Has thanked: 14 times
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
FeRu
Been thanked: 8 times
Post by FeRu »
asoo wrote: 24 Sep 2021, 14:56
I made it for real format GTR2 ready , you can modify from this
https://amazfitwatchfaces.com/gtr/view/17999
Thank you very much bro ;) Today I will post modded version and few other your converted watchfaces
with some mods.
mario_j_costa
Post by mario_j_costa »
And the editor for stratos 3?
fash99
Post by fash99 »
Hi.
Is it possible to port a watchface from GTS to GTS 2e with this tool?
I would like to port a good one from my old GTS.
JPinTX
Post by JPinTX »
First, thank you SashaCX75 for an amazing tool. I have a GTS2, and am having an issue with the AOD face. Specifically, the Activity Goal/Pointer always points to 50%, no matter what the Steps/Steps Goal values are. I've copied from the Main Screen, and double checked all entries. The tool shows the correct pointer position on both the Main and AOD screens, but when I sync to my watch, the Main screen shows the correct pointer position but when it changes to the AOD screen, it always points to 50%. Apologies if this has been addressed in previous comments (I tried to read through them). Thanks for the help in advance.
Julien
Post by Julien »
Dear SashaCX75 do you think it would now be possible to integrate the GTS 2 Mini in your editor. I think kontranik and I have covered 95% of the parameters, some of us have unpacked and repacked some complex watchface and it has proven to work.
Currently Huami editor is broken in several ways (digital aod, animation) and amazfit_tool is the only way to generate a working watchface.
Thanks in advance for considering this request!
neFAST
No. You yourself know how much the dials of the GTS 2 Mini differ from the GTS 2 and how many new parameters you had to add. Therefore, for the GTS 2 Mini you need to make a new editor.
Some of the parameters for GTS 2 Mini are similar to those in GTS 2. But some parameters have no analogues and for them you will need to rewrite the entire code. I'm not interested in this anyway. If someone starts creating an editor for the GTS 2 Mini and decides to make it based on my editor, and not make a completely new editor, then I can answer questions about the existing code.
JPinTX
I have not heard that anyone had problems displaying steps. Perhaps it will be clearer if you give a specific dial on which there are such problems.
JPinTX
Post by JPinTX »
@SashaCX75 I'm not having an issue with absolute STEPS (the specific number of steps I've walked today)... the issue I'm having is displaying % of STEPS GOAL using a Pointer (i.e. I want to have a dial with a pointer that shows from 0% to 100% of Steps Goal, not the number of Steps... If my Steps Goal is 5000 steps, and I've walked 1300 steps,
the pointer should point to 26%, if I've walked 4500 steps, the pointer should point to 90%). I'm setting this up under ACTIVITY tab, ACTIVITY GOAL subtab, POINTER.
When I change the test values in the tool, it shows correctly on both the Main screen
and AOD screen.
However, when I sync watchface to watch, the Pointer is correct on Main screen,
but incorrect on AOD screen (it always points to 50% no matter how many steps I've taken).
I've simplified my watchface for testing in case there is a memory/size issue, but it still has a problem on the AOD screen. FYI, the dial on the left shows the Battery %, and is correct on both the Main and AOD screens.
Thanks for the help!
JPinTX
Indeed, the ACTIVITY GOAL option on the AOD screen does not work. This is a firmware error.
In your case, I advise you to use the STEPS parameter, the pointer will show the progress towards the goal of the steps.
JPinTX
Post by JPinTX »
SashaCX75 That works! Thanks so much for the quick reply and again for a great tool. I see more options in v2 of the tool and just have to try them out. I thought I had figured out most of the ACTIVITY GOAL subtab, but couldn't understand why the Pointer didn't work only on the AOD screen.
adixxxxxx
Post by adixxxxxx »
i would really appreciate if something can be done regarding GTS2 mini.
ig its the best watch, and considering the price, probably the most sold.
please add a provision to make watch faces for the mini. TIA
qd1985
Post by qd1985 »
谢谢楼主分享
If you have any questions about the GTS 2 mini, it is better to contact the neFAST user. As far as I know, he has made a lot of progress in terms of working with these dials. Maybe he wants to create a separate thread on this forum.
Those who have problems installing python can use this utility. It is based on this project, but should work without installing python. I can’t check its performance, I don’t have a GTS 2 mini.
AmazFit_PackUnpack-GTS2mini.zip
(8.7 MiB) Downloaded 428 times
Pal57
Post by Pal57 »
where can I find new Wf for GTR 2 with "Layer Order" and the "Editable Elements".
Pal57
Pal57 You can search the forum for watch faces with the tag "editable zones"
https://amazfitwatchfaces.com/search/gt ... le%20zones
soxnbaur
Post by soxnbaur »
SashaCX75 : I just wanted to say thank you for your great work on this project. I am not a freak and I enjoyed much using your program to modify watchfaces.
So I have much more fun with my GTR 2e.
Again: Thanks!!!
carolef
Post by carolef »
How to add things to idle screen? Or can anyone edit my watchface to name of weekday and date will be shown on idle?
Andrei_Richea
Post by Andrei_Richea »
Hi Sasha , y have a problem after convert the watchface with you program from gtr to Trex-Pro everything goes ok ,y`m installing the watchface to the watch but The ¨¨ year ¨¨disappear from watchface and y cannot find the reason . Can you help me ? Thanks your are the best.
carolef
There is a toggle switch on the edit tab at the bottom. You can select the items on which screen to edit.
Andrei_Richea
If you converted dials from GTR using a converter, then not all elements work on such dials. The display of the year does not seem to work either.
If you converted GTR 2 dials using an editor, then I do not know why the year display does not work. This may not work on the Trex-Pro. I can only check on GTR 2.
Andrei_Richea
Thnak you very much for the advise !!!
domenicopardo
Post by domenicopardo »
Per SashaCX75 .... innanzi tutto gran bel programma.. Complimenti.
Nel programma c'è una cartella \Tools con all'interno tre eseguibili : GTR2_Packer.exe - main.exe - SplashScreen.exe ............ a cosa servono ???? , grazie ancora
domenicopardo
GTR 2 Packer.exe - for bin file compression and decompression. Dials don't work without compression.
main.exe - for packing and unpacking the bin file (bin> json).
SplashScreen.exe - startup splash screen.
domenicopardo
Ok!, Grazie
shamanteras
Post by shamanteras »
Thank you SashaCX75 for this great tool!
