previous editors and it's simpler than huami one that Ill tried use but it's wonky and few times pissed me off :evil:
I'm waiting for next relase with editable weather section and finally i can buy GTR3 Pro and easier port my WF's to new watch thanks to you 8-)
Keep up great work😉
Dema
Post by Dema »
SashaCX75 hi!
I really thank you for your work, without your editor i was unable to add shortcuts to my watchfaces!
I'm facing a little bug (I think) but I don't know if is editor related or is native of zepp os management.
Practically, when heart rate value is under 70 (More or less, i don't have the editor under my hands now) the circle progression doesn't move and it's impossible set higher sensibility, even the image progression give ever the first image until (for me) to much high levels.
Would be great can set a higher sensibility in some way!
Thanks anyway for your awesome work! :D
Dema
When creating a circular progress for heart rate in the editor, I was guided by the behavior of the arrow pointer for heart rate on the dials created on the Huami website and on the indicated heart rate zones in the Zepp app. Therefore, the countdown for circular progress starts from 71. This can be changed by manually editing the code in the watch face.
Dema
Post by Dema »
It can be changed also for image progression? And it's complicated to do?
I really don't know how do it :roll:
Have you in program for the future releases to add the option to view and edit the code inside the editor?
Thanks anyway.
Matejgigi
Post by Matejgigi »
Anythink for BIP U PRO, do you know how I make or convert watch face?
Dema
No, this cannot be changed for a set of images. To change this for circular or linear progress you need to open the watch face, in the "watchface" folder open the "index.js" file. In this file, find the line
let progressHeartRate = (valueHeartRate - 71) / (targetHeartRate - 71);
and in it change 71 to the number you need.
Dema
Post by Dema »
Thank you very much!
I have another question to you, if I can!
A user that download my dials, just wrote me that have a problem with two version of the same watchface.
Practically, i did a dial in different versions, analog and digital and obviously i used the same base.
The user told me that wants keep both versions in the watch, but when he try to install, one replace the other.
The watch face was renamed obviously, but I add only a "_ag" at the end of the name.
Can you tell me if it's name related? Or If not, there is a way to to prevent that?
Thank you very much for all.
FeRu
Post by FeRu »
Dema wrote: 11 Jan 2022, 19:15
@SashaCX75
Yo need change (generate new) watchface ID in background section
Dema
Post by Dema »
FeRu wrote: 11 Jan 2022, 19:50
@SashaCX75
ohu thanks a lot!
Dema
Post by Dema »
Hello SashaCX75,
Sorry if I disturb again.
I noticed that some gts2 dials have curved and rotated numbers (hope you can understand me, my English is awful).
I'm wondering if it possible also with gts3 in some way or, if not, if maybe will be possible in the future.
Thanks again
Dema
Do you mean displaying data at an angle or in a circle?
This cannot be done in the editor (in some cases the date or time can be shown at an angle) and such functionality is not planned. But if you are a little familiar with programming, then such a result can be obtained. Here are some examples of such dials.
https://amazfitwatchfaces.com/gtr/view/20494
https://amazfitwatchfaces.com/gtr/view/20048
Dema
Post by Dema »
Yeah that's what i meant!
How I can do this?
JACKpark
Post by JACKpark »
hi sashacx75 thx for making a good program.
I tried it right away and i was able to make it. thx again.
and i want to ask u a question.
ur next ver. , Can random location AOD be possible?
becoz This watch is equipped with OLED.
FeRu
Post by FeRu »
I have litthe request and question also SashaCX75 . There will be also system font option for some elements like in GTR2 editor? And if yes it will be possible to add selector for system font and ex. separate folder for makers when they can put different .tff font file and use custom system fonts for WF making? This option can give many new posibilities 🤔
Users browsing this forum: No registered users and 8 guests
