Been thanked: 1044 times
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
amazneo
Has thanked: 12 times
Post by amazneo »
SashaCX75 wrote: 12 Apr 2021, 07:58
Of the advantages of such dials, I consider only working shortcuts and the ability to set different fonts and independent coordinates for tens and units in time.
Amazing work you've done SashaCX75!!! This is by far the most comprehensive editor outside of Zepp's own software!!
I have some questions about the work flow for the app.
How does the JSON image index # know which image file to load? I don't see any filename references in the JSON?
Is this the order how we start building new watch face bin files?
1. Select the UNPACK/PACK tab.
2. Select "Unpack compressed Bin (GTR/GTS) > Find a bin similar to your design and unpack
3. Copy our own files over the newly extracted files. Is this when we replace the png files?
Question 1: Do the images have to be in a specific order? For example, does index 0002 - 0011 have to be Hours > Tens images, etc?
Question 2: Is there a maximum limit of 108 images (Index 1 to 107)?
Question 3: When I select index # and click "Images: SELECT" - The result is all of the index # reset to 0? How do we add more index #?
4. Select EDITING tab.
5. Edit each image set (Background, Time, Date, etc) and adjust position.
6. Select UNPACK/PACK tab.
7. Click PACK AND COMPRESS BIN.
Is this exactly how we create new watch faces for the GTS model watch?
And, is this the command we use to extract and compress for the GTS model watchface?
Thank you!
Rubens.vailati
Post by Rubens.vailati »
Hi I wanted to know if it is available or possible to convert the whatchface created for Huawei Watch GT3 in the format suitable for the amazfit gtr3 pro thanks
naikviraj128
Post by naikviraj128 »
Hello Developer,
Is there an Option to Convert Watch faces from GTR 2 to Verge Lite or GTR 47mm in this Watch Face Editor.
amazneo
1. Judging by your questions, you are using the GTR47 / GTS watch face editor or the GTR47 / GTS to GTR2 / GTS2 dial converter (I do not recommend using it). The program for GTR2 / GTS2 is being discussed here.
2. If you are editing an existing watch face, then the procedure is correct. If you want to create a new watch face then you need to:
- create a new folder,
- put the necessary images into it,
- on the "Select" tab, select all files in the folder,
- on the "Editing" tab, click the "Save Json" button and save it in the folder with images.
3. The json file contains the "ImageIndex" parameter that sets the serial number of the image. Therefore, after creating a project, it is better not to change the order of files, but add new image files to the end of the list.
4. Image files should start with a background image and go in order. The rest of the pictures can go in any order. I don't know about the limit on the number of files, but with a large number of them, the size of the watch face may be larger than the allowable one.
5. Question 3 I did not understand. If you want to add new images to the project, the easiest way is to copy the new images to the project folder and reopen it.
6. Yes, these are commands for extracting files and you do not need to change them.
Rubens.vailati , naikviraj128
This editor allows you to convert watch faces between GTR 2 / Zeep E / T-Rex Pro
amazneo
Post by amazneo »
Pal57 wrote: 10 Oct 2021, 16:25
where can I find new Wf for GTR 2 with "Layer Order" and the "Editable Elements".
Pal57
Did anyone figure out if there is a way to specify layer order?
amazneo
Post by amazneo »
SashaCX75 wrote: 11 Dec 2021, 09:05
@amazneo
Geeze, I thought I posted a reply to this last night but I don't see it on here?
@SashaCX75
Thank you sooooo much for your AMAZing app and sharing your hobby with us!
I love this app more and more as I learn how to use it!
This is the version that I am using to create a watch face for the GTS - it is a gift for my mom and I could not find any watch faces with really large fonts - so I set out to create one myself. I have to try to get this done before Christmas:
This is the design that I'm working on (going to add temperature to the top left corner - still a work in progress):
QUESTION 1:
Is there a way to specify z-order for the elements? I would like to specify the z-order of the WEATHER ICON element. If this is not possible then I will have to tweak my design.
QUESTION 2:
In 12H time mode - I notice on most of the watch faces on this site that the time is displayed like this:
08:24 PM
Instead of how the OEM Amazfit watchfaces which display 12H mode time like this:
8:24 PM
Is there a way to disable the "leading zero"?
Thank you again!!!!
amazneo
You are using a converter. There are no such possibilities in it.
Use AmazFit WatchFace editor 2 v7.3. In it, you can change the order of some elements and turn off the display of leading zeros for hours.
amazneo
Post by amazneo »
SashaCX75 wrote: 12 Dec 2021, 18:06
@amazneo
@SashaCX75
Thank you!!
Do you mean this?
https://www.dropbox.com/s/qp0ii7dspf91x ... 3.zip?dl=0
amazneo
Post by amazneo »
Does anyone know the file size limit for bin watch faces for the GTS?
Cooperphile
Post by Cooperphile »
What font is used for the system font, or can you say what font your app uses to simulate the system font? I'm specifically interested in the T-Rex Pro, in case it matters.
Thank you.
Cooperphile
The editor uses the "OpenSans_Regular" font. What font is used in the watch, I do not know.
amazneo
Post by amazneo »
Hello, I am a bit confused about which tool to use to create watch faces for the GTS?
I started out using this tool:
viewtopic.php?p=8844#p8844
But, then was told that I should be using this tool:
AmazFit_Watchface_Editor_2 7.3
But the AmazFit_Watchface_Editor_2 7.3 does not create bin files compatible with GTS model?
Can someone please offer some help?
Guydu91
Has thanked: 59 times
Post by Guydu91 »
amazneo wrote: 18 Dec 2021, 04:42
Hello Amazneo,
If you're searching a software for GTS1 watchface, it's here :
viewtopic.php?t=1076
The maximum size of the bin will be 1,5 Mo for GTS1.
Best regards.
Caria_L
Post by Caria_L »
Hi, how can I use Chiness Lunar Calendar for GTR model?
tibiszabo
Post by tibiszabo »
Hi!
Gtr 3 gtr3 pro editor where can it be found?
BennyH93
Post by BennyH93 »
Hey
sorry first of all for the Google translator....
I come here unfortunately not quite with the solution for the GTS 2 mini...
apparently some have managed to create the Watchfaces.
a "How to" or a ready variant of a Builder would be here really very nice.
ps.
you can also send me a PM
thanks a lot
tZap
Post by tZap »
tibiszabo wrote: 02 Jan 2022, 16:13
Hi!
Looks like SashaCX75 is still working on it?
https://github.com/SashaCX75/AmazFit-Wa ... r-Type-GT3
dinhlam91
Post by dinhlam91 »
Thanks, @SashaCX75.
I'm waiting for a version for GTR3 & GTR3 PRO.
BennyH93
Post by BennyH93 »
neFAST
Hey you build some very nice WF's but I want to modify some of them or create some new...
you are one of those how made it ;)
I whish u could show us a HOW TO please :)
Julien
Post by Julien »
I'm doing everything manually with https://github.com/Tnxec2/py_amazfit_tools
sirantoninyc
Post by sirantoninyc »
Firstly, thanks for this editor! I have had success with altering images to change the appearance of the watch faces.
My question is... is there a way to refresh the editor to see the changes take affect in real time and then undo them if a mistake was made?
I have been changing the images, adding them to the folder, then saving the json file, creating a new bin, and unpacking it to see the changes. I've been trying to make changes to the code but I don't see the changes in real time or I cannot find a refresh option.
Anthony
sirantoninyc
There is no undo function in the editor.
If you have changed the image file, then in order to see these changes in the editor, you need to change any parameter or data for preview on the Browse tab. After that, the preview image will be updated. You do not need to manually change the code.
sirantoninyc
Thank you for the quick reply.
The reason I was trying to edit the code is to remove the distance measure in the AOD (always on display). Then where the distance was located add the sunrise. The goal was to see the sunrise and sunset when the watch goes into the AOD.
The watch face I am looking to edit already has the sunset appear, where the seconds were displayed, when the watch goes into AOD. (It also shows the weather during AOD, where the date appears during normal live operation.)
I would like to see both sunrise and sunset during AOD. I see in the code, under screen idle, that the seconds are not listed there but the hours and minutes are in the code. I was attempting to remove the distance code, under screen idle, then add the sunrise to that X and Y position.
I was trying to do this from the atmosphere tab, but I was getting a little confused.
sirantoninyc
I was able to add both the sunrise and sunset times during the AOD (always on display) and tweaked the UV, Humidity, and Wind display.
Users browsing this forum: No registered users and 8 guests
